  • Dirty Dee
    • 768
    • Northern Illinois
    Originally posted by mtnbiker63
    Dirty Dee, are your OV10 mods on Thingiverse?
    Currently print to order, will host on cults3d for a small fee soon.
    • wrangler1
      • Feb 2019
      • 116
      • Dominican Republic
      Originally posted by Kangi1954
      Where did you get the 105 degree retract? Thanks for the updates.
      On Amazon.
      • TBolt
        Rekitting kits at an extraordinary rate
        • Aug 2017
        • 50
        • Chandler AZ
        no longer on Amazon either :(
        • sam51401
          • 368
          • Sellersburg IN
          With Horizon being the primary supplier and it being listed as discontinued, I didnt hold much hope to find one. Wish there was enough interest to restock those but I dont think one plane will support that.
          That's why I opted for a still supplied option.
          Will like to see the install with strut to see how the 105 degrees works out.
          • Kangi1954
            • Jun 2019
            • 63
            • Palm Coast, FL
            Here's a link to someone who says they have them: http://stores.aeromicro.com/e-flite-...-retract-unit/
            • wrangler1
              • Feb 2019
              • 116
              I just received some goodies,....now to re-start the assembly while waiting for the right replacement wing from MRC. By the way i have to say that on all my years in this hobby (30) this company has an exceptional post sale support, they solved in a fast way every situation or question that i had.
              MRC...Keep the good work !!!
              • wrangler1
                • Feb 2019
                • 116
                One thing that i like to point is that the T45 struts on the picture feels very soft for a Balsa plane like this, maybe i'm wrong.....i will test it and then we will see. Also i'm thinking on how am i going g to attach the lights i bought to the landing struts.? 🤔
                • Kangi1954
                  • Jun 2019
                  • 63
                  • Palm Coast, FL
                  The full size aircraft has the landing light in the nose of the fuselage.
                  • wrangler1
                    • Feb 2019
                    • 116
                    Thank you very much, i intend to go a little further and put some lights in the mains too !!
                    • wrangler1
                      • Feb 2019
                      • 116
                      I tried the T-45 struts but i feel they are to soft for this plane, the same happens to the Yak30 nose gear, so i decided to go with the ines that comes with the plane, they are very sturdy, but now i found a situation were the nose strut shaft is a little wider than the hole on the Eflite 105 degree nose retract. So i think i will need to wide that hole with my dremel.
                      • wrangler1
                        • Feb 2019
                        • 116
                        The mains fit perfectly with the EFLITE retracts !!!
                        • wrangler1
                          • Feb 2019
                          • 116
                          I just expand the hole on the EFLITE nose Retract with a 5mm bit and now the strut fit perfectly.
                          • wrangler1
                            • Feb 2019
                            • 116
                            Finish with the gears assembly.
                            • TBolt
                              • Aug 2017
                              • 50
                              • Chandler AZ
                              wrangler1, thanks for the update.
                              would the 90 degree nose reract work with the provided nose gear?
                              • wrangler1
                                • Feb 2019
                                • 116
                                I assumes it will, the thing is that the nose retract needs to have a 5mm hole for the shaft, but since i dont have a 90 degrees nose retract, mine is a 105. i need to see how hide the nose wheel gets.
                                • Nottoday
                                  • May 2019
                                  • 30
                                  I have 90 degree and rear 2mm underlaid.
                                  • Kangi1954
                                    • Jun 2019
                                    • 63
                                    • Palm Coast, FL
                                    The specs on Horizon for the 90 degree nose gear don't list strut diameter, however, the specs for the discontinued 60-120 90 degree tricycle package says 4mm nose strut amd 5mm main struts. So we'll probably have to drill out the nose gear hole.
                                    • wrangler1
                                      • Feb 2019
                                      • 116
                                      That's what i did yesterday !! 😉
                                      • walkerm45
                                        • Aug 2014
                                        • 74
                                        • Tucson, Arizona, USA
                                        Has anyone flown there Profly Bronco? Need some video footage, and feedback.
                                        • walkerm45
                                          • Aug 2014
                                          • 74
                                          Has anyone come up with some alternatives to the questionable front nose gear, and steering mechanism, or are we all waiting for Motions retracts, and answers......
