I finally got my second Bearcat ready for its maiden flight! Just have to check the C.G. on it, and when I was putting it together I put a bead of Foamtac on the hinges so I wont worry about a control surface coming loose again. :Cool:I went with the same livery that was on my first Bearcat.
Such a great airplane!!
Can't wait for the 1600 mm version, (hint hint) :pop
Grossman56Team Gross!Comment
that's interesting, I just put the 4000 all the way forward when I was running her stock and it worked fine.
Strange..........
Might be the perfect airframe to install a 650 kv into.
That and the 1400 mm Corsair prop work amazingly!
no point in adding dead weight when you can add more power!
I had to add a bit of weight to the rear of the fuse in order to get the CG, this one may not need it.
Right side retract door will not close. All ready had new left wing shipped because retract didnt work. First motion rc plane, the door hangs open after the retract closes. Adjustments, or just return the plane, any help appreciatedComment
Did you check to make sure the wire closer is still attached to the door? If It still is attached, try bending it so that the wheel will pull it closed.Comment
Those pins can be a pain. Mine close most of the time, when they don't I just fly, I worry more about the gear coming back down than the door closing. I can operat mine several times on the ground and it'll work fine, but in the air the wind bends the pin slightly I guess...answer, bend the pin slightly forward, have to try that.
Wire is still attached, the retract pulls it part way closed, wont go all the way. Closing it with a finger it will not close correctly and stay closed, where do put the magnets, pics?Comment
I had one of these at one time and then this happened and made me very sad :Crying:Comment
so is the stated cg correct? I was thinking of using a 4500mah since a lot of you guys said it needs weight up front ight as well be more time then lead.Comment
I had to add 6 ounces to the cowl interior. Epoxied around the dummy radial out of sight. It seemed like a lot, but it balanced exactly on the CG, slightly (3 degrees) nose down... Flies absolutely great. I am using Admiral 4000 packs. 4S. Warbirds like the Bearcat will eat your lunch if they are tail heavy... I like Grossman's solution of more power up front instead of lead!!! :Cool:Comment
