So you see squawkers he does no come equipped with data
so lets move on with the F3A motors. I have 2 of the 14 poles wound. After testing the 4 + 4 the Kv was a little high 1017 for the dual layer and 980 for the single layer 8 turn.so we wound a 4+5 traditional parallel wye. Im going to let you hear it. You pick up the electrical noise right away. As I understand people had problems with the 14 poles but what I wound is definitely more fill than the factory winds. they should be a little cleaner because they are originally delta machines. From here with a D3 inverter id want the single layer but i cant send them that in middle of season. Im going to prepare some single layers for f3A but I want slot wedges to to raise the winding factor and protect the rotor and pm from slot harmonics and ultrasonic vibration..
I have even thought about finding a way to deaden the stator. Like Dynamat my boys. That will help thwart the core ringing. anyone that knows a little about car stereo knows I am not making this up. I was heavy into through high school and college. Im MECP certified in 12 volts and have been for about what 38 year. I worked with people like Hugh Cobb (Factory Rockford Fosgate sponsored Competitor) from Reidsville NC and Jay Lovelace at Creative Acoustics in Raleigh NC. They both won the IASCA worlds several times..
Jay had 16 cerwin vega stroker 15"s in a chevy astro van. You can NOT sit in the car the SPL will not allow you to hardly breathe YOU def lose all your hearing in flash you're talking 171 db was the world record its prolly alot more now.
To deaden the vehicle he had about 6 inches of concrete poured across the floor of the van . The windshield was braced with an I beam and was about 6 inches thick of LEXAN.
so lets move on with the F3A motors. I have 2 of the 14 poles wound. After testing the 4 + 4 the Kv was a little high 1017 for the dual layer and 980 for the single layer 8 turn.so we wound a 4+5 traditional parallel wye. Im going to let you hear it. You pick up the electrical noise right away. As I understand people had problems with the 14 poles but what I wound is definitely more fill than the factory winds. they should be a little cleaner because they are originally delta machines. From here with a D3 inverter id want the single layer but i cant send them that in middle of season. Im going to prepare some single layers for f3A but I want slot wedges to to raise the winding factor and protect the rotor and pm from slot harmonics and ultrasonic vibration..I have even thought about finding a way to deaden the stator. Like Dynamat my boys. That will help thwart the core ringing. anyone that knows a little about car stereo knows I am not making this up. I was heavy into through high school and college. Im MECP certified in 12 volts and have been for about what 38 year. I worked with people like Hugh Cobb (Factory Rockford Fosgate sponsored Competitor) from Reidsville NC and Jay Lovelace at Creative Acoustics in Raleigh NC. They both won the IASCA worlds several times..
