Not to get too off topic but I use Arlo Pro at my house. No wires, super easy, works really well. I've only had it 2 months but it looks like I'm another 2 months from needing to charge the cameras. It sounds like most people get 2-4 months before charging. Not to be confused with the original Arlo which did not have rechargeable batteries.Comment
I got my 8S bird today and this thing is a beast if a plane. New style of hinges make them almost invisible. Nice touches all around and I don't feel the need to re-paint it! LOL Everything worked perfectly and I noticed no slop in my aileron and flap hinges. I plan to fly it stock and will then do a few mods. Cockpit detail, opening canopy, RC Geek center burner and nav lights. Anxious to try out this new 1390kV fan. Overall I am very impressed with it so far. When I first opened the box I thought the vertical fins were the wing... :Silly:
Make sure you check your plane out carefully. I have approximately a 12" seam that is not sealed/connected. It's the right side of the battery area/right intake. I went ahead and added some medium CA. If I want a little better seal, I'll add a strip of fiberglass and 30 minute epoxy. I don't think this is a structural area and will affect the overall strength of the plane. I'll update after my first flight, likely next Monday.1 PhotoComment
Got mine put together last night. I did notice with certain flap deflections and certain rates for the ailerons, the aileron hits the flap. Also, one screw for each stab are too long and won't screw in flush where it is supposed to sit. Watched the build video James did and looked close and his seemed to be the same way though.1 PhotoComment
No interference with flaps and stabs on mine. I don't think the screws are intended to sit flush that hold the stab pivot rods. Mine stick out too. I did also like the ball bearings inside the stabs, very smooth.Got mine put together last night. I did notice with certain flap deflections and certain rates for the ailerons, the aileron hits the flap. Also, one screw for each stab are too long and won't screw in flush where it is supposed to sit. Watched the build video James did and looked close and his seemed to be the same way though.Comment
Well that is interesting! It was one of the first things I noticed when going over the plane as I was building last night. Before I connected the control rods on the ailerons or flaps and was moving them around looking at the hinges, I noticed at certain angles they can touch and interfere with each other. Maybe they won't with the rates per the manual since I haven't measured my rates yet to set them exact. But, they definitely can touch with the flaps deployed at a decent amount and pretty high rate on the aileron. I'll take some pictures tonight. But, if anyone else is building, check to see if yours can interfere before putting the control rods on please!Comment
