    • 5384
    I'm using a Talon HV in my 8S. I put a meter on it and its 5.8V. I haven't had any odd issues but only use the BB for retracts and lights.
    • downwindleg
      • 1279
      • Friday Harbor, Washington
      Can't wait to see all your mods! I too am waiting on Chris' centerburner. He must be backlogged pretty good. Hopefully #2 won't meet an early demise like the #1 so I can actually put it IN the jet by the time it arrives!
      I did get the ARF +. Just added the power system from #1 into it and she's good to go. Guess who will be avoiding light poles like the plague on her maiden!
      LOL
      Hey Todd, got Chris' centerburner in the mail today. Will do that and the airflow parts at the same time while I've got that bay open. Pulled the fan unit out and have to figure out how to remove the tail cone and replace with centerburner. Then wiring with the 2s admiral battery.:Cool:
      • bill34207
        Jet Junkie
        • 455
        • Bradenton, Florida
        That's what I had it for. It only offered 8.0 v and 6.0 v in the setup so went for the 6. (may only be 5.8 in real life). With mine (even though I had bypassed the board for rudder, steering and elevators after the rudders didn't work with gear extended) the landing light would not come on when 1st dropping the gear. Usually took a cycle left & right on the rudder to get it to come on. I swapped out to the stock 6s setup Saturday and now the landing light works like it should. On another note, the Scorpion backup guard that triggers when voltage drops below 5 comes on every time I wiggle a servo. While the Talon was in it, I flew it for 3 weeks without it ever kicking in at all.
          • 5384
          The only weird thing I found was when I first wired it I put a anti spark in with a resistor. When I used it the three flash light I added wouldn't flash and the ESC didn't do the 8 cell count beeps. The solid tip lights and the landing light worked and the ESC/ BEC did work as it was supposed to. I didn't like it and removed the anti spark. No issues since...
          • adb2@suddenlink.net
            Advanced Pilot
            • Nov 2018
            • 104
            • Abilene Texas
            Originally posted by JohnVH
            WINDY day flight, the Raptor bobbles around, check it out.
            Nice flight and good flying.
            • Drifty
              Old A/C mechanic
              • 55
              • Temperance MI
              Painted the rudder servos right from the start. also just installed the center burner afterburner. I think I`ll need it -17degrees with 25mph winds today. Great for flying!
                You will barely need a light jacket... LOL:Cool::Cool:
                • john2kx
                  • 112
                  • North Augusta, SC
                  Any tips or tricks to the center burner install? Should have mine Thursday.
                  Freewing A10, F4, F22, Sebart Avanti S mini
                  • AVIATOR DOM
                    • Nov 2018
                    • 5
                    I have a question for all Freewing F-22 8s version pilots, will this be
                    a good replacement for the stock 12 blade fan?...https://www.rc-castle.com/index.php?...+90MM+12+BLADE
                    • Alpha10
                      J e t - J u n k i e
                      • 377
                      • Chicago
                      Any news about if we're getting a clear canopy option for this one guys?
                      I remember some talk about it being a possibility.
                        • 8202
                        I second that!
                        • Drifty
                          Old A/C mechanic
                          • 55
                          • Temperance MI
                          Nope Just install like Chris says. I do set the ignite place before I install, just because it`s usually eaiser that way. I also lined the outlet with metal tape, easy to do on this aircraft.
                            • 8202
                            From YouTube...
                            • C17loadmaster
                              Retired USAF Aircrew
                              • May 2018
                              • 371
                              • Auburn, CA
                              Same as above... the glow will be much more realistic reflecting off the entire exhaust. Here’s the F-14 with aluminum ducting tape lined exhaust. I install the tape in long strips starting from Forward of the aft section of the fan housing (with the motor/fan out obviously) all the way back to about 1/2 in from the exhaust opening. This helps prevent thrust from unfeeling the tape and restricting airflow while airborne.
                              I also use a separate UBEC so I don’t have to deal with a 2S battery. I’ve done both... they all run 7.4v UBECs now. Don’t use anything with higher than 7.4v , ever. I also program mine to light at 80% throttle.
                                • 5384
                                This is a 5mm collet mount so it will mount to the motor. But until you try it you won't know if it will fit in the shroud or haw many amps and watts it pulls. If you do try it please let us know.
                                  • 8202
                                  Cool! Still waiting on mine. Check out the video I linked to a few posts back. Pretty easy install it looks like. I think I am going to go the 2S route as well versus UBEC. What size Admiral did you go with?
                                  • john2kx
                                    • 112
                                    • North Augusta, SC
                                    Thanks for all the center burner tips, guys!
                                    • john2kx
                                      • 112
                                      • North Augusta, SC
                                      Center burner install: on the aluminum ducting tape, how wide are you guys making the strips?
                                      John
                                      • downwindleg
                                        • 1279
                                        Yeah Todd, got mine yesterday and put it in this afternoon. Also going with the 2s. Soldered the battery terminals for deans connectors to hook up with the admiral battery. Wound up with a 1000mah Admiral pack as they didn't have anything smaller at the time. Guess I wont have to charge it very often.:)Haven't hooked it to the receiver yet . Working on Radarguy's streamlining pieces while everything is out. Could use a tutorial on that too.:Thinking: Got the spar teardrop in but having trouble fitting the other piece.:Confused:
                                        • Radar-Guy
                                          AirBorn Jetworkx
                                          • 364
                                          Let me try to give some more information on the assembly. The first pic shows how the fairing parts need to be arranged. Start with the two small parts, those are the front fairing for the spar. Use some high quality glue, you don't want any of the parts to hit the operating fan. Then add the rear fairing to the spar. After that, add the "sharp divider" part. It might be necessary to enlarge the rectangular vent hole in the foam of the stock divider a bit to get the vent extension to slide in (see second pic). The rear fairing and the divider should be installed in one action to get them properly alligned. That's it. Hope that makes sense.
                                          Did you install the nose gear brace?
                                          Frank :Goodbye:
