  • NCRealEstateGuy
    • 6
    Can someone tell us the size of the main gear wheels? Trying to determine if my LX brakes will fit.
      They look like they might be the same as the A-10?
      • seaviper
        ATC retired
        • Aug 2016
        • 1092
        • Philadelphia Mississippi
        Releases like this are making it harder for me to get that 3D printer...
        Exactly my situation. I was going to get a tronxy a5s.
        • seaviper
          ATC retired
          • Aug 2016
          • 1092
          Im assuming you guys tested the 6s 1550kv 12 blade setup like the other 90mm jets have as stock.
          What differences did you find between that and the 9 blade setup? Im thinking a 12 blade 6s unit might help me get out of the hay field easier. The rhino appears to be lighter tban tbe t45.
          • AirHead
            • 313
            • TorCan
            May God be praised....
            • Ron1950
              Retired ATC
              • Oct 2015
              • 887
              • brandon ms
              I want to see how it flys off and lands on Ryans short geotex runway...
              • t33jetman
                • 515
                I'm all in, order 300339.
                • RickVB
                  • 106
                  • Novi, MI
                  Yes, and did you test the 4068-1680kV 12-blade also?
                  • ryramZ
                    Pilot Ryan
                    • Dec 2012
                    • 814
                    Me too! Can't wait!
                    • Shirty
                      Hobby Squawk Water Boy
                      • 1067
                      • Perth, Australia
                      Wow, this looks awesome. Great job boys, did I mention wow this looks awesome? Thanks motion n freewing, I'm definitely down for one of these. :)
                      • ryramZ
                        Pilot Ryan
                        • Dec 2012
                        • 814
                        the mains are the same as the A10 nosewheel which is 2.75 basically, or 69mm. Of course the F4 nose wheels are much smaller.
                          8S Ultra Performance is now available as a pre-order. Please note the mid-May ETA forecast.
                          This is the bad girl I am going to snag when they are in stock.
                          https://www.motionrc.com/products/fr...phantom-ii-pnp
                            Let me guess, in the land down under it will get a "Blue Nose" ???? Ehhhh Wut Shirty LOL
                            • Shirty
                              • 1067
                              • Perth, Australia
                              Lol, no can't bugger this one up, I love the Vietnam camo, but I'll put some blue on it somewhere ;)
                              man, what a pretty jet. Can't wait to get one of these.
                                • 2137
                                • On planet earth....right
                                Not for a cost, bbaumer, the print files will be made available for FREE during the pre-order. We'll publish them later this month. :)
                                Now that’s some awesome stuff right there. :Smug:
                                  Problem solved! Nothing a little rattle can action can't fix! :)
                                  • bill34207
                                    Jet Junkie
                                    • 455
                                    • Bradenton, Florida
                                    +1 on the SEA camo Shirty. That and the 9 blade 90 sold me on the 6s stocker. I originally ordered the ARF+ when I thought it was coming with a 12 blade that needed a 150 amp ESC. After it was noted here in the thread (and fixed on the website) went back an changed to the PNP.
                                      You could always do the reverse canopy trick they use to do. Paint an underside canopy, just make it a lighter blue so YOU don't mistake top from bottom. :)
                                        • 7415
                                        Maybe a blue helmet for the pilot!!
                                        Congrats to everyone who pushed for this bird, it look awesome, can't wait for Mike and Ryan to get their hands on it.
                                        Even better (or worse depending) when Steve gets through with his!!!
                                          Already considering operable canopies with the 3D printed cockpit parts. This beauty looks so good I am not sure it needs much more. Maybe a center burner or AB of some sort. Can't wait. Very stoked.
