  • mribeiro
    • Jun 2020
    • 9
    Hi there,
    I have the Venom with outrunner 90mm 12 blade.
    I will buying the F22, but PNP only have the 9B inrunner HP.
    I love the sound of the Venom with 12B. So its so much different sound:
    F22 90mm 12B outrunner - old version
    F22 90mm 9B inrunner HP
    I dont look for max speed, i love more the sound then the speed.
    Tks for the help.
      Originally posted by Gary S.
      They can be really exciting at high speeds.
      Yes indeed!
        Well today I got mine to 135mph. Plenty fast for me. Really love this jet.
        Dang! That's blazing! Mine can smoke pretty good on a WOT pass but I'm not touching that top speed.
          • 5416
          My 8S does 126 flat level but that's air speed and not ground speed.
          Mriberio, easy to swap power plants in these planes and I'm sure you'll find someone willing to swap a 12 for a 9.
          • Gary S.
            • Apr 2020
            • 52
            • Fort Worth, TX
              Airspeed is definitely a better gauge for performance. This is just a blast to fly.
              • Av8er278
                • Jan 2021
                • 123
                • San Diego, Ca
                How many of you run a gyro in your F22? If so what brand?
                  I got my frsky s8r with a built in stabilizer, doesn't really need it, but it makes the plane even that much more smooth.
                    • 5416
                    Not me.
                    • Gary S.
                      • Apr 2020
                      • 52
                      • Fort Worth, TX
                      I have been using hobbyeagle A3 Super 3 in several of my EDF's really enjoy them gets it very locked in when setup right. All that said this plane fly's excellent without one. I just like it more with.
                      • WarbirdFan66
                        • 85
                        • Berlin, Germany
                        I use a gyro in mine aswell, graupners GR-12 3xG, which is build into the rx, it is comparable to spektrums AS3X system, works very well and makes it fly even better
                        • jaldendifer
                          • Feb 2019
                          • 14
                          A lot of flights on my 3rd 8 cell ( since it first came out). I'm using Aura on mine and it is awesome. Really allows you to extend the limits! Flies extremely well with out one, one of a few jets that do! I think overall it is the best flying jet out there still, probably because of the design of the F-22.
                          • Av8er278
                            • Jan 2021
                            • 123
                            • San Diego, Ca
                            Anyone have servos glitching? My left elevator servo is glitching but when I touch my radio stick it stops.
                            • john2kx
                              • 112
                              • North Augusta, SC
                              Originally posted by mribeiro
                              Hi there,
                              Tks for the help.
                              The Venom and DH112 have a unique sound generated from their ducting system. I have the dh112 and like yourself, wanted to duplicate that sound in another jet. I was told by several that I was wasting my time.
                              • Oachidori
                                • 52
                                • Bucharest, Romania
                                Hello,
                                For all they are already make the upgrade from EDF to X45 can tell me what is after modification the during flight? For 6S EDF i have around 3.5 min and i want to know if it is worth to make the upgrade?
                                On the other hand for who made the Starscream scheme, there is somewhere some kit to buy for F22 90 EDF? I want to make more visible, and add more black and in my opinion will be the easy option. Or if someone have the file to print myself will be also better.
                                Tks,
                                Badan Kit - Yak55M 2.8m; EF - Extra 300 2.3m; Multiplex - Funcub;Funjet Ultra2;Parkmaster;FW - F22 90-X45 Xicoy;ROBBE MISTRAL 2.0
                                • Con Papaioannou
                                  • Mar 2021
                                  • 40
                                  Hi All Frgot to add the cockpit mods. Click image for larger version
ID:	327437Click image for larger version
ID:	327436Click image for larger version
ID:	327435Click image for larger version
ID:	327434Click image for larger version
                                  • Shaun Evans
                                    • Apr 2021
                                    • 125
                                    • California, USA
                                    Hi Guys!
                                    Ok, if this is considered a no-no, then ok, but if I didn't want to read through the whole thread right away, but still wanted to know if there are any major issues I should know about before I maiden, can someone vector me to the best pages/comments?
                                    What are people getting for AUW? Is the listed CG what people are having the best luck with?
                                      • 5416
                                      I don’t remember any big issues when I first flew mine, loctite on the struts to the retract units… book CG is a good starting point.
                                      • Shaun Evans
                                        • Apr 2021
                                        • 125
                                        • California, USA
                                        Originally posted by Scale Master
                                        Well boys I finally got my "Star Scream" F-22 Turbine conversion complete! I waited for the new X-45 to com in @ 10lbs of thrust instead of using the slightly bigger and heavier K30 @7.5lbs of thrust! This motors diameter is smaller than a soda can. This Turbine is bad to the bone, high quality, light powerful with a 2 stage compressors. The pump is brushless, and the GSU is small and super light weight. Super easy plug and play set up, NO programing needed from you radio for throttle trim settings as it already knows you radios end points, unlike the kingtech stuff which required the "in learning" process to get things set up. The pics show pretty straight forward installation right where the old EDF unit was. Made the fuel tank with a 33.6 ounce Fuji bottle that squeezed right over the CG area, not using a UAT to save space, so I'm using a felt tip clunk and air trap soft cover over it. Jet has JP wheels and brakes (60mm). 3 lipo backs to power everything; 950mAh/brakes, 2000mAh-50C/ECU, and 2000mAh/Servos along with a BEC. See pics. If you have any question let me know!
                                        AUW?
                                        • Shaun Evans
                                          • Apr 2021
                                          • 125
                                          • California, USA
                                          Thanks, Evan!
