    Indeed I just ordered a bunch of spare parts
    • themudduck
      -TMD- Foaming at the Mouth!
      • 1041
      • Burton OH (near Cleveland)
      [QUOTE=TiredIronGRB;n92112]Gear doors...
      Nice work! Wondering how you did that - where did you get those hinges from.
      • CFIT rob
        • Jul 2016
        • 220
        • Indy
        Very sorry to hear rifleman. Will be assembling this weekend. Maiden sunday i hope. What battery were you using? Do you think the battery could have slid back? Any first flight reports from anyone else? Battery type/weight? Recommended CG? Fly similar to any other plane? P38 perhaps?
          • 8814
          Might have been the throws. But I never use more than 1/4 stick when I'm doing a shakedown,. It almost crashed on the maiden rotation. It rolled left immediately. All the snapovers were to the left as well
          Curious if you did a throttle calibration to sync the motors? Sounds like one motor was pulling more than the other.
          • quitcherbitchen
            • 927
            • Altadena, CA
            My Durafly Bf 110 does the same thing, but after lift off it mellows out. Calibrated the ESC so many times it is a bad habit. It doesn't snap though, just scares the ka ka out of you.
              Originally posted by ruffneckx1
              TIGRB...are you only using one gear door per wheel ?
              Woody
              Yes
              • fieldofdreamsflyer
                Banned
                • Jan 2013
                • 289
                Did you calibrate the escs first, sounds like you have a motor turning faster then the other one
                • ruffneckx1
                  • 112
                  Hardway.............mine was done at SEFF a couple of years ago.I called a landing but someone decided he had the right of way and came down on top of me. Easy enough fix as it was a clean break, though unnecessary.
                  Woody
                  • ryramZ
                    Pilot Ryan
                    • Dec 2012
                    • 814
                    Sorry to hear about the crash. I flew at 60mm and loved it.
                      Almost done, decals and some paint for the white legs and she'll be ready to fly.
                        Banned
                        • Jan 2013
                        • 289
                        Dam you putt that together fast , whats up with the canopy. Looks pretty fogged up
                          Yeah I did the calibration first thing. I was using a 4s 5000 and 4s 4000. Both packs did the same. I kept moving the battery forward through the flights. Just never seem to be happy in the air. Maybe that's why they called this the widow Maker.
                            Had silver paint all over the canopy, used Goofoff and it fogged it up.
                              Oh the 4000 was a zippy and the 5000s were nanotech
                                • 8814
                                Unpacked mine today and as someone else already mentioned, that lead weight in the tail was just rattling around loose - probably what caused the rear guns to detach and rattle around, too. Anyway, I took that weight out. I'd rather move the battery back or use smaller batteries to make it balance. That top wing cap is really ill fitting. Don't know if I'm going to mess with it. Tried shaving a little off the rear lip but that didn't do a thing. It could be the magnets aren't embedded enough and that's what's holding the cap too high up. The front lip is easy. I'll Blenderm that in place.
                                  Can someone post a picture of where the lead weight is? Mine didn't have one.
                                    Mine was rattling around don't know if it was before or after the crash
                                      I weighed the lead and it is 1.54 ounces. In the section of the tail, directly under the tail guns... (that happen to go to the Dynam BF-110 rear gunner) Just say'n. The paintbrush indicates where mine was floating around.... :-)
                                        • 8814
                                        Originally posted by Mad Baron
                                        I just went and checked my plane and I found no lead weight in mine. I haven't really started on the build yet I just checked out the electronics to ensure that they were working properly. Rifleman do you have a tachometer to check both props are tuning at the same RPM?
                                        If it's glue in, it's hard to see it. It'll be at the very tip of the tail cone. You have to look at an angle from above and towards the tail cone through that last hole. Shine a light. It's dark in there.
                                          • 8814
                                          Weird that they would put that weight in some and not in others. :Confused:
