  • Jpmcdo
    • Dec 2015
    • 60
    Does anyone know if there is a way to verify the blue box is working properly after a crash? I'm going to bypass as much as I can this time around but was wondering.
      • 5402
      Plug it in and move the sticks on the radio...
      • Jpmcdo
        • Dec 2015
        • 60
        Thanks, I was planning on doing that, but saw a few posts back people were questioning it.
        • KC8REH
          • 17
          • Grand Rapids, Mi
          Thats may not be an accurate test. The problem My blue box did not happen unless it is in flight with the vibrations effecting it. On the bench the malfuntion does not appear.
          • themudduck
            -TMD- Foaming at the Mouth!
            • 1041
            • Burton OH (near Cleveland)
            A few posts back I mentioned I was going to try using a pair of 4-cell 2500's. There was some concern because they are lighter than the 3600's and perhaps there would be a balance issue.
            RONWC mentioned that he didn't have a problem with the smaller packs. My report: I tried them today and had good results. No issue with the balance, and the model performed well during two flights.
            So here's a picture of them installed, you can see they are not pushed all the way forward, they are about an inch back from the front of the battery compartment.
            During the first flight I tested the balance and found that the model was actually still a bit nose heavy (it needed a LOT of down elevator when inverted) So I could probably push these 2500 packs even further back, but it was ok.
            I got about 6 minutes with the 2500's and had about 35% left. (I can go for at least 10 with the larger packs)
            Click image for larger version  Name:	2500 batteries.jpg Views:	0 Size:	61.3 KB ID:	263683
            And here is a video I took on the second test flight. (camera is mounted on the left ordnance pod)
            On this second flight I did some loops and rolls and then a touch-n-go.... and then I realized that my touch-n-go was without the right main gear - it wasn't down! I tried cycling it several times with no luck - so I landed on two gears right on the edge of the runway (carefully, slowly, with flaps) and just let it run to the right into the grass. No damage at all, it was perfect. So.... a good day, I was happy with the way the model performed. I need to permanently eliminate this connection problem with the main gear...
            • Rcfiddy1
              Professional Crash Test Dummy
              • Aug 2015
              • 186
              • Manalapan, NJ
              Originally posted by ronwc
              I fly everyday down here in FL, and have flown my OV-10 a lot, just got three more flights this morning. I have three different pairs of lipo's I use, 2500, 3300 and 3700. I move them all the way forward with no extra weight added, and the Bronco flies great on all of them. And for those that didn't see some of the earlier post, the power is not overwhelming, but what I would call adequate. Changing out to APC 10x8 two bladed props helped a lot in speed and pull.
              Did you do counter rotating props? What props did you use? I’d like a little bit more punch and hate to start sourcing motors and esc.
                • 5402
                Mud, what’s the weight of the batteries you used and where did you balance it? Congrats on trying something different and it working!
                  • 5402
                  He said earlier he didn’t.
                  • themudduck
                    • 1041
                    Hey, I tried the yellow Admiral 2500's (previously I used the black Admiral 3600's - the two 2500's weigh 1lb 5 oz (total) and the two 3600's weigh 1lb 11oz (total).
                    The 3600's are a few years old. Motion is selling 4000's now that are about the same weight as the 3600's.
                    Anyway it balanced about 1/3 back from the LE, using my fingers (my final balance check is in the air)
                    I've been using the heavier batteries, and obviously the balance point would have been even more nose-heavy, but I was happy with the way it handled before. I just think it flew better with the lighter batteries, but I have to say that it really wasn't a lot different.
                    • vduniec
                      Hobby Squawk Pilot
                      • 314
                      Still not completely done but very close. I'm especially proud of the FM whip antennas added to the tail booms. On the actual aircraft, they stand up straight when the plane is stationary but in flight, they bend due to the air flow. I was trying to think of a material that would have those qualities, yet still be durable enough to survive the everyday bumps and dings my planes usually endure. The solution is cheap and easy. I took two bristles from a nylon broom we have. Perfect! They even bend in flight. The humps at the antenna bases are 3D printed. I'll upload them to Thingiverse in the next few days.
                      Once again, Thank you Motion RC for another great plane!
ID:	263711Click image for larger version
                      • ronwc
                        AMA 1025
                        • 37
                        • Largo, FL
                        I will try three different things to get more power in a plane before paying for new motors and or ESC's. One that can make a small difference is to set timing up by using a programming card. Next is to change out props. As mentioned before, three bladed props are usually on planes for looks, and they do look good, but they are inefficient. In this case I went with the APC 10x8 two blade, they don't make this size in reverse pitch so not counter rotating, but it really makes no difference in the way it flies, and very easy to swap two wires on the one motor. In this case it made quite a big difference in speed and pull, cost $22 for props and two 2" spinners, so a cheap improvment.
                        I am happy with the prop improvement but the next step, which I may do later, is simply to go to 5 cell lipo's. I've done this on many planes, but I always look at stock ESC's first to see if they can handle the extra load. In the case with the OV-10, I don't think they can since they are small 30A and are unlabeled, probably just good for 2-4S. I do have some 50A ESC's I bought a while back that are good up to 6S ($11 each) that I may use, and hope that the motors will hold up, which they usually do. Going to a 5 cell will increase RPM on a typical motor by about 2500 (depending on kv), making a huge difference.
                        Ron - AMA 1025
                          • 5402
                          Looks awesome Hawkdriver!
                          • Dave A.
                            • Jul 2020
                            Evan D and vduniec,
                            Did you guys strip the original paint before repainting? Just curious if you did anything to help the paint adhere. I have discovered the hard way that even blue painter's tape will take the original paint off the OV-10, and I have not had much luck getting paint to stick well to EPO-type foam. If you actually want to strip the paint, which I did for the glue area of the sponsons, duct tape seems to work pretty well.
                            I'd like to repaint the wing white. VMO-2 apparently re-painted their wings white in Vietnam after discovering that the jets they were trying to control could not see the OV-10s against the trees with overall green.
                            - - Dave
                            • Spinny Testaverde
                              Videographer, Editor, Drone Pilot
                              • Mar 2019
                              • 92
                              Wow this looks awesome vduniec!
                              • AceMigKiller
                                Insta: Check5_Av8r
                                • 175
                                Great scheme! I'm considering that one or the desert scheme... decisions, decisions.
                                  • 5402
                                  I sprayed mine with house paint, valspar from Lowes, I sanded it down lightly to remove the injection nubs. Vic did mostly the same but he hand brushes the paint. It's amazing how well his planes look.
                                  • fjkelley@cox.net
                                    Bronco FAC
                                    • Jun 2019
                                    • 25
                                    Just for everyone's info: Testor's Model Master spray enamel Flat Gull Gray, FS 36440, #1930, is a EXACT match to the gray that is on the model...
                                    I'm doing mine all gray (flat white on the top of the wing) to match the OV-10, Air Force, I flew in Vietnam.
                                    Old Dawg
                                    • Uncle Bob's RC
                                      • Mar 2020
                                      • 11
                                      I had the same problem with the right main landing gear not coming down. After multiple attempts I finally got the gear down. This happened on two consecutive flights. Could not duplicate at home. I was thinking that if I couldn’t get the gear down, I would land gear up, but after seeing your video a two gear landing might be a better option.
                                      Update..... I by passed the blue box and connected both gear directly into the receiver. When I tested the gear, the right gear failed to extend. I contacted Motion and they are sending me a replacement. Excellent customer service.
                                      • thomasnwilliams
                                        • Aug 2018
                                        • 20
                                        • Columbia, SC
                                        Here is the 3d wiper from post 674 pg 34. I've not printed it yet so not 100% sure but it was the only one I found and they match design wise. have fun!
                                        https://www.thingiverse.com/thing:2632986
                                        • themudduck
                                          • 1041
                                          I printed this wiper and installed it. I like the way it looks.
                                          Its fun to add these details.
                                          Update; I flew two more times last night (Wednesday) and the landing gear worked properly each time. I still have no idea why it was intermittent.
                                          Click image for larger version  Name:	20200716_172137.jpg Views:	0 Size:	51.5 KB ID:	264098
