  • jetfool
    • Nov 2022
    • 1279
    • Crawfordsville, Indiana
    Dangerous Dan,
    First check with Davegee, I sent some extras for his Corsair back when I did mine. If not send me a pm with your address and I will make you some and mail them to you. Not a problem to make.
    Made my winter X-MAS plane decision..... ordered the FMS P-47, be here next week. Going to pick Davegee's brain for scale details this winter. Poor Dave! LOL
    Best Regards, Rex
      • 7333
      Ah he loves it! You'll love the P 47 too, I've known many people including OV 10, Ryan Ramsay and DaveGee that rave about them. If you dig through the archives, Ov10 (Warbird Charlie) replaced the 6s system with a 4s system and a bigger prop and, believe it or not, a sizable performance boost as well. I saw him fly it at Muncie a few years back and it was impressive. It was also the survivor of the great 'Collision' when Ryan and Charlie tried to make one bird out of two!
      Ryan lost and the motor and ESC from the wreck now reside in my FMS P 40.
      I believe Dave is running the FMS 1700 mm Corsair prop on his P47's and it looks much more scale, but let him tell you
      I'll check with him about the pieces, we're going to, hopefully, get together this week.
      (Dangerous Dan)
      • jetfool
        • Nov 2022
        • 1279
        Grossman56,
        Ah Muncie, I'm just 1 1/2 hr drive from me and attend many scale events throughout the summer, Finishing a BUSA 1/4 sc N-17 for next year. Fantastic facility and wide-open flying space.
        Ordered the V 3 scale prop with purchase and have Robart wheels. Trying to decide on what profile to model, thinking of R Johnsons 'LUCKY'
          • 7333
          Sounds good! It's one I've eyeballed as well. I've had Bob Johnsons book since I was a kid, don't know how many times I've read it, it's definitely a bird/pilot worth honoring.
          Good news, the gear folded perfectly, it was just a matter of placing the wheel on the axle so it would hit the gear well dead center. Started an initial coat of very diluted umber and one side of the fuse. Painted the lines and then used a paper towel on my finger to pull the paint down. Looks great for the first layer.
          The umber shows its green against the blue of the fuse which is just way to cool!
          The darker spots under the cockpit for instance, were with a less diluted mix, which, I admit was a complete fluke, the paint started settling on the bottom of the container and I reliaded the brush from the bottom, good fluke though, sometimes those accidents turn out to be the coolest thing.
          HAPPY THANKSGIVING TO ALL
          (Dangerous Dan)
            • 7333
            BTW, Muncie, ah airplane heaven!! I could swear my planes were jumping for joy when we arrived!
              • Nov 2013
              • 2662
              • Cody, WY
              Originally posted by jetfool
              Grossman56,
              Johnson's plane Lucky would be a good one. Pretty basic paint scheme for that earlier period of the war. The one distinguishing thing if you want to go full scale, is that it had a Curtiss Electric Prop with the cuffs, and a longer more bullet shaped spinner. I have a couple of planes I have done in this manner, worked out ok after a lot of trial and error. The printed bullet shaped dome I had someone design and make for me with the threads inside so it can screw onto the prop shaft. I still don't know how to do that, but I can easily print some up if I have the STL file for them. With the Corsair V3 prop, all the security for keeping the prop from flying off the aircraft is borne by a hex nut that securely holds the prop on, no matter what kind of spinner you put on the end.
              If you decide you like a plane that had the Hamilton Standard prop with the more blunt spinner on it, you don't have to do anything, that's how easy it is. If the accuracy of a Curtiss Electric propeller isn't a big deal for you, you can just put a Ham Stan prop and spinner on your airplane. Most would never know the difference.
              Cheers
              Davegee
                • 7333
                Hi Dave:
                Let me know when you can head over.
                Dan
                • jetfool
                  • Nov 2022
                  • 1279
                  Davegee,
                  Good info. Probably fly with stock prop to get everything dialed in, then go to the bigger prop. Would like a Curtiss prop so will look around for something similar. Yes, a basic OD but will need advice on shading the faded surfaces which in pictures occurred. Another good profile would be Silver Lady (did this scheme om my Yellow P-47) but leaning more to Lucky. Plan to pick your Brain on this.
                  Dan,
                  Corsair is really coming alive. The Birdcage had a hard life in the SWP and the worst wreathing you apply only looks better if done in a subtle way. A 1600m B-26 dirtied up would be another one to attack Rabaul
                  Look at my Corsair cockpit posts and you will see I used Elbee's seat and cockpit parts. Required some foam surgery, not much, but really adds to the plane
                  I might start a re-paint/ weathering post when I start? Excitement is hitting my bones again to start this, but Keeper of the wallet says I have to wait till X-MAS to open. Think she might be the Grinch!
                  Instead of that Thanksgiving nap fellows, go work on your plane, Rex
                    • 7333
                    I wasn't happy with the placement of the upper color on the cowling, it should have extended down further to the cowling 'joiner' which in itself is in the wrong place, too high, it should line up with the rivet line just above the wing
                    Click image for larger version  Name:	vmf213-WRG-0016753.jpg Views:	0 Size:	115.9 KB ID:	415045 Click image for larger version  Name:	20241128_103121.jpg Views:	0 Size:	101.3 KB ID:	415046
                    So I mixed up some paint and lowered the paint line to the joiner, compromised I guess.
                    Click image for larger version  Name:	20241129_110538.jpg Views:	0 Size:	95.8 KB ID:	415047 I'm also attempting to duplicate the exhaust 'swirl' coming out of the cowling and doing a 90 degree turn downwards just before the leading edge. Meanwhile she's getting more combat dirty with the wheel hubs painted and the staining on the fuse. Can't go much further until the decals arrive, they're on their way though.
                    Click image for larger version  Name:	20241129_110544.jpg Views:	0 Size:	55.4 KB ID:	415048 Click image for larger version  Name:	20241129_110622.jpg Views:	0 Size:	40.9 KB ID:	415050
                    Click image for larger version  Name:	20241129_110556.jpg Views:	0 Size:	84.8 KB ID:	415049
                      • 4820
                      In my 'World Order of Meritocracy' that is outstanding. Best, LB
                      • jetfool
                        • Nov 2022
                        • 1279
                        Fantastic work Dan! Wheels look great, hope you install Elbee"s strut covers and modified tail wheel retract, they really add character. I will use Elbee's bomb drop attachment and bomb on mine for some strafing flights. Not used on my version of Ken Walsh but will look cool flying.
                        Onward and Upward, Dan Rex
                          • Nov 2013
                          • 2662
                          • Cody, WY
                          Hey Danger Dan:
                          I like your weathering patterns on the fuse! I find with these models, once you have them for awhile, they start taking on a weathered patina of their own. Like fine wine, they get better over time, unless you crash them, of course!
                          I have your cockpit parts printed and in a bag so if we can get together sometime, I'll give them to you.
                          Cheers
                          Davegee
                          • jetfool
                            • Nov 2022
                            • 1279
                            Davegee,
                            I think it would be real nice if you painted/weathered the cockpit parts for Dan. Then all he has to do is install. HA<HA
                            Rex
                              • Nov 2013
                              • 2662
                              • Cody, WY
                              Davegee,
                              Rex
                              I can do that, but first he would have to verify that these parts do fit properly. I had to do some adjusting to make them fit in my bubbletop cockpit.
                              Dave
                                • 7333
                                drop in any time Dave. I'll PM my number in case you lost it.
                                (Dangerous Dan)
                                  • 7333
                                  Hey Dave, sorry, but she who exceeds my rank decided we were going to Billings today. Thanks for the parts, I took them right down stairs and they fit perfectly!
                                  Click image for larger version  Name:	20241130_161215.jpg Views:	0 Size:	52.1 KB ID:	415131 Click image for larger version  Name:	20241130_161241.jpg Views:	0 Size:	49.0 KB ID:	415132 Click image for larger version  Name:	20241130_161038.jpg Views:	0 Size:	89.1 KB ID:	415133
                                  The decals also came today
                                  Click image for larger version  Name:	20241130_163407.jpg Views:	0 Size:	103.9 KB ID:	415134 Click image for larger version  Name:	20241130_163626.jpg Views:	0 Size:	89.7 KB ID:	415135
                                  She's starting to take shape!
                                  (Dangerous Dan)
                                  • jetfool
                                    • Nov 2022
                                    • 1279
                                    Grossman56,
                                    I'd say it's starting to look "DANGEROUS". You're doing a fantastic job!
                                    Best Regards, Rex
                                      • 4820
                                      Now that's what I am talkin' about.
                                      Great work, Danger.
                                      She's really taking shape, love the livery markings.
                                      Best, Elbee
                                        • 7333
                                        Thanks Elbee!
                                        I had a good visit with DaveGee today and we went over some of the finer points. Since then, I've added the bullet proof windshield and the reflector piece of the gunsight as well as got all the 3D printed parts painted and the decals on, WHEW! Click image for larger version
ID:	415209 Click image for larger version
ID:	415210 Click image for larger version
ID:	415211 Click image for larger version
                                        Now I have a little bit of clean up around the sight and the base of the B.P. glass, Instrument panel turned out great, I used a small syringe to fill in the instrument 'glass' with Spar Varathane, turned out great. That stuff is so handy, I used it in the eye and mouth areas of the pilot as well as the top of the gunsight.
                                        (Dangerous Dan)
                                        • jetfool
                                          • Nov 2022
                                          • 1279
                                          Grossman56,
                                          WOW! That is looking very nice
                                          Rex
