Originally posted by Mad Baron
And the hatch fits absolutely perfectly on the fuselage when there is no wing. -- check
But when the wing is installed in the saddle, the hatch doesn't go down all the way. D'OH~!
I took the wing off last night (keeping in mind that I've had 8-10 nice flights) and I found that the rear wing attachment points in the fuselage had pulled out AGAIN even after I had re-secured them. This is NOT GOOD. (I can't help but think -with some ominous music in the background- that someone's going to have their wing come right off while doing a loop....)
Next step for me - I am installing piece of plywood at the rear of the wing saddle, a hard mount if you will, so I can screw down the rear of the wing securely.
