  • Foot long rod... punch the old one out. Then use the long all-thread to drag the new in place.
    It does get tedious turning a nut on the all-thread to pull a blind nut a long way in from where you have access, but it gets the job done.
    • I got the bad blind nut out and used a flexable metal pushrod and slid the new nut into place. I hope to test fly it on Sunday
      • :Cool::Cool:
        • I am not getting along with this B26 I just found loose tail weights in it I don't know if the weights had any thing to cause the crazy flight.
          • Get rid of them, anyway mine was much better without them
            • This plane needs the weight it doesn't want to balance without them it was too nose heavy without the weight
              • Weird mine flew waaaaay tail heavy with them
                • Hopefully it will fly like it used to. I plan on going this Sunday. I'll post a flight report after the flight.
                  • Sounds good will be hoping for the best my friend
                    • There are 2 weights in the tail cone. On mine, one was just rattling around. I hot glued it back in place and put more hot glue on the other one. I think it'll fly pretty the same with or without the weight. Without the weights, you'd need a little more elevator UP to compensate but once trimmed, the plane shouldn't know the difference. My 4000mah, 4s is pushed as far back into that bulkhead as it will go. The front velcro isn't even used. It doesn't touch the battery.
                      The true test is flying it inverted. It's been a long time since I flew it that way, so I can't remember what the outcome was. Obviously, it wasn't shocking enough that I would remember anything bad about it.
                      • I had to put my weights back in as I had put larger motors and ESCs in, plus I replaced the Dynam gear with a mix of Freewing (mains) and FMS (nose gear). With the weight it is still a tad nose heavy. Next flight I will adjust with a bit of weight, or move my BEC battery (s@ 1300) further aft. She sure sccots around nicely with the 11Hobby Bearcat motors!
                        Bob
                        • Wow it's really strange as my 4000 almost touched the front of the canopy hatch :Confused:
                          • Originally posted by Mad Baron View Post
                            Too nose heavy without the tail weights? Have you tried using a smaller battery (as I have been suggesting for like since forever?) You'll end up with a lighter model overall, which is always a good thing when you're talking about this kind of plane.
                            The weights were talked about from the beginning of this thread (see post 537 for example). Someone at the factory noticed how nose-heavy the model is... and added the weights. Its better to use a smaller battery! With a 4000 mah battery (and the tail weights) your plane will weigh about 6 pounds. With a 3600 and no weights it will weigh about 5.5lbs.
                            Besides correcting the balance issue, with a lighter plane the motors don't have to work quite as hard (they draw less amps) and so flight times with the smaller battery are just as good.
                            • I can't see a difference of 225 grams between a 4000mah and a 3600mah (and those weights). Besides, I 'm quite happy with the way mine flies as is.
                              • I use the 3600 and it balances out just right. I tried balancing it with no weights and it was too nose heavy. I can live with a couple of ounces if it helps the plane fly well.
                                • Yeah I think it does, weird thing is mine still looked like it was dragging its butt in the air. It flys ok but it's just leaving a large W in the sky where its ass drags...:Confused:
                                    I can't see a difference of 225 grams between a 4000mah and a 3600mah (and those weights). Besides, I'm quite happy with the way mine flies as is.
                                    Hey Xviper, let me point out that back on post 437 you wrote that you took out the tail weights and you said "
                                    I'd rather move the battery back or use smaller batteries to make it balance".
                                    There are variances between planes of course. Mine balances with the 3600 battery propped forward about 1.5 inches from the back of the battery bay (I used a piece of foam for a spacer) with no tail weights. But if you guys are flying noseheavy with a 3600, then I guess the tail weight may be needed. IDK, personally I would try an even smaller battery before I would add weight.
                                    • I use 3300 40c China Hobby batteries and no weights in the tail. I did move the servos back one bay. My 3300 is shoved as far back as it can go. I weighed mine and I was under 6.3 lbs with battery. Get 9mins flight time
                                      • That's freaking awesome :Cool: very impressive
                                        • Well the B-26 is 99% complete just a few parts need put back on. I took it outside to my front yard (away from any powerlines) and range checked with the motors on and off no unusual servo movement so hopefully it will fly with no issues.
