    • 8795
    Originally posted by sfmadmax
    Yes I have the Admiral RX with Gyro. I think I may have explained it poorly. My Admiral is in Comb A, Default... The Gyro is always on I think and I have a panic button ("Recovery") ... The Recovery switch is my bind button, "Button I" Just like in the quickstart video, I set my Mix, to use the Gear Channel + I Button, which activates my Recovery. I don't think doing this affects my gears at all, the recovery feature i simply programmed to the gear channel. So I was wondering if I put a Y connector on the gear channel and simply pressed the button, if it would actuate the servo. I don't know if that would work, just a thought.
    Give it try. Just remember the steps you took so you can reverse it all if it doesn't work.
      • 2696
      Originally posted by MrSmoothie
      So, since it's my birthday and the weather was perfect, I decided to skip the office and take my Corsair out for some fun. First flight was beautiful and I let my flying buddy take the controls for a few minutes. Time to land, I made an absolutely perfect full-flaps landing -- perfect, that is, except for the fact that I "landed" three feet above the ground. The stall was a thing of beauty -- it just dropped evenly, pancaking into the ground. Both retracts folded back. To our amazement, the airframe is virtually undamaged -- just a few scuffs to touch up, but nothing broken or cracked. Both retracts are fractured and will be replaced. Two of three prop blades broken, and one of the four gear doors snapped in half.
      Unfortunately the retracts (w/o struts) are out of stock, so I had to order complete units (about twice the cost).
      The bad news: The motor was very loose, and I feared the plastic mount was broken. Upon taking it all apart, I found that the plastic mount was fine. The 4mm aluminum motor X-mount, however, was fractured badly at all four motor screw positions and bent out of shape! Those motor screws were a royal pain to remove, even with application of heat to loosen the thread lock.
      The more bad news: The X-mount is out of stock at MRC! I took a chance and ordered the last-in-stock X-mount for the 1600mm Spitfire, but it has a different part number and must be different somehow.
      By any chance does anybody have a spare FlightLine 1600mm F4U-1A/D Corsair Motor X Mount SKU: MO1505522 they are willing to part with? It may be that that Motion has not yet gotten any of these in stock, being a new part.
      Sorry to hear that Mr. Smoothie, and if it's any consolation (which I know it's not), been there, done that and I'm sure we're not the only ones. Did it with my first Corsair, the flying FMS Brick 1400mm. Got tired of coming in a little too hot, making what I thought was a spot on 2 wheel landing, and having the thing decide to take an immediate left (maybe the pilot saw a naked cheerleader on the side of the runway), and proceeding to nose over in the grass and damage not only the prop but the rudder (not to mention my ego). Then tried a slow, full flap landing (at 1/4 throttle no less for that dog), and she stalled about 2 feet up and dropped straight down on the retracts, with virtually the same result as yours.
      I may not be getting any better at landing, but I'm sure getting great practice at repairing.:Smoking::corsair
      • RichJ53
        • Nov 2018
        • 342
        • Southern Oregon
        I'm baring my soul for you guys who haven't flown your's yet in hopes that you will catch any problems before you attempt your maiden -- this is way too nice (and expensive) of a model to crash over something stupid.
        ASK ME HOW I KNOW!!!!
        Hey MS
        Sorry to read about your Corsair..... Happy Bday
        The parts you needed were in stock a few weeks ago, so they will most likely get some more in stock soon. Hope you are able to get everything you need soon
        edit: the Spitfire motor assembly has all the parts you need less the F4U screws... lot more cost but this would get you going again faster
        Rich
        • MrSmoothie
          Scale Warbirds & EDF's!
          • Oct 2017
          • 177
          • Gainesville, FL
          Man, I’m sorry to hear that. I’d recommend flattening out the old motor mount and use it as a pattern. This is SOP for full size aircraft repair.
          The stock motor mounts are typically .120 thousands, 2024 “O” aluminum, the softest variety out there as it’s not heat treated.
          It’s also easy to work and will deform and fail as your’s did without breaking the airframe.
          I’d recommend trying to get some sheet “O” aluminum and just fab your own if the Spitfire mount will not fit or can’t be modified.
          2024-T3 or T6 is hardened and is what aircraft skin and parts is fabricated from. Should you use that, the plastic part molded into the fuselage will fail instead as the mount will not give under load.
          Or...
          Fabricate one from model aircraft grade plywood. That will indeed work to.
          Or...
          Tell your Dad an AD note was issued on his motor mount and will take a month of NDI work to verify it’s integrity, with extensive testing in your airframe.
          Thanks O-T for that useful aluminum info -- I will look into this -- it had crossed my mind to try and make a new mount, but know nothing about the various grades. The original mount is in small pieces -- both from the original damage and me pulling off the remnants to gain access to the screws, but it wouldn't e any problem to draft a new pattern. I'm telling you, Flightline used some serious thread lock here, which barely responded to soldering iron heat. Next time I'll use a small propane flame right on the screw head.
          I also think you're right that I could make one out of good quality ply, and it wouldn't even need to be "X" shaped. That may be the most expedient way to go, and I could always replace it when the factory part shows up at MRC.
          Haha -- I am "proud" to have a reputation in my club for doing really good, nearly invisible repairs -- unfortunately this is in direct proportion to, and the result of, my "stupid pilot tricks." I know guys that have the same model for years and nary a scratch--I strive to be "that guy"!
          • MrSmoothie
            • Oct 2017
            • 177
            • Gainesville, FL
            https://www.motionrc.com/products/fl...rushless-motor
            I ordered the very last in-stock Spitfire X-mount yesterday in hopes it would work with the different F4U motor. However it (the Spit X-mount) has a different part number, so I'm not holding my breath. I see there are a couple of Corsair motors still in stock, and I have to think they come with the X-mount, so I guess that would be the quick fix. I'm not adverse to "throwing money" at a solution and have done it more times than I like to admit. But I can't get too excited about buying a $55 motor to get the $3.50 mount...
            • Ole-Timer
              Warbird Enthusiast
              • Dec 2017
              • 344
              • New Brighton, PA
              The X shape provides cooling airflow through the motor so while you can make it less like an X, just be sure you don’t block airflow through the nose.
              • Grover54
                Going Weightless
                • Jan 2019
                • 319
                • Seattle Area (Redmond)
                Show and Tell......Just ran across these videos on Planes of Fame - War Birds - Pacific Theatre 2017 and 2018. The F4U and P38s are my FAVs but I'm really crazy about them all. Some of you may have already seen them but if not I hope you enjoy them as much as I did. Very well done.
                • theoldALFER
                  Taildragger Pilot
                  • Jun 2017
                  • 163
                  • Cape Coral, Florida
                  Yup, the CA (Krazy Glue) works GREAT on the instrument pgun sight :Cool:
                  ... now all I gotta do is wait for my thumb and index finger to “unglue”... :Confused:
                  :pop
                  • theoldALFER
                    Taildragger Pilot
                    • Jun 2017
                    • 163
                    Well that worked well...NOT :Angry:
                      • 8795
                      Did ya do the old "tongue on the frozen sign pole" trick? :Crying:
                      • theoldALFER
                        Taildragger Pilot
                        • Jun 2017
                        • 163
                        Nah... don’t get that cold down here in SW Florida ;)
                        • RichJ53
                          • Nov 2018
                          • 342
                          • Southern Oregon
                          Agreed and glad you were able to get the last X mount. The Spitfire and Corsair uses the same motor and the mount visually looks the same. The part numbers are different because the mounting screws are not the same.
                          Keep us posted
                          Rich
                            • 8795
                            You got walk in freezers, don't ya? I once glued a sweaty hand on a metal shelf in a walk in freezer once. In your case, you'd be left with "double skin" on one finger and none on the other. Big OWIE!
                            • sfmadmax
                              • Jan 2019
                              • 105
                              • New Hampshire
                              Yea I saw your pictures and cursed at you :P , Here it snowed all night last night and it's cold. lol
                              • TonyGagJr
                                • 36
                                Do we have to use the blue box on the Corsair? On my other FLRC planes I remove them, don’t really trust them.
                                • Beeg
                                  • 1335
                                  • Texas
                                  No, you don't have to use the box but it sure makes it easy. You will need at least four Y connectors and a 7 channel receiver or a 12 channel receiver if you want to put every servo on it's on channel. You will also need to program your radio to operate the gear doors in sequence with the gear.
                                  • Grover54
                                    Going Weightless
                                    • Jan 2019
                                    • 319
                                    I've read where it's better to trust the blue box than rely on a bunch of "Y" connectors but hey - that's just me. :Cool:
                                    • Grover54
                                      Going Weightless
                                      • Jan 2019
                                      • 319
                                      Here in the Northwest (Seattle Area) we've been having a very strange light appear in the sky the last several days so the weekend looks great for my Maiden. Excited to say the least so I'll post pictures unless a trash bag is involved! LOLLOLLOL
                                      • sfmadmax
                                        • Jan 2019
                                        • 105
                                        • New Hampshire
                                        The Blue BOX is a set of software instructions on a chip ( SOC ) or integrated circuit. it's not going to break unless you poke/prod at it with forceps. Sure an electronic component can possibly fail, however with the tech these days, it's usually unlikely.
                                        I would rather "trust" the blue box than a harness of Y connectors that can possibly become undone. The likely hood of the Y connectors becoming undone mid flight??? (Probably the same as an electronic component on the blue box failing)
                                        It probably comes down to, preference at that point, IMO the blue box wins, since as a previous poster says, i knocks down your radio requirement from 12 -> 6 channels.
                                        • sfmadmax
                                          • Jan 2019
                                          • 105
                                          • New Hampshire
                                          Good Luck Sir, I am counting the days until the good weather hits so I can get mine airborne, Every night before bed I power mine up and do a pre-flight check.. LOL.... :)
                                          Post some pics!
