Yep, on its way! It's going to be a long winter before it flys though.......
I like the hobbystar packs because they have more capacity for a given weight. For example, their 4600mah 4s 35c, which weigh about as much as an eflite 3000mah 4s or Turnigy Graphene 2700mah 4s. I don't use them in anything pulling anywhere near 35c, realistically only 15-20c tops, but I get great flight times from them.
Those 4600 packs won't work here though, as they only have xt 60 plugs, but they sell a 5200mah 8s pack with xt90 that only weighs like 850g. Little pricy at $130, but the flight times with that low weight would be really good.
I have the 8s version on the way, so everything I say goes out the window for 6s. I have no experience with their 6s packs. Probably very similar though.Originally posted by JayP View PostI like the hobbystar packs because they have more capacity for a given weight. For example, their 4600mah 4s 35c, which weigh about as much as an eflite 3000mah 4s or Turnigy Graphene 2700mah 4s. I don't use them in anything pulling anywhere near 35c, realistically only 15-20c tops, but I get great flight times from them.
edit: dang, I hit quote instead of edit.
yeah I love the hobbstar parks. I have 8 of them now. The 35c 4600s and 5200s are incredibly light and perform well. The 45c 5200 is even better. I plan on using the 5200s in the f22. As well as my gens ace ,chl and heavy duties. I will be using the fms edf in mine. The 70 and 80mm fms fans are so chill amps wise on the batts though. The batts get much hotter with the freewing outrunners so much so that I wont use the 4600s in the L39 or Red Avanti anymore but in the fms bae 80 no problemo they are by far the best pack for 70 and 80 fms fans.I think the 35c hobbystar packs are more truly 25c but they are so light it's worth it in most applications. I'd recommend the 45c rated ones (truly 35c probably lol)for the freewing outrunners however
Welcome to Hobby Squawk!Originally posted by EDJEFF View PostF-22 8s delivery tomorrow, must have got the tail end of the preorder as I ordered really late. You guy Rock !
I concur. This has got to be the biggest battery compartment out of any foam plane I've ever seen. Seriously, it's large enough to swallow the entire U.S. deficit.Originally posted by purduephigam View PostFor the record, the battery bay is incredibly cavernous. Plenty of room for just about anything.
Sry to derail, Amazon cams are 1080 p super clear and service is free up to 3 cams, also viewable and recordable via phone app. I have 3 and glad I did get it as I caught someone stealing oil out of my heating oil tank last year.Originally posted by Flanker271 View PostOut of curiosity what type of camera are you using? I've been thinking about installing a outdoor security camera, but doesn't really want to drill holes in the wall to run wires. Arlo Pro looks pretty attractive but the battery doesn't last very long.
BTW Thank you Motion/ for the fast shipment, The craftsmanship and design is beautiful ! Not so sure about the UBEC on the 8s version, would have been great for the Bec to be intergrated in the Esc.
And the anti spark is a great add though !
I just Can’t help myself I’ll be out to the field tomorrow.
In freezing N.J.
Flanker, We use Arlo and like 'em a lot. We have 6 cameras on 2 systems all outdoors. I did have to drill for mounting on 3 of these but used their mounts and it took longer to 'aim' the cameras than it did to do the install. Worth it for us. No real programming, just scheduling and battery replacement about once a year. Just my $00.02USD. Best, LBOriginally posted by Flanker271 View PostOut of curiosity what type of camera are you using? I've been thinking about installing an outdoor security camera, but doesn't really want to drill holes in the wall to run wires. Arlo Pro looks pretty attractive but the battery doesn't last very long."I am having an extraordinary ordinary life."~Lucky B*st*rd~
"You just need the will to do what the other guy wouldn't."~Keyser Soze~
Awesome, thank you! By "battery replacement" do you mean recharging the batteries? Or actually replace them? Okay, now back on topic ...:)Originally posted by Elbee View Post
