The stock CG is pretty nose heavy (the lines molded into the fuse). I'm fairly certain that unless you have a "unicorn" of a plane Marktur that any 6S pack you shove in it as far back as you can physically manage you'll be fine w/the CG unless you carve foam or are adding significant tail weight.
I've flown it at 140mm and I'd like to get it a little further back (albeit I'm using a gyro). I'm going for a neutral CG if I can manage it without adding too much more weight. I think it'll help with its performance.
