  • Waconut
    • Feb 2020
    • 310
    • Cincinnati, Ohio
    Maiden Report:
    I put my F-18 up for 2 flights first to loosen my thumbs up. We had 8mph wind straight down the runway. On the takeoff roll I hit a small bump in the runway and the plane bounced into the air and at the same time the right drop tank decided it wanted to stay on the runway. To say the least I was pretty much screwed and it was on from there. I was able to recover and gain some altitude but the jet did not want to turn and kept trying to roll over on it's back. As I got it turned back downwind I turned on the unproven HobbyEagle A3 Pro guyo and that helped a little to stabilize the plane. After making 5-6 saves I was able to make a fast landing approach and put the plane down in one piece.
    After cleaning out my shorts and taking a break I removed the other tank and put a 2nd flight on. The wind had increased to 13mph and was gusting and on top of that it started to sprinkle. The 2nd flight went pretty good. I can't wait for next weekend to hopefully get it back out and get it dialed in.
    Here is a video of the first flight. I will work on the video of the 2nd flight and upload it later.
      • 4838
      Originally posted by Waconut
      Maiden Report: After cleaning out my shorts...I can't wait for next weekend to...get it dialed in.
      WN, Your debrief sounds like SOP. Congrats, Sir. Best as always, LB
      • locharrow
        • Feb 2020
        • 283
        "Here is a video of the first flight. " Well saved W.. Generally mine will lift off as nice as ninepence but I've had that sort of fright myself when it wanted to go vertical. I thought it could have been kicking up on the rough ground..... post flight analysis has to wait.......the pants take priority. :stuck_out_tongue_wi
        • Waconut
          • Feb 2020
          • 310
          • Cincinnati, Ohio
          There is a little dip in the runway there and I hit it which sent the plane into the air and knocked the tank off. Still can’t believe I saved it.
          Here is a video of the 2nd flight. Much better. The winds had picked up and gave me fits when I turned cross wind.
          • n99jh1
            • Jun 2015
            • 20
            • Hartsville, SC
            I need help, please.
            I connected all the servos to the main board per the wiring diagram in the manual and bound the receiver to my DX 18. When i turn my Rx "on" and than plug the 6S 5000 mAh Lipo in the airplane, I get a beeping sound that stays after the Rx stabilized. All controls work except for the motor. It makes a beeping sound and the fan rocks back and forth.
            Does anyone know what is the problem? Thanks for any help offered.
            Josh
              • 5398
              Calibrate your ESC.
              • GliderGuy
                • 1408
                Josh
                Try reversing the throttle channel on the transmitter. That should solve the problem. This was what MRC help chat told me, and it worked!
                Then If that works...calibrate your ESC, for sure.
                Also, consider beefing up the elevator push rod and also search this forum on the word “ferrite” and read those posts. Make sure the elevator servo is secure!!!!
                I lost #1 bird twice (First Crash was repairable) due to these things. Bird # 2 is good!
                Click image for larger version  Name:	8D423616-0402-4DCA-BBD9-6A73FDC7B83A.jpeg Views:	0 Size:	138.8 KB ID:	279964
                • n99jh1
                  • Jun 2015
                  • 20
                  • Hartsville, SC
                  Thanks Evan and GliderGuy.
                  I calibrated (armed) the ESC and it works as it should now.
                  Another question:
                  Ultimately, I plan to convert my F-4 to the long nose F-4E. I know that the RCGEEK website offers a printed, full conversion package. Has anyone here performed such a conversion?
                  Thanks
                  Josh
                    • 5398
                    RCjetdude did. I did a Blue Angel scheme with needed the bulge under the nose removed but kept the stock length.
                    • GliderGuy
                      • 1408
                      Another question:
                      Thanks
                      Josh
                      Just wanting to make sure about the use of the term "armed". Can you go through the process you used to calibrate the ESC for our review? Thanks.
                      • n99jh1
                        • Jun 2015
                        • 20
                        • Hartsville, SC
                        Yes, sure.
                        1. Turn Tx "On".
                        2. Move throttle stick all the way up.
                        3. Plug the battery to the ESC. There will be 2 beeps.
                        4. Move the throttle all the way down.
                        The system will reset itself - the ESC learned the UP and DOWN limits of the throttle stick.
                        The fan will now respond to throttle command.
                        • n99jh1
                          • Jun 2015
                          • 20
                          • Hartsville, SC
                          Thanks Evan
                          I found RCjetdude thread - pretty much answered all my questions.
                            • 5398
                            Awesome, post pics when you get it done please.
                            • GliderGuy
                              • 1408
                              n99jh1 - Yes sir! Thanks.
                              • n99jh1
                                • Jun 2015
                                • 20
                                • Hartsville, SC
                                The FW T-45 Goshawk has this Fan / Motor:
                                Freewing 90mm 12-Blade EDF 6S Power System w/ 3748-1650kV Motor
                                Freewing 130 amp esc with BEC
                                Both the F-4 and T-45 are similar in size and weight but I think that the T-45 has a much more authentic jet sound to it. Any reason why its fan/motor will not work well in the F-4?
                                  • 5398
                                  Well, it can be used. From Motions site...
                                  This brushless outrunner motor is used primarily with the following Freewing jets:
                                  • 90mm F-16
                                  • 90mm T-45
                                  • 90mm F-104
                                  • 90mm Stinger 90
                                  • 90mm Venom
                                  • 90mm F-15
                                  It can be used with other aircraft with compatible specifications (see below).
                                  My opinion would be a higher power inrunner or go 8S or even better Fan Jet/ HET 8S.
                                    • 2696
                                    Maiden Report:
                                    Nice Save!! You are definitely a "Steely Eyed Missile Man".
                                    • N4Speed
                                      • Jun 2020
                                      • 50
                                      • Dallas TX
                                      I bought an Eflite F-4 and really enjoyed it. I am now looking at FW F-4.
                                      I noticed FW has 2 version, 6S with 9-blade fan and 8S with 12-blade fan. I appreciate any tips regarding these 2 versions.
                                      Also if someone here has both Eflight F-4 and FW F-4, how do they compare/differ?
                                      • themudduck
                                        -TMD- Foaming at the Mouth!
                                        • 1041
                                        • Burton OH (near Cleveland)
                                        I have the FW F4 and a friend in my club has the Eflight one - which I've flown (I'm one of the club's instructor so I end up flying everyone's planes, LOL). Basically the main difference is that the FW is bigger and heavier - a big brother - and it has a little more detail and more refinement (like the removeable missiles and fuel tanks). Both of them fly really well. The Eflight one is vey fast and has A3X which helps smooth it out, and I put a gyro on mine which helped it a lot. Eflight is 80mm, FW is 90mm so you'll get a little longer flight time on the eflight.
                                        I don't have the 8S version of my FW F4, I am using the 6S stock. From what I've read here, the 8S version is a little faster (but not extremely so) and will drain the batteries fast. But I don't have any experience with the 8S. I'm sure others here will give you their opinions!!
                                        • evensen007
                                          • Jul 2020
                                          • 101
                                          • Asheville, NC
                                          One thing hobbySquawk could really use is stickied posts. I searched around a bit, but if someone would indulge me:
                                          For the 8s version (I'm using 2x4000 HRB 4s packs), has the experience been to follow the throws, default elevator position, flaps-ele mix settings, and CG noted in the manual? Going to maiden and wanted to hear your experience. Is it the typical 'shift back the CG from what MRC recommends'?
