Thanks brother, it was great feeling flying it. Looking forward to more flights :)
Official 3DP Thread
Recently I tested a black ABS print against the summer heat. Left the pieces out in 94 deg F weather on asphalt for about 20 minutes. Surface temperature reached 141 deg F with no signs of softening or warping.
I have some "black bird" designs planned after validating this, and I already started on the first one. Should have something to show in the next week or 2
1 Photo
- Likes 2
Originally posted by Dirty Dee View PostRecently I tested a black ABS print against the summer heat. Left the pieces out in 94 deg F weather on asphalt for about 20 minutes. Surface temperature reached 141 deg F with no signs of softening or warping. I have some "black bird" designs planned after validating this, and I already started on the first one. Should have something to show in the next week or 2.I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
You'll never be good at something unless you're willing to suck at it first.~Anonymous~
- Likes 3
Originally posted by Dirty Dee View PostCool, I'll keep that offer in mind. First plane I plan to tackle would be the U-2R before I move onto the SR-71 and F117
- Likes 2
Originally posted by RCjetdude View Post
If you could make a 3D printed F117 it would save me a lot of time scratch building one but I am not going to hold my breath as I am sure it would be a ways off.
- Likes 2
Here is something I found out from others and tested out myself.
If you have a 0.4mm nozzle, you can use that nozzle as a "0.3" or "0.25"mm nozzle by altering the settings in the slicer. Obviously, the prints may turn out a better quality with the actual 0.3 or 0.25 nozzles, but this is an easy way to try out finer printing. You just need to make sure to bump down the layer height to 0.15mm for 0.3mm nozzle settings, and 0.1mm for 0.25mm nozzle settings.
Attached picture of the U-2R horizontal stabilizer printed with a normal 0.4mm nozzle setting, and another with the fake 0.3mm.1 Photo
Originally posted by Dirty Dee View PostHere is something I found out from others and tested out myself.
Attached picture of the U-2R horizontal stabilizer printed with a normal 0.4mm nozzle setting, and another with the fake 0.3mm.I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
