Official Black Horse 2350mm Gilmore Red Lion
  • 406PIlot
    Well the engine came in today!!!
    Another question. Has anyone ever used the power box regulator switches before?
    Here is a link to the switch I was looking at.
  • 406PIlot
    RC ML looks dang good!!! Can't wait to hear about or maybe see some video of the maiden!!!
    Cheers to a job well done!
  • RCBobP
    Originally posted by RC ML
    Finished
    That's a real sharp looking bird there. Looks like you glued the blisters on? Looks pretty good!
  • DaleD
    Finished
    GREAT Going!!!!
    Now get her maidened and let us hear all about the thrill. Looking forward to flight report.
    DaleD
  • RC ML
    Finished
  • 406PIlot
    Can anyone tell me what the size of their wing tube is? The manual says it should be 890mm or 35inches. The wing tube I received in my kit is only about 760mm or 30 inches.
    I contacted motion about this and they say it's no problem. But a short wing tube doesn't really inspire confidence. So if anyone can tell me the length of what they received that would be great. I'm curious does yours match the manual described length / size or is it shorter or longer etc...
    Thanks.
  • RCBobP
    Excellent, thanks!
  • DaleD
    Originally posted by RCBobP
    Understood, but who makes/sells metal arms that are small enough for what is recommended for the Gilmore? I've not seen any servo arms that short other than the plastic ones. What's everyone using for this plane?
    Take a look at whats on offer here https://www.rc-race-shop.de/en/team-...5t-16mm-orange or here https://www.hobby-china.com/miracle-...ec-servos.html
    This should also work https://www.tcscrawlers.com/Robitron...y-p/r17020.htm
    DaleD
  • RCBobP
  • 406PIlot
    A servo with metal gear output and then an arm with plastic splines makes for a good chance of stripping the splines in the arm. I use aluminum arms on any servo with a metal output shaft. This prevents slippage & stripping out the splines on the arm from the torque / power of the servo.
  • RCBobP
    Originally posted by 406PIlot
    I wouldn't trust a plastic servo arm on a plane this size. But maybe that's just me. Good servo & bad servo arm just seems like a waist and potential point of failure. Everyone should build to the way they want or how they think is right. I'm just tossing in my 2 cents.
    What servo arm are you using? I have the Dubro heavy duty servo arms. That should be sufficient, since I'm not planning on any extreme aerobatics. The question is length. Instructions call for 16 mm between center of spindle and the servo arm hole to be used. The arms I have I can either go 13 mm or 19 mm.
    What's been everyone else's experience here?
  • RCBobP
    Originally posted by djmoose
    wow, you're stuck with that little 4 way arm? 10mm is super small! The 8411 doesn't come with any other arms?
    Either way, shouldn't be tough to find some arms: https://www.motionrc.com/collections...-8-pack-dub674
    JR has plenty of arms for their servos. It’s just another delay having to wait for replacements. 😆
  • 406PIlot
  • djmoose
    KNow my hold up is finding the right servo arms. I bought JR 8411 servos, but they come with arms that are only 10 mm at the longest. I have longer servo arms, but they won't fit the JR spindle.
  • RCBobP
    Keep looking! There were several items I thought were missing, but I dug deeper into the box, or looked in some of the other boxes and found them. I can't say for sure that your delivery was complete, I only know that I had to keep "taking inventory" and looking to be sure I had what I needed. Now my hold up is finding the right servo arms. I bought JR 8411 servos, but they come with arms that are only 10 mm at the longest. I have longer servo arms, but they won't fit the JR spindle.
  • 406PIlot
    [QUOTE=RCBobP;n306168]Ailerons now installed. The pre-drilled holes were nice, but maybe a scoche too wide. Really needed to coat the pockets with epoxy, and be sure to twist the hinges to get an even coating. Hopefully I did a good job. Thanks again to twowingtj for posting that video.
    I noticed the same thing about the pre-dilled holes on the ailerons! I actually got my ailerons / hinges epoxied in last night. Did you check to make sure you had all the hardware? Mine was missing the screws for the servo covers. Not a huge deal I have some that will work with no issues, but I was a little disappointed they just flat out forgot to add those in.
    It's nice to see all of these Gilmores going together! Thanks for sharing your progress guys.
  • RCBobP
    Ailerons now installed. The pre-drilled holes were nice, but maybe a scoche too wide. Really needed to coat the pockets with epoxy, and be sure to twist the hinges to get an even coating. Hopefully I did a good job. Thanks again to twowingtj for posting that video.Click image for larger version
    Glad that the info has been helpful.
  • djmoose
    Great info! I'll say this again, your info on this plane is the main reason I pulled the trigger. Thank You!
    djmoose My model came with about a 6" x 10" piece of extra covering material. It allowed me to experiment with the covering on both sheeted and open framing. I set up a small test platform. I used a good covering iron and an IR thermometer to determine the best temp range.
    That's how I found out that too much heat, or heated for too long goes from good to ugly really fast LOL..
