  • dahawk
    Augermeister
    • Jun 2013
    • 1006
    • Keller,Texas
    R,
    I mount the rear batt as far back as possible and then butt the front batt as tight as possible against the rear batt. They are 803g ea. The 5800's are 780g ea. Both options work great. Never really technically measured CG outside of the two finger method.
    Going to test in the A4. Should be fine. Pat is using them without any issues.
    Hawk
    • TSHobbies
      Hobby Squawk Warbird Pilot
      • Nov 2015
      • 671
      • Cartersville GA
      the white nose gear door part popped off on me again..this time I didn't notice it till I was home... so decided to fix it once and forall ..so far its working..haven't field tested it yet. just used a spare ball joint with a control horn screw on the end.. screwed it into the strut and put some CA there to keep it from rotating from vibration
      www.TSHobbies.com
        Good idea! Let us know how it works.
        • TSHobbies
          • Nov 2015
          • 671
          • Cartersville GA
          got to test this out over the weekend...works great..had two flights in with no issues....for that part anyway... I still managed to bounce it...again...looks like I might have damaged the nose retract..very floppy now, so got to take it apart and see what I did. ...first flight..pewfect..second flight., needed just a tad bit more power...
          www.TSHobbies.com
          • Dirty Dee
            • 768
            • Northern Illinois
            I 3D printed some functioning vents to replace the 4 that are molded into the fuselage. I'm debating doing the same with the inlets, but those might be a bit harder. I've attached the STL files for anyone who wants to do the same.
              Those look great! For those who can't print them like, ahem, yours truly, are you willing to print up a couple sets and if so how much?
              • Dirty Dee
                • 768
                • Northern Illinois
                Sure! Does $5 plus shipping work? I'll have to see if these can safely ship in a padded envelope or if it will need a small flat rate box.
                I've got some more A-10A specific details planned over the next few weeks if you are interested. I'll post those as I finish them.
                  Excellent! Yes, please do. This is something that is going to become more common place. I am going to try and get a 3D printer myself soon. Any recommendations? Check on the shipping and let me know. I definitely would like two sets.
                  • Dirty Dee
                    • 768
                    • Northern Illinois
                    I have a Josef Prusa MK2S, and they just released their MK3 with some major improvements.https://shop.prusa3d.com/en/17-3d-printers
                    I'll check out shipping early this week for you.
                      Looks like a darn good printer. Very high ratings and good reviews. Do you anticipate the MK3 to be even better?
                      • Dirty Dee
                        • 768
                        • Northern Illinois
                        Absolutely. I was contemplating upgrading my MK2S to a MK3, but I might just purchase the MK2.5S upgrade kit to get the magnetic removable PEI sheet. I really want the aluminum extruded Y-axis, but it would basically mean buying $500 worth of parts to build the MK3 as it is a major revision.
                        Its very easy to assemble, so I'd say look at buying a kit to save on cost.
                        • Dirty Dee
                          • 768
                          • Northern Illinois
                          And some more details and supplied STL codes. Gun Gas Purge Vents.
                            Man, where were you when I was making mine from scratch?
                            • Topshot19
                              Pilot
                              • 189
                              • logan utah
                              The easiest way I have found to share Work is by posting it on thingaverse. It’s a awesome site.
                              • Dirty Dee
                                • 768
                                • Northern Illinois
                                You got yours early :^)
                                Topshot19, I'll have to give that site a look.
                                • Czonio
                                  Chris
                                  • 17
                                  The last bit of exterior detail I had to complete before painting is now done. No ladder yet but the box and door are made as well as the vent covers just ahead of it. Paint goes on tomorrow.
                                  All though nice scoops, I had the fleet remove them due to gun exhaust interference with the AOA. All A-10C PE's had them along with Pave Penny removed.
                                    Welcome to Hobby Squawk, Czonio, and thank you for your service and sacrifice! Which unit were you attached to?
                                      Agreed. However the Euro Green one I moddled was the last A-10A made and did have them. The Pave Penny was missing from it. Welcome to the Squawk!
                                      • Czonio
                                        Chris
                                        • 17
                                          Hey fellow Aeros member, Welcome to Hobby Squawk:Cool:. Good group here.Your full scale experience with the A-10 will be valuable to the detail oriented RC A-10 builders here. Along with the Squawkers that have also flown the full scale bird as well.
                                          Tony
