  • Mad Baron
    132 Aviation
    • 547
    • McMinnville Tn.
    I finally got my second Bearcat ready for its maiden flight! Just have to check the C.G. on it, and when I was putting it together I put a bead of Foamtac on the hinges so I wont worry about a control surface coming loose again. :Cool:I went with the same livery that was on my first Bearcat.
      • 7438
      Such a great airplane!!
      Can't wait for the 1600 mm version, (hint hint) :pop
      • Mad Baron
        132 Aviation
        • 547
        • McMinnville Tn.
        I got my Bearcat balanced I had to put 3 ounces behind the radial engine.
          • 7438
          that's interesting, I just put the 4000 all the way forward when I was running her stock and it worked fine.
          • Mad Baron
            132 Aviation
            • 547
            • McMinnville Tn.
            I put the 4000 battery all the way forward as well but it was still tail heavy. I didn't put any weight in my first Bearcat but this new one needed the extra nose weight.
              • 7438
              Strange..........
              Might be the perfect airframe to install a 650 kv into.
              That and the 1400 mm Corsair prop work amazingly!
              • borntoolate
                Bomber Bob
                • Mar 2013
                • 424
                • California
                Strange..........
                I have done this and you are right, it is amazing.
                  • 7438
                  no point in adding dead weight when you can add more power!
                  I had to add a bit of weight to the rear of the fuse in order to get the CG, this one may not need it.
                  • Mikeinlutz
                    • Jul 2018
                    • 9
                    • Lutz, Fl
                    Right side retract door will not close. All ready had new left wing shipped because retract didnt work. First motion rc plane, the door hangs open after the retract closes. Adjustments, or just return the plane, any help appreciated
                    • borntoolate
                      Bomber Bob
                      • Mar 2013
                      • 424
                      • California
                      Did you check to make sure the wire closer is still attached to the door? If It still is attached, try bending it so that the wheel will pull it closed.
                        • 7438
                        Those pins can be a pain. Mine close most of the time, when they don't I just fly, I worry more about the gear coming back down than the door closing. I can operat mine several times on the ground and it'll work fine, but in the air the wind bends the pin slightly I guess...answer, bend the pin slightly forward, have to try that.
                        • hotrod23t
                          jim jets
                          • Nov 2017
                          • 312
                          • EUSTIS FL.
                          i put an additional magnet on both doors no more problem air was opening doors at high speed at least it worked for me..:pop:Thinking:
                          • Mikeinlutz
                            • Jul 2018
                            • 9
                            • Lutz, Fl
                            Wire is still attached, the retract pulls it part way closed, wont go all the way. Closing it with a finger it will not close correctly and stay closed, where do put the magnets, pics?
                            • hotrod23t
                              jim jets
                              • Nov 2017
                              • 312
                              • EUSTIS FL.
                              i just stuck them to the exsisting magnets.. on the outside of fuse didnt even have to glue them can get pics tommorow:Yawn::pop
                              • hotrod23t
                                jim jets
                                • Nov 2017
                                • 312
                                • EUSTIS FL.
                                i just have to touch my doors and thay just snap shut your doors are not binding right:Thinking::pop
                                • fhhuber
                                  • Aug 2015
                                  • 1476
                                  Retract doors are sources of perpetual need to adjust linkages. Part of life with "complex" models.
                                  • hotrod23t
                                    jim jets
                                    • Nov 2017
                                    • 312
                                    • EUSTIS FL.
                                    BEARCAT gear doors are just a pin and two magnets on each door 1 to hold it open and 1 to hold it closed make sure ll your magnets are there..no linkage to adj.:pop
                                    • fieldofdreamsflyer
                                      Banned
                                      • Jan 2013
                                      • 289
                                      I had one of these at one time and then this happened and made me very sad :Crying:
                                      • axerhand1976
                                        • Mar 2014
                                        • 89
                                        so is the stated cg correct? I was thinking of using a 4500mah since a lot of you guys said it needs weight up front ight as well be more time then lead.
                                          I had to add 6 ounces to the cowl interior. Epoxied around the dummy radial out of sight. It seemed like a lot, but it balanced exactly on the CG, slightly (3 degrees) nose down... Flies absolutely great. I am using Admiral 4000 packs. 4S. Warbirds like the Bearcat will eat your lunch if they are tail heavy... I like Grossman's solution of more power up front instead of lead!!! :Cool:
