Freewing F-105 64mm EDF Jet - PNP
  • Originally posted by F106DeltaDart View Post
    A few photos of my P-47 flying in some nasty weather last weekend. Unfortunately, in the last flight, I ran into some nasty low altitude turbulence, and ended up falling short of the runway by about a foot. The gear hit the edge of the runway and ripped out, prop broke, and broke the firewall free. It will be repaired, but it may take a while to get everything back together.
    DeltaDart, it is a lovely paint job mate, very well done.
    Tolga
    Instagram: @_t01ga_
    YouTube: t01ga
    • Currently working on my black Friday project, while a friend is doing the Flightline Spitfire. Will be fun to fly side by side.
      Still some airbrush and detailing to do. Gun and exhaust is not yet ready.
      Thank you all for your tips and tricks in this thread. Helping a lot.
      Andy
Name:	20191130_205625 Kopie.jpg
Name:	20191130_205523 Kopie.jpg
      • Wobisch Your subtle weathering looks quite realistic, very nicely done! Have you maidened it already, or will both of you be going up for the first time at the same time?
        • the weathering was done with the "washing" method. No airbrush yet. I used some paint from vallejo called "Model Wash". Grey, light grey and terra. Applied several layers.
          I think I'm waiting for a double maiden. Currently it's a bit cold here anyway. Meanwhile I'm going to finish the Tomcat.
          Click image for larger version  Name:	20191130_205553.jpg Views:	0 Size:	104.4 KB ID:	220962
          • Wobisch Even more impressive that it's a wash, not an airbrush! I usually don't have good experiences with washes on foam because they tend to accentuate the foam cells, but you've obviously mastered this technique, regardless.
            • My buddy and I. Ready for new year.
              Both maiden went well.
Name:	20200105_143724 Kopie.jpg
Name:	20200105_144158 Kopie.jpg
              • MRC now shows this Bonnie in 1500mm as dis-continued with no real parts availability. I may have just bought the very last one and it's still NIB.
                AMA-1162306
                With more planes than should be legal
                • You can still get one at Hobby Zone.
                  • Originally posted by farmflyer View Post
                    And Horizon Hobby or direct from FMS Model
                    Now to the real reason for visiting the thread. NEED the STRUT LENGTH from axle to top of strut
                    Thinking of using it on the main gear of the E-flite CZ T-28
ID:	248840Click image for larger version
ID:	248839Click image for larger version
ID:	248838Click image for larger version
ID:	248837Click image for larger version
ID:	248836Click image for larger version
ID:	248835Click image for larger version
ID:	248834 Cockpit upgrade is complete!
                      Tolga
                      Instagram: @_t01ga_
                      YouTube: t01ga
ID:	250504 Landing light added. Regrettably it is not retractable.
                        https://youtu.be/uQTGndvoUEs
                        Tolga
                        Instagram: @_t01ga_
                        YouTube: t01ga
                        • t01ga If your landing light is regrettably non retractable maybe take a step back and redo it
                          Did you know that the Freewing 1410mm Mustang has retractable landing lights and that you can get them as spare parts
                          Here's the direct links:
                          https://www.motionrc.com/products/fr...ght-holder-set
                          https://www.motionrc.com/products/fr...landing-lights
                          Best regards,
                          • OV10 No I wouldn’t know that as I don’t care much about P-51s. Never had one and I doubt I ever will. However I appreciate the tip as those lights are cool. I might do that on my spare one in the box.
                            Tolga
                            Instagram: @_t01ga_
                            YouTube: t01ga
                            • Around 6 months ago, I had an in flight motor failure with my P-47 and ended up landing short of the runway. After replacing the motor bearings and repairing substantial motor mount damage, it sat on the shelf for a long time. Yesterday, I finally got it down and started the tedious process of re-masking the checkerboard. After 5 hrs of work with masking tape and post its, the cowling is finally looking good as new. Can’t wait to get it in the air again!
                                I was working on the "floating plug mod" on the RH wing when i accidentally unplugged the connector from the two servo leads coming out of the fuselage. After plugging them back in, now the only thing that works on the wing is the nav light. No gear, no aileron and no flap. I moved the left wing over to the right side, plugged that in, and it worked fine. Any ideas? Thanks in advance.
