  • f4u ausie
    • 1242
    • Melbourne
    That poses a new question,,, im sure the higher kv , spit motor will bolt up etc.. to the corsar likely the eighty amp esc will need upgrading,, bigger prop ??? (dont have amp checking equipment) looks like shaft etc will fit.... anybody done it?? Should have asked on f4u thread... o well
    • Prekin
      • Feb 2021
      • 135
      I was busy with some orders and CAD works in last days, well I did not work on Spitfire very much. Bottom side is almost done for painting and now I am going to open the cockpit.
      Today I only painted exhaust stacks. Final coat they will get when I put them back on nose.Click image for larger version
ID:	373403Click image for larger version
ID:	373401Click image for larger version
      • jetfool
        • Nov 2022
        • 1362
        • Crawfordsville, Indiana
        Very, very nice Prekin. Attention to details really brings the model to life. Rex
        • Prekin
          • Feb 2021
          • 135
          Thank you very much Rex! I hope, I will keep my motivation to the end of project!
          • Prekin
            • Feb 2021
            • 135
            I really missed the canopy rails on the fuselage. I cut the a hole for dummy rails and also did cockpit a little wider.
            Cockpit is very shallow, so there will not be many details on side panels.
ID:	373775Click image for larger version
              • 4869
              [QUOTE=Prekin;n373772]I really missed the canopy rails on the fuselage./QUOTE]
              PK, Nice touch, as usual. Best, LB
              • Prekin
                • Feb 2021
                • 135
                Thank you LB!
                I got back to wings for a minute and added flap control arm doors. Those I cut from piece of aluminium tape.
                MG ports will be covered by fabric tape, but it may will be more authentic if there will be holes in leading edge.​
ID:	373874Click image for larger version
                • Prekin
                  • Feb 2021
                  • 135
                  I looked at the cockpit closer. Depth of the cockpit area is 40mm. It seem, there will not be a lot of work on cockpit details. Only some braces of the fuselage and small piece of seat. But on the port side I may add radio channel switch and parts of crowbar and throttle quadrant.
                  • f4u ausie
                    • 1242
                    • Melbourne
                    2 more flights on my spit thismorning ,, loving the way it flys.. great power..,, still need abit less elev flap mix ,, will reduce that 4 next weekend
                    • Prekin
                      • Feb 2021
                      • 135
                      I added some covering tape on tail. Now I will do some painting to see, how it looks under paint.
ID:	374145Click image for larger version
                      • Prekin
                        • Feb 2021
                        • 135
                        I am happy with the result of painted tail. Does not look bad.
ID:	374148Click image for larger version
                        • jetfool
                          • Nov 2022
                          • 1362
                          Jiri,
                          Looking great! Rex
                          • Prekin
                            • Feb 2021
                            • 135
                            Spitfire is getting back camouflage. For masking the light grey bottom side I use our masking tape for very sensitive surfaces. As you can see, no peeling.
ID:	376875Click image for larger version
ID:	376876Click image for larger version
ID:	376878Click image for larger version
ID:	376879Click image for larger version
                            • Prekin
                              • Feb 2021
                              • 135
                              Yellow painted leading edges looks much better than stock decals to me.
ID:	377035Click image for larger version
ID:	377037Click image for larger version
ID:	377036Click image for larger version
                                • 4869
                                Prekin, Acknowledged & Agreed. Best, LB
                                • Prekin
                                  • Feb 2021
                                  • 135
                                  Painting is in progress. Fin tricolor is finished, next I will do all roudels.
                                  I was not sure about width of the white field, but I was very happy when I found camouflage regulation for RAF WWII airplanes.
ID:	377150Click image for larger version
ID:	377148Click image for larger version
ID:	377147Click image for larger version
                                    • 4869
                                    Prekin, painting your markings looks so much better. Nicely done. Best, LB
                                    • Prekin
                                      • Feb 2021
                                      • 135
                                      Thank you LB!! fuselage roundels are challenge on the fuselage, but I've already tried it on B-24.
                                      • f4u ausie
                                        • 1242
                                        • Melbourne
                                        Looking forward to finished product,, looks great
                                        • Prekin
                                          • Feb 2021
                                          • 135
                                          Thank you ausie! Actually I am in rush now. Only 2 weeks left to event. That is the reason why I closed the cockpit and started painting. I will finish the cockpit later.
