    That's a good option if you have a decent paved surface. Many of us fly to and from grass. Little wheels don't work for take off and make landings even worse.
    Having a good launch system might even save a few friendships
    You mean when your buddy is supposed to hand launch your bird, but instead spikes it into the dirt like a football?
    • Evoman
      • 567
      I had the very same thing happen to me when I had a friend hand launch my Dynam Hawksky. But it was not even his fault because the elevator was not working. Had I attempted to take off normally with the wheels the airplane would not had even taken off resulting in less damage.
      Ever since then I don't care for hand launch airplanes.
      • Gary42
        • Mar 2019
        • 3
        Flightline models are superb, I've got the 1600mm Spitfire and the P-38 Lightning and they're both awesome.
        Please, please, please can we have a 2000mm Flightline Avro Lancaster, one of the best, if not the best, heavy bomber of WWII.
        • NoDirt!
          • 183
          80mm F-105 would be awesome!
          • Hoomi
            Cactus Dodger
            • Apr 2018
            • 863
            • Baja Arizona
            Originally posted by Phantom
            I've seen F-15's use the tail hooks for static full burn engine runs, but never to land. Where did that happen? I figured that the landing gear and tail hooks are not built for deck style landing on an F-15.
            Well, in at least one case, an Israeli F-15 needed the tailhook for an emergency landing, though it didn't hold.
            • Skyboom
              Foam flyer
              • Nov 2018
              • 344
              • Chilliwack, British Columbia, Canada
              All I can say is WOW! Thanks for sharing that remarkable video Hoomi.
              • wvrailfan
                • Sep 2013
                • 682
                • West Virginia
                A fellow flyer and I were talking the other day about how technology has really helped the hobby. Since on board stabilization has become reliable and common, perhaps some models that may have had control issues when scaled down to affordable RC size would be less problematic now. Maybe Flightline could do a big 1800-2000mm YB-35? With any of the stabilized receivers on the market, including Admirals, it could be made into a relatively easy to fly platform.
                The contra rotating props were really neat, but I bet that would drive the cost of a model up, so they could do the late version that had standard four blade props. At that size, the wheels should be large enough to handle well kept grass.
                Anyone else think a large Flying Wing from Flightline would be cool?
                • AirHead
                  • 313
                  • TorCan
                  I mentioned the LANC a couple of times, but FlightLine produced the B24 Liberator which has been pointed out as being a similar match to the LANC in the "Ugly Bomber" category. The best looking bomber was/is the B17. But, it's not offered anywhere except HK which is always "Out Of Stock"....A revisited and upgraded B17 would be a "huge" deal....
                  • Phantom
                    • Mar 2019
                    • 504
                    • M.D.
                    True, watch that video many times
                    • Evoman
                      • 567
                      I had seen that F-15 video before its good! Here is another good video about the A-10 making it back after getting hit with a SAM!
                      • Jets and Wings
                        • Oct 2019
                        • 103
                        • Aachen, Germany
                        A Tornado having 90mm would be awesome. There are hundreds of planes possible to customize!!!
                        • Chrys
                          Chrys
                          • 41
                          • FRANCE
                          J'aimerais un beau Rafale et Mirage 2000 en 90mm.
                          Un C-130 ou B-29 en 2000cm .
                          F-117 , SR-71, B1B Lancer en 80 ou 90mm .👍🤙😉🤪
                          • Ice2262
                            • IL
                            I would like a mig29
                              Welcome Jets & Wings and Ice2262! Glad you guys are here! Jerry. Greetings to you
                              Chrys!
                                • 8819
                                There's this one ............................ https://www.bananahobby.com/12-ch-bl...f-jet-arf.html
                                Freewing did make one for SebArt. I have two of them. They are now discontinued. I believe Freewing has destroyed the molds. Chances of them making another one is low.
                                • Zoomer02
                                  I vote for a 90mm F-105 Thunder Chief with an 8s option!
                                  • lauterbacher
                                    • Oct 2017
                                    • 5
                                    Yep a 90mm Thunder chief is the way to go. And a 90mm F 117 or a proper sized B 2.
                                    • cashmoneybrother
                                      • Aug 2017
                                      • 69
                                      Thunderchief, 80mm mig 15, f8 crusader 80/90mm.. Whatever just keep those new planes coming. There are now other options too. So we have alot to choose from now FMS Hk Eflite.. Plus 3d labs and Aerotetris make cool stuff too.
                                      • Woodcock
                                        Old Returning Pilot
                                        • Apr 2018
                                        • 830
                                        • SoCal
                                        You know I would love one of those, seriously no pun intended. When the F-22 came out, everyone was expecting an F-100, or I say many were expecting it. F-22 is a great plane, many love it. I'm just sayin.
                                        So we come back to a plane that is dear to my heart. The A-7 Corsair II. Awesome plane. Was a very popular model when jet hanger hobbies made it. Now no one makes it. At least that I know of.
                                        so a small group of hobby minded people decided to come up with a nick new name for this plane. and it caught on. So in the circles I run in, I see and awfully lot of would be owners wondering why no one is producing a model for this plane. But I think because of the new nick name. No one has even considered it. I don't fault MRC, they are just one modest successful organization. They can't make everything. It just surprises me that no company is making it. In my opinion it is a guaranteed winner.
                                        But so are all of those you just mentioned. One company can't do them all.
                                        Best Regards
                                        Woody
                                        • JohnVH
                                          • Nov 2017
                                          • 259
                                          • Lynden, WA
                                          F100 on 6s
