View Post
Official Freewing 70mm F-16C Falcon V2 Thread
Yeah the admiral is the same as the LemonRX and allows for it. I will be switching mine to try it here in a little bit. landing slower is always better... as is using spoilerons for better high alpha performance...
Thanks guys! Ryan - when you get it all set, please tell me what you did... I'm going to look into that gyro. Also, I'm using the Graupner MZ24 radio - they just came out with a receiver/gyro combo, will check later to see if that will handle it properly with ailerons plugged into 2 channels.
You can do flaperons with the new Admiral gyro rx. You still have to set it up through the radio AND select the dip switches on the gyro itself.
Also splitting ailerons is still necessary. I simply left one in the blue box and the other in my aux channel on the rx which is channel 6, what would be flaps if it had them. I'm setting up 70mm f16 right now.
I believe it will eliminate the use of a gyro (see HOWEVER below). The gyro must control the ailerons as a single signal (ie, requiring the use of a "Y"). Using wing type "flaperon" requires each aileron servo to be plugged into separate channels. The Hobby Eagle has options of "normal", "delta wing" and "V-tail", hence it won't apply stability function to flaperons.Originally posted by Marktur View Post
I have a question too: I have a Eagle A3-L gyro, and I'm setup using FLAPERONS, bypassing the blue box for aileron and plugging them into the reciever direct... my question is: does this remove the opportunity for me to use a gyro? If not, what should I get, and is there a video or thread on setup?
Thanks all!
HOWEVER, you can still plug only the "aileron" servo into the stabilizer and it will control just one aileron. It'll work but will give a weird flight characteristic which may create other problems in certain situations. The stab may still over drive that servo during heavy stabilization.
My F-16 utilizes flaperons and it does assist in take offs and landings tremendously. The plane really doesn't need a stabilizer. You simply have to know when and when not to use 1/2 and full flaps and to dial in restricted aileron travel for each case or you'll over drive the servos. (IE, I ONLY use full flaps on the final straight approach. Cranking full flaps during any kind of banking or turning could result in the plane taking a dirt nap. Keep the throttle up until the plane has settled in on the "home stretch".)
I have a question too: I have a Eagle A3-L gyro, and I'm setup using FLAPERONS, bypassing the blue box for aileron and plugging them into the reciever direct... my question is: does this remove the opportunity for me to use a gyro? If not, what should I get, and is there a video or thread on setup?Originally posted by Phatbob View PostQuestion for the Gyro guys...................
I have a 2-axis Gyro that I am toying with installing for use on elevator and ailerons. I assume we bypass the factory Control Board completely as only signal wires come from the board to the receiver. I would be using y-harnesses from elevator and aileron servos to gyro, and gyro direct to receiver?
Thanks!!
Thanks all!
I wanted them for the scale effect. Yea there's not much of a roll out after touch down on a high alpha landing. I picked up a nice set of wheels with brakes but I don't think they were will fit the stock struts. Not enough axle is exposed and up grades are out of stock. There also kinda heavy.
I don't think you would want to. I have been messing with my Elevator throw and have it where the plane is barely moving at touch down now... It just takes some time to get right. I am also going to try spoilerons and flaperons to see what I can do as well...Originally posted by Apache Jets View PostHas anyone put electric brakes on one of these yet.
Finally finished mine tonight and I hope to maiden this weekend if the snow holds out. I'm balanced with a 5000 6s Gforce elite and I had to toss in 3/4oz to the rear. I install the counter weight inside the edf cover. Upgrades include missle kit, afterburner kit, metal retracts, and nerf whistles.:Cool:
Has anyone found a good AIM-9 sidewinder for the wingtip rails? I’m turning the new 70mm BAE-Hawk into a Desert Hawk and got some extra 70mm F-16 rails for it. They’re slightly too big but will work at 9”s. I’m looking at the Freewing 90mm F-15 missiles and tanks for it, don’t know how long the AIM-9s are though. Anyone have them?
Dear Alpha or should I say Obi Wan EDF Kanobi Thanks for the very good advice. I didn't consider this airflow constrictions when putting the 80 in. I'll try opening up the inlet somehow or adding an extra cheater duct somewhere. I'll also keep an eye on the gear blocks. I added the gear upgrade to it so hopefully that helps. I figured it's about time that I start pushing the planes limits after it pushed mine thru several sets of parts when it was pushing my limits.
Got my weapons kits today. I was surprised to find the AGM's weren't removable. They are now!2 Photos
Thanks!!
Hey WildBillG, welcome to Hobby Squawk! It's always nice to see another DIY guy willing to test an aircraft's limits.
Watch your FSA % inlet and outlet when you're shoehorning in another 80mm fan... you're probably starving the fan up front and/or fighting a backlog out the back. I dimensioned this F-16 specifically for our 70mm fan.
I also recommend reinforcing the main retract blocks if your AUW surpasses 15% stock.
Be safe, have fun, fly low!
Greetings everyone, I am a new member who has 6 of the Freewing EDFs, mostly 70 and 80mm, with one F104 90. I have been flying the white camo 70mm F-16s for several months, and couldn't agree more that they fly great, but they are not exactly fast. I just upgraded mine with the 70mm 12 blade 6S 2938-2085, red fan that is listed as an upgrade for the 70mm F-104, and WOW, what a difference. Flying on a 6s Admiral 4000 and this thing is at least 10-15 MPH faster than it was with the stock 70mm and getting a solid 3 1/2 minutes flight times WOT With plenty of reserve.
also just replaced the 70 in a pretty beat up F16 Camo fuselage with the 80mm out of a scrap F-5, with the hopes that it would be even faster. Had to carve out of a bunch of foam to get it in there, and I made sure to use the ESC from the F-5, but the motor must have taken one to many crashes as it was slower than the original F-16 70mm fan. Guess I'll try a new 80mm unit in it since it's already carved out to fit one. I'll let everyone know the results.
A step up for sure. A really nice bird all around:Cool:.Originally posted by Phatbob View PostI just sprang for the Arctic Pro with upgraded gear and weapons. Also have an afterburner light set coming. Kinda getting bored with my Phase III F-15. I hope this is considered moving up. :Cool:
Can flaperons be setup using an A3-L Gyro? And if so, please tell me how.
