  • pmisuinas
    • 35
    Bomb Bay doors--part 2...
    First door attempt had way too much drag and binding--but it did what a prototype is supposed to do, identify areas needing changing.
    So I did some thinking on how to reduce drag and came up with following, in the order of most drag reduction first:
    1. Decrease size of bay doors 1/16". Doors are now 1/8" smaller than opening.
    2. Decrease size of pins. The reduction is small, but turns out every little bit helps.
    3. Pre-flex the door. Folding it back and forth on itself at each corrugation really increased flexibility.
    4. Standardize pin installation so all at same location with respect to corrugation.
    All these added up to a door that easily slides on the track and can easily be handled by a servo. So now need to finish the other three doors and start working on torque rod/door connectors. Pics tell the story...Pete M
      • 7415
      Looks great Dave, as a matter of interest, has anyone thought of opening the waist gunner positions and adding some detail there??
        • Nov 2013
        • 2783
        • Cody, WY
        Yes, I may very well revisit that area someday. These hatches opened inward, hinged at the top, and the bottoms were secured in the ceiling. I would hinge them like that and maybe a spring and magnet to open and close them. Or, maybe just have them open and a gunner at each side with a full .50 cal machine gun. A plane like this is so fun because of all the mods you can do on it. I am enjoying seeing all the great creativity and imagination from our group!
        • MANFRED
          Any Warbird, any time
          • 299
          • San Diego, Ca
          Tired Iron, how much did the Shapeways detail parts end up costing you?
            I didn't do them all, go to the link I posted and you can see the cost of each part.
            • whstlngdeath
              • 2
              • Catoosa, Oklahoma
              Hello all,
              I'm new to this forum, and just got my Lib before Christmas. Very impressive. I noticed that the upgraded sprung main gear struts are already sold out! Does anyone have any particular flight performance to report? Any peculiarities such as needing any flight control mixes or other issues relating to flight? I was just wondering if adding flight stabilization or gyro is needed. Also, does it tend to balance close to the given CG if we stay within the recommended battery sizes? Happy New Year everyone!
              Jesse
              • borntoolate
                Bomber Bob
                • Mar 2013
                • 424
                • California
                Originally posted by whstlngdeath
                Hello all,
                Jesse
                Welcome to Hobby Squawk, Jesse.
                Don't worry about the "out of stock" struts. They have not arrived, or been loaded on the web page yet. They are expected soon.
                Bob
                • donnie
                  • Mar 2014
                  • 12
                  • montgemy tx.
                  I too am a Newbie here. Have R/C experience though. Not in my hands yet as the O.D. one is still B.O. . Soon I hope. Currently do have an F7 Tigercat. It's not the one from Motion though it's from a European company [JR]. Airframe, fuse and nacelles fiberglass, wing outer panels foam with 1/32 balsa sheeting. See is an outstanding flier. Apologies for the O.T. chatter . Excited about incoming. donnie
                    • 7415
                    Welcome to the Squawk Donnie!!
                    Nothing wrong with excitement! It's all over the place on this Forum.
                    • jwellsy
                      • 2
                      Any tips on 3D printer settings for these parts?
                      I'd mainly like to hear what size nozzle tip and layer height is needed to get good results. I've got an original Prusa i3 mk2s printer and several nozzle sizes. I've printed 4 different 3DLabPrint planes (thin wall printing). So I'm sure my printer is capable of some pretty fine printing. I'd like get feel for what's been tried so far.
                      • ruffneckx1
                        • 112
                        To the guys familiar with 3d printing, what material would be the best compromise between showing detail and overall cost ?
                        Woody
                        • jwellsy
                          • 2
                          What do you mean by overall cost? These parts are very light weight and won't use much filament making them. So the type of filament doesn't make hardly any difference in the value of filament used.
                          Most filaments cost between $15 and $50 per kilogram. These parts will only use a few grams out of a kilogram roll. So cost only becomes a concern in the initial purchase of the full roll. These parts probably won't use 10% of a roll. So for this example the material cost would be from $1.50 - $5.00. Plus, you wind up with an almost full roll leftover for other prints.
                          BTW, I get most of mt filaments when they are on sale for under $10 a roll.
                            • 8826
                            I wasn't going to do this till spring but our dollar has been rising and it's likely to not get much better so I pulled the pin on the one they had in stock. It may be a slow build or it'll sit in the box till the snow goes away.
                            • dahawk
                              Augermeister
                              • Jun 2013
                              • 1006
                              • Keller,Texas
                              I've always been keenly interested in the historical part of the B-24 and the Bombardment Group and Squadrons as my Dad was a tech saarge with the 93rd Bombardment Group 409th Bomb sqaudron known as 'Ted's Traveling Circus.'
                              Here's the very last Newslatter published by the 2nd AF heritage league in 2012: http://www.heritageleague.org/files/...all-Winter.pdf
                              Some useful information and real experiences published in these newsletters that help capture the day and even some of the scale details. The Second Airforce embodies many Bombardment groups and squadrons.
                              • ruffneckx1
                                • 112
                                Regarding the 3d parts I need to clarify that I intend to have the parts commercially made as I don't have a 3d printer.
                                Was just wanting to know the best balance between cost and detail.
                                Woody
                                • Regatoni5
                                  • Nov 2017
                                  • 137
                                  • Lemoore, San Diego
                                  Thought I'd post some pictures of my PB4Y-1 WIP. I'm mainly focusing on paint and then will go into cockpit and interior details in the future. This is absolutely the first time i've ever used a paint gun so everything is very rough. I hope it comes out well. I cant wait to see the final product! Dont mind the messy garage and boxes. I just moved two weeks ago and still have a lot of things to do amongst these projects and family time. Huge shoutout to Spec450 for pushing me to do this.
                                  • S.W.Warbirds
                                    • Jan 2015
                                    • 121
                                    • West TX.
                                    Looking good can't wait to see it done ! Your airbrush kit looks like the one I just got a couple of weeks back and will be my first try at it ? :Confused:
                                      For a first attempt with a paint gun it looks really good. Well done! :Cool:
                                      • spec450
                                        low altitude record holder
                                        • 124
                                        • Hanford, Ca
                                        Its gunna look sweeeeeeet! Cant wait. It'll be a head turner for sure!
                                        Current Fleet: Flightline Tigercat, Flightline Bearcat, Eflite Corsair, ESM Skyraider, Pilot RC Yak-54 30%:corsair
                                        • Prowler901
                                          • 940
                                          • Gunnison, CO
                                          That's gonna be beautiful!:Cool:
