  • downwindleg
    • 1279
    • Friday Harbor, Washington
    Sounds like a missing tooth or two on the drive gear of the potentiameter......aka bum servo. BTW I finally flew mine for the first flight after the terrible maiden landing. All dialed in and flying great but the nose gear gave out on landing. Looks like the original damage to the underlying foam is too much. Gonna have to replace the fuselage and switch everything over. All because I failed to set the ailerons to indicated throws when setting it up originally.:Loser::Crying2: Sure wish you could get replacement ailerons without having to replace the whole wing!!
    • Pogo
      • 452
      • Waterford, Ontario, Canada
      Could you make it (them?) out of balsa Brad? You know, that wood stuff...:)
      Tom
        • 5416
        Are you using a gyro?
        Originally posted by Rcfiddy1
        Anyone replace the elevator servos and if so what servos did you use? I can’t seem to get this bird dialed in. The first few flights were great but now she doesn’t want to stay stable. On the ground the servos work fine but I did notice the elevator servos a bit notchy and not smooth.
        • downwindleg
          • 1279
          Tom
          Hey Tom, yes I could. Just need to replace the last inch or so of the trailing edge of the starboard aileron. Just being lazy.;)
          • Rcfiddy1
            Professional Crash Test Dummy
            • Aug 2015
            • 186
            • Manalapan, NJ
            I do use a s8r with built in gyro. My gains are turned almost off and when testing I shut off gyro but still have a unstable plane.
              • 5416
              The reason I ask is I’ve seen a gyro cause an itchy servo. Even with the gyro function off.
              • janmb
                Slow and low
                • 729
                Originally posted by Aros
                I can't get over how light the F-22, F-4 and other New Gen jets of ours are
                Definitely agree on that!
                I'm flying my F-22 stock 6S and totally love the things you can do with it - which is very much a direct consequence of weight.
                Had some interesting 8S vs 6S discussions on FB and other places, and a lot of people seem to not appreciate the impact of weight (and lack thereof) nearly enough.
                • janmb
                  Slow and low
                  • 729
                  I'm using Turnigy 306G for mine. Amazing speed, precision and power in a very small package. You will have to pad it a little bit though (it is slightly smaller in most directions).
                  • Pheonix
                    • Aug 2013
                    • 670
                    Mike, I read your post and went to the link. Are you offering a service or what? I am not sure I got this part. Thanks.
                    • Pheonix
                      • Aug 2013
                      • 670
                      After reading much on the CG, I decided to see where my CG was using the Xicoy machine and the 5000 battery. The wire clutter is from the after burner lights and so forth. I have not flown yet; therefore I cannot comment on how this CG behaves. It worked well with my other planes.
                        I created a new thread to report blue box issues. If you've had any issues with it in any of the 3 planes it has been released in (L-39, F-22, F-18), please post the details on this thread:
                        • The RC Geek
                          Flying jets and living Danger Zone free!
                          • 73
                          I finally got a chance to see one of these babies fly in person as one of our club members has one. Seems like a really sweet ride with a great speed envelope! Here's a quick little video from one of his flights.
                          Chris
                          http://thercgeek.com
                          http://youtube.com/thercgeek
                          • janmb
                            Slow and low
                            • 729
                            A little example of what this bird can do in the slow part of the envelope :D
                              Wow! I know what I will be working on in my next flights! :Cool:
                                • 5416
                                Install TVs first...
                                  Oh I didn't realize he had TV...I guess I should have guessed. :Silly:
                                  • Radar-Guy
                                    AirBorn Jetworkx
                                    • 364
                                    What a great model, it’s so much fun to fly. Thanks to Geert and Peter for the videos!
                                      • 5416
                                      Aros, he doesn't have TVs. I have them on mine and it makes it so much more fun.
                                      • janmb
                                        Slow and low
                                        • 729
                                        Thanks, that's exactly the reaction I was hoping for :D
                                        I don't :D
                                        Perfectly stock 6S F-22.
                                        (actually a lie, I replaced the elevator servos due to stuttering, but that's it)
                                        • janmb
                                          Slow and low
                                          • 729
                                          Yeah I have been considering it. Have flown a lot of SU-35 so kinda know what I'm missing out on. The flip side is weight. The ridiculously low weight on my current setup is making it sooo much fun, so I definitely am reluctant to add any
