    The HSD Skyraider prop.works with the stock shaft and hub nut if you put a piece of heat swrink over the shaft and swrink it.
      See what I mean about this not looking like a six pitch but rather maybe an eight?
        • 2818
        • Arlington, TX
        Yeah, definitely looks higher pitched than 6.
          • 8215
          I agree, that looks more than 6 pitch...So I will be the 5S guinea pig eh? Gladly! :)
            Not the best shots but here's the fly-bys..
              SWEEEEEEEET..........4S and the 16" Raider prop IS A WINNER. THANX TI
                Very nice. Has a unique sound to it. Thanks for the vid.
                  :) got several flights on the P-47 today, the only thing I don't like is the light wing load.
                    • 7349
                    Looks great TI!
                    • farmflyer
                      • Mar 2015
                      • 1164
                      • Quitaque Texas
                      TI flying under that wire all the time could get interesting I bet.
                        • 2818
                        • Arlington, TX
                        Looking good TI! Can't wait to get mine in the air now!
                          You don't even notice it after a while...there's plenty of room if you don't want to fly under it. I may end up moving it, I had it put in to get power to the other side of the property.
                          • TomC
                            • 79
                            NICE! I have been following this thread closely:D...Looks be running an estimated 85-90 MPH??
                              Two 4S 4000 packs in parallel oughta help load you up ;)
                              Can't tell ya how stoked I really am that this 4S / 16inch set up has worked out.
                                I would guess around 80 mph.
                                  • 2818
                                  • Arlington, TX
                                  Either way, that's some incredible performance from 4S! Makes me wonder how fast Aros's bird is going to go on 5S :cool:.
                                    • 8215
                                    Nice! 4S definitely looks manageable! Yeah can't wait to see what I can get from 5S. :)
                                      • 8215
                                      TI where's your CG at? Also, how exactly did you put the HSD prop on the stock motor shaft?
                                        I used a prop reamer to cut a pocket for the hex then put one piece of heat shrink over the shaft the length of the prop hub then tightened the stock hub nut on it. CG is at 93mm.
                                          • 8215
                                          Got it...Okay thanks!
