  • Jhnybgd
    • Dec 2017
    • 262
    I also am running Jetfan 90mm 8s setup from from Gary at Efflux RC.
    Using 2 4s 5000 60c admirals
    2 venom 5000 50c
    0r various 6s 5000 45-60c with admiral 2s 5000 50c batts
    I set my timer to 3 minutes,drop gear at 3 do a gear pass and land,after taxi back almost always am at 25-30% left and batteries barely warm.
    When flying any of my 6s EDF the batteries always come down hot,I think(uniformed as I am)that battery longevity will be the most benefit of running 8S.
    Also I can take off less than half throttle and have pushed flight time to 4:45 with a couple of go arounds and still end up with 18-20% in batts.
    I really doubt a 6s setup would have given me the confidence to stretch the flight time like that.
    • lomcevac
      • Dec 2017
      • 24
      • Salisbury, NC
      2 venom 5000 50c
      I need to call him and see what he would recommend.
      • Westcoloflyer
        • Dec 2017
        • 4
        For you guys using latex house paint from Home Depot or Lowes what are you thinning it with and how much to airbrush it?
          • 4869
          Westcoloflyer, welcome to posting on the 'Squawk'. I used the HD Behr Marquee (3 separate colors) exterior latex in semi-gloss on my FW A-10. I thinned the paint with distilled water to a thick milk consistency and the ratio seemed different with each color, go figure. I know this seems vague but that is my best description. The thinned paint has less pigment obviously so I also hand painted the thinned paint with a foam brush and either way it took a minimum of two coats to get decent coverage. In my case using a Paasche dbl action airbrush my coverage was sloooow and I had to back flush the airbrush many times as the paint would dry quickly at the tip. Don't know what gun you are going to use, but water is the go-to for me regardless though I will use a different paint gun for the large areas on my FW F-4. Hope this helps. Best, LB
          • lomcevac
            • Dec 2017
            • 24
            • Salisbury, NC
            I used Latex to paint a Ziroli Corsair and I used the old blue automotive windshield washer fluid to thin the paint. Also added Flotrol to help smooth the paint. Turned out great. As for the right amount of thinning... that will depend on the color and also the gun that you use to spray it with. I just tested small amounts first. And no, the blue washer fluid does not change the color of the paint. :Cool:
            • lomcevac
              • Dec 2017
              • 24
              • Salisbury, NC
              Here is a great article for information on painting with latex. It is under the "How To" tab.
                Good articles!!!! Thanks so much. :Cool:
                • amgsky1
                  Grip and Rip
                  • Apr 2018
                  • 39
                  • Kings Park, NY
                  Hi Guys. I finally had a chance to take a few photos. - TG
Name:	F-4 photo 1.JPG
ID:	137920Click image for larger version
Name:	F-4 photo 2.JPG
ID:	137921Click image for larger version
Name:	F-4 photo 4.JPG
ID:	137922Click image for larger version
Name:	F-4 photo 3.JPG
ID:	137923Click image for larger version
Name:	F-4 photo 6.JPG
ID:	137924Click image for larger version
Name:	F-4 photo 5.JPG
ID:	137925Click image for larger version
Name:	F-4 photo 7.JPG
ID:	137926Click image for larger version
Name:	F-4 photo 8.JPG
                  • lomcevac
                    • Dec 2017
                    • 24
                    • Salisbury, NC
                    Very Nice!
                    • EA-6B Geek
                      EW Misfit
                      • 485
                      • South Central Ohio
                      That looks great! Love your weathering effort, I can't bring myself to try that yet. Are the MK-82s 3D printed?
                        Awesome stuff!!! Great job! :Cool:
                          Very nice! Another sweet livery job. Well done!
                          • Helmsman52
                            • 247
                            • Saint Paul, MN
                            Looks Great!!!
                              • 4869
                              [QUOTE=amgsky1;n137919]Hi Guys. I finally had a chance to take a few photos. - TG
                              amgsky, Beeeeeuuuuteeeful....Diggin' all the Navy/Marine liveries...and that from an old zoomie. LOL Best, LB
                              • MikeT
                                Here......Hold my beer.
                                • 1060
                                Great work.
                                Mike
                                • BreakX101
                                  full throttle or no throttle.
                                  • Jun 2018
                                  • 26
                                  • clarksville
                                  Last night after assembling my f4 I noticed my rudder push rod was short and unable to center the rudder. after taking the ball link off and measuring the length mine was 80mm and not 87mm per the manual. if anyone runs into this problem Motion has sent me a replacement set already so just let them know.
                                    Thanks! And welcome to the Squawk.
                                    • BreakX101
                                      • Jun 2018
                                      • 26
                                      • clarksville
                                      Thank you!
                                      • BreakX101
                                        • Jun 2018
                                        • 26
                                        • clarksville
                                        thinking of adding this behind the battery compartment for the good old smoky f4 look. https://www.motionrc.com/products/mr...tric-rc-planes
                                          • 4869
                                          BreakX101, Welcome to the Squawk! Would like to see that, thought about similar, still thinking about how to make vapor blackish. Looked at 'magic' smoke systems, still pondering the how. :Confused: Post pics and ideas, please. Best, LB
