  • Corsair nut
    Jets...warbirds...mmm hmmm
    • 218
    • Tehachapi ca
    I got rid of my sabre far too quick. I really bees to give it another shot with todays 9bl inrunner setup
    • Bajora
      AA6JB
      • 462
      • Sonoma County, California
      Originally posted by Corsair nut
      those landings were perfect!
      Thanks Brent ... I'll pass the compliment on to Michael. though I think he hangs out here on Squawk too? But that's why I whipped out my handy iPhone video camera today ... he was killing the landings and I couldn't resist shooting them!
      Your F-86 looks awesome, as usual Brent! You always raise the bar a dozen building stories or so!
      • Corsair nut
        • 218
        • Tehachapi ca
        Well thanks :p sadly i sold my sabre before i repainted it. I need to find amother one and do it up right. They are fantastic flyers! Did you ever see my recent f14 i did?
        • Waconut
          • Feb 2020
          • 310
          • Cincinnati, Ohio
          Hi guys,
          My plan is to maiden my F-86 this weekend. I put the maiden on my Avanti over the weekend and found the aileron thrown to be too sensitive set per the manual. What are you guys using for throws on your F-86’s ?
          Thanks!!
          Anthony
          • Phantom
            • Mar 2019
            • 504
            • M.D.
            F-86 is a docile roller at best, put in as much throw as you like with minimal expo, and you'll have the best of both worlds
            • Waconut
              • Feb 2020
              • 310
              • Cincinnati, Ohio
              I just got back from the field. I tried to maiden my F-86 and no luck. We have a well groomed 800ft grass strip cut very short and I could not get the F-86 to rotate. Just would not get enough speed. I have the HP version as well. I tried no flaps, half and full flaps. I also calibrated the ESC again to be sure I was getting full power.
              Anyone have any suggestions for operations off a grass field with this plane ?
              • Quickstop
                • 275
                I know with the real F-86 if the nose comes up too soon in the takeoff run the drag increase actually keeps the plane from accelerating and hugely increases the takeoff run. On the model....don’t know
                • Waconut
                  • Feb 2020
                  • 310
                  • Cincinnati, Ohio
                  I can’t get the nose up, it will not rotate. I have the CG set where it will rest on its tail and the nose will fall when you lift the tail about 1”.
                  I may have to see about modifying it for slightly larger wheels.
                  • C17loadmaster
                    Retired USAF Aircrew
                    • May 2018
                    • 371
                    • Auburn, CA
                    This was almost expected when the attached pic was posted in one of your posts a while back.... It has to be extremely nose heavy or tail heavy (without the lipo installed) being as you stated the correct CG. Make sure the tires are not too tight and rubbing on takeoff, and of course... ESC Calibration.
                    • Waconut
                      • Feb 2020
                      • 310
                      • Cincinnati, Ohio
                      I found my problem, a wet grass runway full of grass clippings. I had to pull the EDF unit to remove all the grass.
                        • 4819
                        Waconut, That'll do it. Glad it was something simple. Looks like you might want to add some type of grass guard device to the bottom inlet. Hmmm.... Best, LB
                        • Waconut
                          • Feb 2020
                          • 310
                          • Cincinnati, Ohio
                          Hi LB,
                          I added aluminum window screen material over the cheater hole. I am also going to stiffen up the front strut to keep is from compressing during the takeoff run. I will try again this weekend to get the maiden flight in.
                          • Waconut
                            • Feb 2020
                            • 310
                            • Cincinnati, Ohio
                            Hi Guys,
                            Well good news and bad news. I was able to get the maiden flight in this morning and she flew great. The only adjustment was 2 clicks of right aileron and it was tracking straight and level. I went to put the 2nd flight on it and hit a small hole or bump in the runway just before rotating and it turned sideways and ripped the main gear out .
                            I did film the maiden flight with my sport cam but was disappointed to find out I had the camera angled too high and was shooting over top of the plane during the takeoff and landing. I did get some usable flight footage. The plane really flew great and I greased the landing with a nice smooth touch down on the mains. I will get it patched up and fly it again next weekend. Taking the A-10 out tomorrow.
                            Here is the video of the maiden. https://www.youtube.com/watch?v=0lNcXlci_dA
                            • Waconut
                              • Feb 2020
                              • 310
                              • Cincinnati, Ohio
                              Hi guys,
                              What would be the best glue to reattach the retracts into the wing pockets? I have 5 min epoxy, Gorilla glue or the tube glue supplied by Freewing.
                              • Waconut
                                • Feb 2020
                                • 310
                                • Cincinnati, Ohio
                                I flew the F-85 again today. It just does not like a grass runway.
                                • C17loadmaster
                                  • May 2018
                                  • 371
                                  • Auburn, CA
                                  Just glue them back in... it was guaranteed to happen sooner or later. Doesn’t matter if there were nothing but perfect landings. I ripped mine out before flight on my 2nd version 😀
                                  • coyote137
                                    • 14
                                    While waiting for mig29 and saab gripen to arrive here in Scotland.
                                    I decided to repaint my 80mm F86
                                    Started with Tamiya primer over existing decals.
                                    Airbrush pattern with Tamiya paints
                                    Design and make my own graphics
                                    Weather and dirty with oil pastels
                                    then x2 coats clear matt acrylic varnish
                                    all done in x2 days
                                    Click image for larger version  Name:	20200910_122342.jpg Views:	0 Size:	89.1 KB ID:	274317
                                      • 8748
                                      I flew the F-86 again today. It just does not like a grass runway.
                                      https://youtu.be/RWuQtlCZ344
                                      That's exactly how the 2 Sabres behaved on grass a couple years ago at our old field. Most times, it wouldn't make it off the ground before the end of the runway. Even just rolling on the rough grass ripped out the retracts. Mind you, that was back when the plane came with the old outrunners. I've got the inrunner in mine and it's got pretty good push, though I haven't tried it on grass yet.
                                      Does yours have the inrunner?
                                      • Waconut
                                        • Feb 2020
                                        • 310
                                        • Cincinnati, Ohio
                                        Yes I have the inrunner version. The grass has to be fresh cut and blow all the clippings out of the runway.
                                        Once I get it airborne it is a blast to fly and it looks and sounds great in the air.
                                        • Waconut
                                          • Feb 2020
                                          • 310
                                          • Cincinnati, Ohio
                                          coyote137
                                          Your pics are not showing up for me.
