Thanks GBL.. for the video. I actually took a snap at the end and used as my desktop!!
How about some details on his setup if you can so we can start compiling what works and what doesnt. First question, i assume those are the Callie graphics for VMO-2? Same set im using as i grew up watching these in person. Camp Pendleton is where i started my RC hobby and on the same airfield that very plane was based.
I’m most interested in what nose gear retract he used and what mounting modifications, if any, were needed. If any of you guys have installed the Robart 105 degree retract, I'd also like to know (see) how that worked out. Please?
Looking at the Robart 105 retract that i have here i assume that will have the same travel as the eflite that i installed on my plane. So looking at that, i assume anyone that will decide to use it will have to do the same work that i did on my Nose retract wood base.
Photos belowComment
Hi, new guy here. To help out GBL who is an outstanding videographer of my Bronco, I'll post some specs of my OV-10 to answer some questions that were asked on this thread.
Motor - Rimfire 32 x 2
ESC - Talon 90 x 2
Props - APC 13 x 6.5E x 2 (one is reversed)
Spinners - DuBro 2.5 inch x 2
Batteries for motors - 4s 5000 x 2
Electronics battery - 2200 Life
Retracts - Eflite 90-120 90 degrees x 3
Servos - Hitec HS-225MG Mighty Mini x 8
Graphics - Callie Graphics 1/7 VMO-2
Flying weight, I don't really know because I have not weight it yet. I get six minutes of flight time and landing around 50%. Mixed throttle, to include high speed passes. Most of the flight are done at 1/2 to 3/4 throttle. Since the video was taken, I got brave and have been doing basic aerobatics that this aircraft would do IRL. More than enough power with this set up. She takes off from grass with no problems. Very stable flyer with the counter rotating props. Pilots and exhaust will be added as soon as they arrived to add more scale to this a/c. The only mod I really had to do was extending the standoff for the motors. The retracts were all dropped in with no issues and the supplied struts slipped on with no modifications.
Yep. it looks like the Robart will require the angled shims as well. I just ordered the X Wave retract from Motion, so hopefully that solves the problem.Looking at the Robart 105 retract that i have here i assume that will have the same travel as the eflite that i installed on my plane. So looking at that, i assume anyone that will decide to use it will have to do the same work that i did on my Nose retract wood base.
Photos belowComment
Welcome to the forum! Thanks for sharing your set-ups. You were able to install the nose retract without modifications to the mounting surface? No shims or change to mounting angle? Does the front wheel retract fully into the wheel well?Hi, new guy here. To help out GBL who is an outstanding videographer of my Bronco, I'll post some specs of my OV-10 to answer some questions that were asked on this thread.
ESC - Talon 90 x 2
RickComment
Great. That's the same power set up I'm planning on using.
Mike\"When Inverted Down Is Up And Up Is Expensive\"Comment
Great Video , thanks !!!Comment
Good to have TLAR and glyrenden onboard and to share their setups on this Bronc. I have my wing and fuse center recovered and doing flight surfaces next. Im toying with some ideas on making some closer to scale functional main struts and a semi opening rear fuse fairing but i rather get this flying and go back later for that. I think it was wrangler that posted about battery sizes and the room under the cockpit tub may not allow 6s 6000ma batteries. Any further thoughts or pics on that as most of mine are 6s 5000 on up for my FW EDF's. :rolling_eyes:Comment
