  • Rcjunkey
    Love that RC stuff since 1990
    • May 2018
    • 23
    • C17loadmaster
      Retired USAF Aircrew
      • May 2018
      • 371
      • Auburn, CA
      Mine is set up the same way except I don’t have a piece of wood between the battery and ESC. It’s is directly in the intake airflow on one side and flat with the battery tray. I’ve flown this plane more than any other EDF.
      • C17loadmaster
        • May 2018
        • 371
        • Auburn, CA
        • Ron1950
          Retired ATC
          • Oct 2015
          • 887
          • brandon ms
          Flew the f86 today off a great tar surface. It was first few flights sense i installed the fms 2000 kv in runner wow this plane with the upgrade motor is a beast. Fast. Sounds great. Powerfull vertical etc. hoghly recomend this new fms fan.
          • Rcjunkey
            • May 2018
            • 23
            Does the FW F-86 need any elevator mix with flaps?
            • C17loadmaster
              • May 2018
              • 371
              • Auburn, CA
              No, I have none set. My landing flaps are set up for maximum deflection too. They’re almost 90 degrees down
              • Rcjunkey
                • May 2018
                • 23
                Good to know thank you for the quick response.
                • C17loadmaster
                  • May 2018
                  • 371
                  • Auburn, CA
                  No problem. The low wings are easy to set up flaps and elevator mix. High wings like the F-14 require a ton of up elevator. I actually destroyed my F-14 on my second flight by testing full flaps while flying too fast and too low. I added a 3 second delay to make them more scale and in doing so made them too slow to retract before it exploded into the ground like you wouldn’t believe
                  • DCORSAIR
                    • 1918
                    • Selma, Ca.
                    :Scared: Wow, I bet that was a mess of foam..........:Crying:
                    • C17loadmaster
                      • May 2018
                      • 371
                      • Auburn, CA
                      Yes it was...
                        Ouch!:(:Crying:
                        • fhhuber
                          • Aug 2015
                          • 1476
                          Its not a high wing vs low wing issue.
                          Its the wing geometry vs the flap geometry in relation to CG. (among other factors)
                          At speed, the F-14 acts somewhat like a flying wing and the flaps act like elevons. (yes, I have one)
                          I've seen this with a few swept wing models.
                          I had a Nitroplanes Falcon 120 that I stuck a 5 inch EDF on. Programming the ailerons for elevon the ailerons had more pitch authority than the elevator. Because of the huge EDF nacelle blocking airflow over the horizontal tailplane, I could completely lose pitch control with the elevator when chopping throttle, but could loop on the ailerons in elevon mode.
                          • C17loadmaster
                            • May 2018
                            • 371
                            • Auburn, CA
                            with the wings extended or retracted? I understand the rest of what you are saying
                            • Ron1950
                              Retired ATC
                              • Oct 2015
                              • 887
                              • brandon ms
                              where did the edit button go?
                              • fhhuber
                                • Aug 2015
                                • 1476
                                I don't recommend trying to put the flaps down with wings folded back... You'll strip the servos.
                                There's enough sweep with the wings extended for the flaps to act like elevons. Amplified if you linked ailerons to flaps for scale flap system.
                                • wvrailfan
                                  • Sep 2013
                                  • 682
                                  • West Virginia
                                  We are expecting several days of rain starting tonight or in the morning, remnants of Hurricane Florence, so I figured I'd get in a couple of flights today. I forgot the drop tanks at home, so it may look a little nekkid.
                                  I am starting to like this plane.
                                  • C17loadmaster
                                    • May 2018
                                    • 371
                                    • Auburn, CA
                                    Here’s a clip of a nice sunset flight. The F-86 is so fun and stress free.
                                    Sorry about the dog barking. I have my wife video. I refuse to wear a camera on my head
                                      • 4878
                                      C17LM, Bravo Zulu. Best, LB
                                        Nice flights, guys! Wvrailfan, stay safe in Florence. I'm sitting through this Super Typhoon making its way near Hong Kong right now. Only indoor flying today!
                                          You stay safe too... The remnants of Florence will be passing right over us tomorrow. Expected to be a little wet and windy but nothing like the coast saw.
