View Post
What i I have found to eliminate the need for elevator trim when flaps are used is to put a 5-8 second delay on the flap channel. So far this has worked on four different models.
Guess ill I’ll find out if this applies to the F22 in a few hours. I’m using a standard 7 channel (no gyro) rx in this one. Good luck with your maiden.
John
) mix with full flaps, manual CG at 150mm.
