Two things. ESC calibration or receiver "sensing".
ESC, calibrate it )might help to use a "dumb" receiver for this the first time to make sure it works. Then... If it doesn't go through it's zip zip zip AS3X moving of the surfaces it either not sensing proper position or the aircraft is not super still, even slight wind movement will stop it from going through it's zip zip zip... Are you sure it's position is correct?
