Three colors to match. Once I had the grey, it was a matter of adding additional color to get the green and a bit of light blue to get the underside. For some reason, I can look at a color and see what it needs, probably comes from my oil painting days (you can see my Flying Tiger painting in the top center of the first pic) One thing I've found is that when you have one color it will lead to the other, like they just added some additional pigment to change the color rather than cleaning the gun, probably faster on the assembly line (I'm talking the full scale WWII era).
I found this when I was matching paint for the P40. Mixed the green, then added some red and white to make the brown. Also, I got wise and made a couple of swatches, unfortunately, I forgot with the first color so will have to mix it again. With the swatches, I can take them to Ace and scan the colors, definitely easier that way!
Sorry Simon, I had no idea the MR RC Sound system is no longer available. Just did an exhaustive search and found nothing out there, not even on ebay. I've been using those since they first came out and originally dealt with Andrew (maker) directly in 2018 before MRC ended up representing them. Must have 9 of his systems now. I did try the Model Sound System with two 3" speakers in my large FW 190, which works great and also has gun sounds, but he also went out of business late last year. Maybe I'm a jinx.
A second transducer really does help but I guarantee you that gluing your single transducer to the hardboard will muffle at least 70% of the sound. It really needs to be glued to the foam. The hardboard will not resonate the sound at all, in fact it will deaden the sound. The foam, being microscopically filled with air pockets, magnifies the sound and this carries throughout the entire foam of the fuselage. If you can remove it, just set it directly against the foam and see how much greater the sound is. The hollow fuselage then magnifies it further.
