    • 4819
    [QUOTE=Prekin;n365212]Next year I would like to put my giant scale Spitfire project back on bench. That project needs some new parts. The instrument panel is one of the part which needed revision. In the pictures you can see the IP. It will need some mods on the shape for the FL Spitfire, because the foamy fuselage./QUOTE]
    PK, that is some beautiful work, Sir. Looking forward to watching your progress. Best, LB
    • Prekin
      • Feb 2021
      • 135
      [QUOTE=Elbee;n365244]
      Thank you very much Elbee for your kind words. I do my best. I hope I will be able to use the control column I designed.
ID:	365246Click image for larger version
ID:	365248Click image for larger version
        • 4819
        [QUOTE=Prekin;n365245]
        Originally posted by Elbee
        Thank you very much Elbee for your kind words. I do my best. I hope I will be able to use the control column I designed.​
        PK, again great work. I had designed and then redesigned extra cockpit parts for my Flightline Spittie, as well as some semi-scale Seafire Conversion Parts; however, your parts appear to be "spot-on".
        Do you have a 3DP Printer or access to one? Also, do you have the original MotionRC OEM Spitfire Cockpit STL FIles?
        Best, LB
ID:	365261Click image for larger version
ID:	365262Click image for larger version
ID:	365263Click image for larger version
        • Prekin
          • Feb 2021
          • 135
          Very nice cockpit parts!
          Of course I have several 3D printers in our workshop. I am going to use only the CAD designs from our office.
            Elbee commented
            Editing a comment
            Yes, again, beautiful work, SIr. Best, LB
        • Prekin
          • Feb 2021
          • 135
          I'm still waiting for better weather so I did only some cockpit parts such as gunsight, spade grip with brake lever and canopy latch.
ID:	365366Click image for larger version
ID:	365365Click image for larger version
ID:	365363Click image for larger version
ID:	365364Click image for larger version
            • 4819
            Prekin Beautiful resin prints and great design work. Nicely done, Sir. Best, LB
            • Prekin
              • Feb 2021
              • 135
              Thank you very much for your kind words LB!!
              • Prekin
                • Feb 2021
                • 135
                I went thru the manual once more and probably I will set the CG at 85mm and also use smaller control rates. She will need some extra weight. Also on the FL B24 I moved the CG little closer to L.E.
                • Prekin
                  • Feb 2021
                  • 135
                  Happy New Year!!! Maiden successful. I moved 6S 5000mAh into nose as possible and add 35g of extra weight. Just only little trim elevator up.
ID:	365611Click image for larger version
                    • 5385
                    Congratulations on the maiden!
                    • Prekin
                      • Feb 2021
                      • 135
                      Some flight shots.Click image for larger version
ID:	365640Click image for larger version
ID:	365641Click image for larger version
                        • Nov 2013
                        • 2659
                        • Cody, WY
                        Some flight shots.Click image for larger version  Name:	F3.jpg Views:	13 Size:	55.9 KB ID:	365640Click image for larger version  Name:	F1.jpg Views:	13 Size:	47.8 KB ID:	365641Click image for larger version  Name:	F2.jpg Views:	15 Size:	120.9 KB ID:	365639​
                        Nice inflight shots showing the prop blur, Prekin. The cardinal sin for airplane photographers is to use a too fast shutter setting where the prop is "stopped" in midair. I did it myself back in the day. Nice and crisp inflight shots, too. Well done.
                        davegee
                        • Prekin
                          • Feb 2021
                          • 135
                          Thank you Dave. That guy use to take some shot at our airfiled. That was the first time when he took some shots of my airplanes.
                          I did some new parts. 20mm Hispano cannons, pitot tube and antenna mast.
ID:	365737Click image for larger version
                            Elbee commented
                            Editing a comment
                            PK< Great details, simply marvelous work. Best, LB
                        • Prekin
                          • Feb 2021
                          • 135
                          Spitfire project started. As first I replaced the fuel filler cap. Now I am working on the antenna mast with base. The mast will be removable. I was thinking about small bolt and nut I used on the giant Spitfire, but small pin would be better in in that size.Click image for larger version
ID:	365797Click image for larger version
ID:	365803Click image for larger version
ID:	365802Click image for larger version
ID:	365798Click image for larger version
ID:	365799Click image for larger version
ID:	365801Click image for larger version
                            • 4819
                            Prekin you are a man after my own heart. Really liking all the small details and your parts look excellent. Best, LB
                            • Prekin
                              • Feb 2021
                              • 135
                              Thanks a lot LB. But the cockpit will not be so detailed as you did. I want to fly her ASAP!!! 🤣🤣
                              • Prekin
                                • Feb 2021
                                • 135
                                Some little work on Spit tail for today. I replaced trim rods with fairings on elevator and rudder. Tomorrow I must add one trim rod on left elevator, because I lost it somewhere in workshop. 🤣🤣🤣
ID:	365929Click image for larger version
ID:	365930Click image for larger version
ID:	365939Click image for larger version
ID:	365933Click image for larger version
ID:	365931Click image for larger version
ID:	365932Click image for larger version
ID:	365937Click image for larger version
ID:	365938Click image for larger version
ID:	365934Click image for larger version
ID:	365935Click image for larger version
                                • Prekin
                                  • Feb 2021
                                  • 135
                                  Not too much work today. I just add the trim rod on elevator.
                                    • 4819
                                    Not too much work today. I just add the trim rod on elevator.​
                                    PK, Yep, that'll do nicely, Sir. Best, LB
                                    • Prekin
                                      • Feb 2021
                                      • 135
                                      I am ashamed. just a minute in the workshop today. 😞
