    • 8772
    Doing some quick calculations, a plane like this P-38 spins props about 10 revs per second (~1/2 throttle). A typical frame rate of 30 for HD video would put an image of a couple of prop blades per frame. Add to that, changing throttle input and it's not going happen. NOT getting the sushi effect is very difficult unless you have a camera that can video at hundreds of frames per second - that's about the perception rate of the human eye. At 30 frames, the human eye can distinguish too many images in a second and that translates into a skewed blur (ie, sushi effect). You need a lot of blurring to be able to see through a prop without seeing the prop.
    • downwindleg
      • 1279
      • Friday Harbor, Washington
      Thanks for the feedback xviper2. I've done a little research myself on the subject. The "sushi effect" is otherwise known as the stroboscopic effect or wagon wheel effect where the the spokes or prop blades appear to be going backwards. Long story short if using a gopro hero 3 for instance set the resolution at 1080, Frame rate at 24 fps, field of view medium, spot meter on, protune off. With a slower frame rate, "just like in the movies", the prop blades are blurred slightly and you avoid the sushi but still get the sense of movement. If someone out there tries this on a model, I'd like to know if it works, Thanks Brad
      • mr.frankenjet
        Eat, sleep, FLY FLY FLY !
        • 448
        • Virginia, USA
        great memorial day flight yesterday, getting her dialed in
        rc flyin addict
        • Delizar
          Perpetual Noob
          • 88
          • SoCal
          Nice use of nearly every inch of that fairly short runway.
          Yield to temptation. It may not pass your way again.
          R. A. Heinlein
          • mr.frankenjet
            • 448
            • Virginia, USA
            tks, we added 35" this year so now roughly 90" of pavement or so. With grass on both sides it's enough to get the job done.
            rc flyin addict
              • 7340
              You mean feet? not inches right?
              Anyway, great flight and a nice field t fly from, she looked like she handles the grass pretty well.
              • mr.frankenjet
                • 448
                • Virginia, USA
                Thanks Grossman- yea feet, he he, got to get my glasses out when I type :o)) We have been working on the grass and the runway, the planned improvements help to seal the deal on getting the P-38. Just one more reason to get one, sure glad she flys so well, great plane and a thing of beauty for sure .
                rc flyin addict
                • MikeT
                  Here......Hold my beer.
                  • 1060
                  Got to maiden my P-38 this morning. Pleasantly surprise great air-frame. Our Scale Fly in is tomorrow and I'm looking forward to putting it thru her paces.
                  Mike
                  • Flygirl
                    • 969
                    • Glen Burnie, Maryland USA
                    Mike
                    Congrats Mike!
                    Lauren
                    • Lon
                      • Jul 2014
                      • 1201
                      • Miles, Iowa
                      Mike
                      Woo Hoo!!! Glad to hear you got the maiden in this morning.
                      Lon
                        • 8211
                        Nice Mike!
                        • mz34334
                          • 13
                          • Ocala Fl
                          Hi Guys. My maiden went OK, but I'm not happy with my nose gear mod. So, a question for all: Has anyone done a FW p51 nose gear mod using a 2 1/2 " wheel, and after a flight or two the gear door actually closes all the way? Thanks, Mike
                            That's what I did and mine closes all the way. I have a build thread on it.
                              • 8772
                              Topic: Retract jamming and not deploying for landing. Possible explanation and fix.
                              Lately, I've been reading (not here) about people who have had one or more retracts jamming when in the UP position and then not coming down when getting ready to land. This necessitates a belly landing, which is accompanied by this and that being broken. Then a lot of yelling and screaming about what poor quality components are in this plane and running to the vendor for warranty replacement for the retract and everything that got broken in the process.
                              The following is one possible explanation for what's going on and what can be done to resolve it. It may or may not apply to your plane but it certainly did to mine and doing what's in the video, all retracts have worked every time.
                              When a retract jams up and won't come down, one way to get it down so you can work on it is to grab to tire/strut assembly, while bracing the retract body, and pulling up on the strut so unbend it a bit. Then push down on the strut near the retract base to help it go just a little bit further so the next deployment cycle can begin. Once up, the video should explain the rest. The same principle can apply to the front but it has one additional factor that needs to be addressed.
                              Failing this, you've got a defective or busted retract.
                              • MikeT
                                • 1060
                                Originally posted by Flygirl
                                Congrats Mike!
                                Thanks she flies just awesome. I had 3 really hard core gas war bird flyers have a go at the P-38 yesterday and every one was impressed with it. For them to be impressed is really something since not one of them has a electric no less foam war-bird.
                                Mike
                                • Flygirl
                                  • 969
                                  Really?? No one flies foamies or electric?
                                  Nice job Vipe on the vid!!!!
                                  Lauren
                                    • 8772
                                    Thanks, Flygirl.
                                    You would be amazed at how staunch some "old fogies" can be at certain flying clubs. There are always a small crowd of them who show their complete disdain for anything "new fangled". Unless it makes horrific noises, belches out smoke and covers the model with slime, it is not consider a "real" RC plane. If the club is small and old, I can easily see how somebody showing up with an electric foamie would be ridiculed as a rebel. Up until only 2 years ago, one of my clubs had never even seen a foamie fly on their field. Then some newcomers showed up with foamies (me raising hand) and suddenly, some of those old farts started to boast about their shiny new electric machines. That's when they start fighting among themselves. :angel:
                                      • 2817
                                      • Arlington, TX
                                      Yep, had experience with some of those types. You should have seen the disdain on their faces when I brought a scale electric heli to a field of gas-only fixed wing balsa planes.. However, I think most of them are starting to get the idea that electric is where it is at. A year ago, someone brought a sport cub to the field and insisted that some of the older gentlemen fly it. There are now 15 sport Cubs owned by club members..
                                      • Flygirl
                                        • 969
                                        Originally posted by xviper2
                                        Thanks, Flygirl.
                                        ROFL!!!!!!!!!!! I can imagine that argument! ;)
                                        Delta, you were REALLY out of your element! Heli AND electric! LOL!
                                        Lauren
                                        • farmflyer
                                          • Mar 2015
                                          • 1164
                                          • Quitaque Texas
                                          I bet it was the same way when the control line and free flight guys first saw a rc plane. I can hear it now "Son that ain't flying"
