Not sure if anyone else has this problem. My canopy was always a bit fatter than the fuselage. After a little work, I feel it fits much better.
Originally posted by Bobaroo View Post
Howabout a 'Spoiler' Goon,... You've seen them Fly and had your hands on the Sticks I'm Guessin' .... You going for Lightweight SlowFlight with good Speed ?? Or..... Ballistic Performance on HighCell ??? I know you've got this already figured out !!! Hahahahaha. CheersCheck me out on youtube at https://www.youtube.com/user/gooniac33
ok well no more waiting needed! A friend had a kit plus for sale at a price I could not pass up! You will see it up and running very soon!!Check me out on youtube at https://www.youtube.com/user/gooniac33
Originally posted by Badwolf79 View PostNot sure if anyone else has this problem. My canopy was always a bit fatter than the fuselage. After a little work, I feel it fits much better.
Originally posted by C17loadmaster View Post
The 8s is a heavier 12 blade that runs at 1390 times 8 cells (11,120 rpm). Using 6 cells would only be 8,340 rpm... That being said, it might fly at sea level, on pavement, and would be a handful to keep airborne.
I bought the 8s version, and just bought (3) 2s packs to run with 3 almost new 6s packs (same brand and specs). If I had the same plan, I would just buy a 6s fan off RC Groups classifieds to use until wanting to fly 8s...
Or just fly 8s, being as the F-22 is actually pretty easy to fly.
FALSE!
I happened to reread this and can’t edit it. It’s not motor kV Times number of cells. It’s kV multiplied by Volts.
By looking at the time I posted that I think I shouldn’t have been on the squawk...
Received my 8s F22 last week. All the parts look good (no damage from shipping as far as I can tell) Now researching what I feel the best radio/receiver combo will be.
I'm taking some queues from you guy's on this site as well as reviewing input from the same guy's on RC Groups. At this point I'm not sure if I should stay away from Spektrum 8000 series or not, but the research continues.
Just wondering if anyone else is dealing with a very flimsey nose-wheel like iam. This nose wheel is designed very poorly. They mount the steering servo in a piece of wood, you would think they mount the wheel shaft base assembly on wood also. Its just glued into weak foam? Really? I have about 10 flights on my jet and the nose wheel is now soo wobbly and weak i couldn't even take off earlier today. Really screwed up my wing tips after the nose wheel flexed one way really far and tipped the whole plane on take off. Again- this is under minimal, normal usage. Has anyone beefed theirs up a certain way? Great jet, but motion really missed the mark on the strength of the nose-wheel assembly.
Originally posted by Flightsss View PostJust wondering if anyone else is dealing with a very flimsey nose-wheel like iam. This nose wheel is designed very poorly. They mount the steering servo in a piece of wood, you would think they mount the wheel shaft base assembly on wood also. Its just glued into weak foam? Really? I have about 10 flights on my jet and the nose wheel is now soo wobbly and weak i couldn't even take off earlier today. Really screwed up my wing tips after the nose wheel flexed one way really far and tipped the whole plane on take off. Again- this is under minimal, normal usage. Has anyone beefed theirs up a certain way? Great jet, but motion really missed the mark on the strength of the nose-wheel assembly.
Haven't had a single problem with mine and I have at least 25 flights on mine.My YouTube RC videos:
Pavement. Haven't flown hard at all. The plastic mount didn't come loose, the foam its glued into softened up and now the shaft bends. I guess i have to beef it up somehow, with some wood or something. For the record, i do not fly anything i own hard. I keep well used planes for a very long time. Just disappointed in the design of the nose wheel mount on this one. Other than that the jet is a show stopper. Walking speed high alpha etc
Originally posted by Flightsss View PostPavement. Haven't flown hard at all. The plastic mount didn't come loose, the foam its glued into softened up and now the shaft bends. I guess i have to beef it up somehow, with some wood or something. For the record, i do not fly anything i own hard. I keep well used planes for a very long time. Just disappointed in the design of the nose wheel mount on this one. Other than that the jet is a show stopper. Walking speed high alpha etc
Just got mine last night!! Let the fun commence!!! Still not sure how I will power it... but we will get it up in the air this weekend if all goes well!!Check me out on youtube at https://www.youtube.com/user/gooniac33
