  • Ronniehinesh
    • 21
    • Columbia Tn
    Mine were more like 1-2mm...
    1-2mm sounds more like it to me.. Thanks
    • Ronniehinesh
      • 21
      • Columbia Tn
      I'm working on making decals for the bombs, missiles and other under wing pods. On the Sniper Targeting Pod at the rear there is a warning: RF Burn Hazard Remain at least 14 foot???. I can not read the last part of the statement. Does anyone know or have a picture of the pod. I have searched the web extensively and have found a lot of photos, but non give me a clear view of this warning. Any information on any of the under wing lettering would be greatly appreciated. My OCD kills me when I start detailing a plane.:Silly:
      • wvrailfan
        • Sep 2013
        • 682
        • West Virginia
        Check post 235 of this thread.
        • Ronniehinesh
          • 21
          • Columbia Tn
          I've got the lettering done from post #235. I've found all the lettering except for the warning at the rear of the sniper pod. Does anyone have a clear picture of it or know what the warning says?
            I had found a few close-up pics of the pod, but could not make out all the details of the stencils, so I didn't bother with them.
            • Fast Eddie
              • Oct 2016
              • 119
              • So.Cal
              I just purchased and received the full body scale pilot from Jet Hangar Hobbies. I did not know the head comes separate from the body. So I thought I would try for the first time and have the pilots head swivel from a servo. I'll Y into Steering channel. never done this mod before and haven't seen this mod done yet on the 80mm A-10. I hope video plays as this is my first Video upload too. My A-10 arrives tomorrow. Ordered canopy early to tinker with until plane arrives. I'll post more after painting and attaching flexible oxygen hose.
                Originally posted by Fast Eddie
                https://youtu.be/8QmFahwRHbM
                Neat idea....love the creative element.
                  As for the rivets, I've seen posts where the person use a dowel sanded down to 5mm. I did this and tried it on the plane and they just looked big to me. I'm all about scale, I'm I being over critical. What size rivets are you guys doing on your A10's?
                  Hi Ronniehinesh, the real A-10 uses different rivets in different areas, so your "OCD" as you say may not be fully satiated here, haha. If we want to get technical, most but not all of the real A-10's fuselage forward of the main spar uses flush rivets. 5mm is way too thick for the effect we want --What we're doing on this model are just shallow depressions, that try to capture the overall effect of a rivet without actually replicating its real life shape (which is a flat circle with a small dot in the center, not merely a hole). Its really difficult in this scale in foam to model an actual flush rivet shape as shown below. The outer diameter is nearly flush, and the dot/hole in the center would be very tiny. Perhaps someone could create a specialized die/tool for the job, but then again, you're working against the surface tension of the foam... and besides who's inspecting rivet fidelity on this aircraft?! To thicken the challenge, much of the fuselage behind the wing uses rounded head rivets. See some references I photographed myself on a Black Snakes A-10, 658.
                  The wing root fairing shows the flatter flush rivets, and you can also see the round head rivets as they begin to dominate the rear fuse.
                  Click image for larger version  Name:	DSC04083.JPG Views:	1 Size:	23.1 KB ID:	83542
                  Note that the rear fuse has both kinds of rivets, flush and round head:
                  Click image for larger version  Name:	DSC04074.JPG Views:	1 Size:	33.6 KB ID:	83543
                  There are also visible seam lines of seam sealant. Even Mibos don't have that level of detail.
                  Click image for larger version  Name:	DSC04071.JPG Views:	1 Size:	89.7 KB ID:	83544
                  An easy "scale mod" is to add the joiner plate visible in this picture on the leading edge of the outer wing. I sliced straight into the foam and buried thin piece of scrap plastic. It's visible in several pictures of Regulus [Prime] that won the Scale Jet award in Arizona.
                  Click image for larger version  Name:	DSC04091.JPG Views:	1 Size:	97.5 KB ID:	83545
                  Remember, the point in all this is to have FUN!
                  Even the baby 64mm A-10 wants to get in on the action.
                    Steve.......You had to know it was the next step in the line of mods. ;)
                    • Ronniehinesh
                      • 21
                      • Columbia Tn
                      [QUOTE=Alpha.MotionRC;n83541]
                      Even the baby 64mm A-10 wants to get in on the action.[/QUOTEThanks for the information and pictures.
                      I have done flush and raised rivets on my sons FMS P47 with good success. Now that I have the photos I'm going to try a few techniques on a crashed A10 (bad landing and ground hog hole) and see what works best. I'll post some pictures of the mock up and see what you guys think.
                      • downwindleg
                        • 1279
                        • Friday Harbor, Washington
                        [QUOTE=Ronniehinesh;n83608]
                        Click image for larger version  Name:	DSC04098.jpg Views:	1 Size:	27.0 KB ID:	83565
                        You mean your Warthog got destroyed by ground hog? Wow, what are the chances? Was it Thursday February 2nd by any chance?LOL
                        Brad
                          In that case, Ronnie, I look forward to seeing what you come up with on the A-10 and I hope my pictures helped. I might have other ones of areas if you're particular about where which kind of rivet is used.
                          • Fast Eddie
                            • Oct 2016
                            • 119
                            • So.Cal
                            Started with the rivets, Long way to go. Trying to match location and spacing as best I can from online photos. I noticed that not all adjoining panels have rivets/screw heads on both sides of panel lines. Not trying to be too critical, but don't want it to look like stitches either.
                            Don't know if it's been mentioned with other hogs or I missed it, but the stock paint on mine is two tone, lighter contrast on bottom. Others the same?
                            • Ronniehinesh
                              • 21
                              • Columbia Tn
                              Alpha I'll take all the pictures you have.
                              • Ronniehinesh
                                • 21
                                • Columbia Tn
                                [QUOTE=downwindleg;n83620]
                                Brad
                                No it wasn't Feb 2nd lol. But ya a ground hog hole did a job on the front of the A10 from the canopy forward.
                                  Hello Ronnie,
                                  With Motions top of the industry reputation for customer support and service on their products I gotta ask WHY are you even futzin around with trying to repair a new part that you received damaged :Confused:
                                    I agree with OV-10, Ronnie, please call the Customer Service team at 224-633-9090 or better yet submit a Service Ticket online and attach pictures (they'll need to receive pictures in that system to properly document and authorize the warranty procedure for replacement or partial credit). That department's office hours just began a few minutes ago. They'll be more than happy to get you sorted out!
                                    This is a good time to remind everyone that for all product issues, especially on new/recent releases, please always contact our Customer Service team before anything else. That team tracks thousands of products in our system, and forums like this one aren't always monitored every day by those team members. We all value the data you provide to help us continually track, evaluate, respond, and improve!
                                    Thanks, everyone!
                                    • Ronniehinesh
                                      • 21
                                      • Columbia Tn
                                      At this time its a moot point. I have already put the 2 sections together. I didn't call or complain about it simple due to the fact its foam and sometimes things just happens. My son has a fly-in this weekend and I needed to get the plane ready and didn't have the time to wait for a decision on if it was my fault the item was damaged or it was the shipper or just a issue with the part. As I rarely disclose where I get the planes my son flies there will be no negative toward who it was purchased. I do realize that motion is the only one that sells the plane but I will not give negative press to anyone. The decision to keep and use the part was mine. I will remove the posts and the pictures. Thank you all for your input on the modification and pictures.
                                      • TomPatton
                                        XNitroJunkie
                                        • 279
                                        • Elida Ohio
                                        Originally posted by t33jetman
                                        I must say, this is the cheapest mode, but it does dress up the plane alot.
                                        I used a shish kebab skewer sanded down and just pushed in on the foam lightly. Click image for larger version Name:	Screenshot_2017-06-27-05-49-02.png Views:	1 Size:	70.4 KB ID:	83256Click image for larger version Name:	20170624_143544.jpg Views:	1 Size:	48.1 KB ID:	83257
                                        Looks good...
                                        Thanks for riveting the ladder door shut, lol, now I don't feel so bad, I did the same thing...
                                          Hey, a little foam filler would take care of that.
