  • thisguy65
    • 509
    Those look like to be the inrunner
    I did a test a while back on the stock 12 blade fans vs the inrunners
    Thanks for all the support regarding the main landing gear plates guys! Have some parts in the works for the F-18 too
    Planes
    • SJN
      • Mar 2019
      • 7
      • Denmark
      Changed the stock scheme slightly. Just used Humbrol model paints and my airbrush to change the look a little. Humbol number 129, and 130 seem to be a verry close match to the stock paints.
      Only added a new air force insignia on the nose, as it was painteed over with the stripes. The yellow Tamiya masking tape is great. It does not pull paint off the foam.
      Click image for larger version  Name:	IMG_20200612_193539.jpg Views:	0 Size:	93.0 KB ID:	259555Click image for larger version  Name:	IMG_20200612_193633.jpg Views:	0 Size:	121.3 KB ID:	259556Click image for larger version  Name:	IMG_20200612_193548.jpg Views:	0 Size:	102.3 KB ID:	259557Click image for larger version  Name:	IMG_20200612_193528.jpg Views:	0 Size:	113.9 KB ID:	259558Click image for larger version  Name:	IMG_20200612_171245.jpg Views:	0 Size:	204.9 KB ID:	259559
      • N4Speed
        • Jun 2020
        • 50
        • Dallas TX
        The servo plugs in my F-14 are slightly larger than the slots in my Spektrum AR9030T RX. The RX came with an iX12 system. I've attached a photo, any feedback is appreciated.
        • Wild Man
          • 526
          • Rapid City, S.D.
          The ends are not larger where the difference is the ends on the free wing servo's do not have the 45 degree bevel deep enough to match the slot in your receiver. If you have a JR servo laying around take a look at the end and you will see the difference in the beveled plugs. What most of us have been doing is take an Exacto knife and make the bevel more pronounced you will find once making the bevel on you free wing plug ins deeper you will have no problem plugging them in. The servo ends free wing uses are a cheap Chinese knock off, and there are alot more manufacturer's using these JR knock off plugs to keep there costs down
          • N4Speed
            • Jun 2020
            • 50
            • Dallas TX
            Originally posted by Wild Man
            The ends are not larger where the difference is the ends on the free wing servo's do not have the 45 degree bevel deep enough to match the slot in your receiver. If you have a JR servo laying around take a look at the end and you will see the difference in the beveled plugs. What most of us have been doing is take an Exacto knife and make the bevel more pronounced you will find once making the bevel on you free wing plug ins deeper you will have no problem plugging them in just. servo ends free wing uses are a cheap Chinese knock off
            Thank you Sir!
            • N4Speed
              • Jun 2020
              • 50
              • Dallas TX
              I will be using a Spektrum iX12 for my F-14. I like how RC Geek has his F-14 configured, I have his setup file, but looking at some of the previous post on this thread, there seem to be problem with ailerons and flaps with the wings swept.
              I would greatly appreciate it if someone who has iX12 working with F-14 similar to RC Geek could email their setup file. My email is mfar700@outlook.com.
              • Johnnyrabuse
                winner wolf
                • Apr 2020
                • 136
                • NY
                Thank you Sir! I agree, what is a good beginner EDF?
                Also, any suggestion on radio? back when I was flying, Futaba, HiTec & Airtronics were the way to go, but I am not having much luck finding 9 CH plus in these 3 brands. The only Airtronics I found was developed 10 years ago and looks like they are no longer in business in USA. I found Futaba 10JA but it comes with 8-CH R3008SB Receiver.
                I am tempted to give iX12 a try but in most review sites, it only gets 3.5/5
                Bae hawk 70 mm cheap good gear easy landing red easy to see and it can do every trick in the book easy to transport and repair and the struts are thick wire you can bend back into place it also has lights it's a six cell ...
                If you want a four cell go with the freezing rebel long flight times on 3000 s
                • Davegr123
                  Super_Heli_Dave
                  • Mar 2020
                  Try this, I have it in my iX12,
                  • N4Speed
                    • Jun 2020
                    • 50
                    • Dallas TX
                    Thank you!! I'll give it a try.
                    • SteveO
                      Pilot
                      • Jul 2018
                      • 6
                      Hey guys, I've just started putting together my Tomcat and I noticed there is a little green circuit board (just forward of the main white mixing board where everything is plugged into) that a servo wire/connector hanging off of it. What is that and where does it plug into? I can't seem to find any information or directions on it. Thanks in advance!
                      • thisguy65
                        • 509
                        Does it have a red and black wire? If so that is the BEC, it power the RX
                        Planes
                        • C17loadmaster
                          Retired USAF Aircrew
                          • May 2018
                          • 371
                          • Auburn, CA
                          Originally posted by Door Guns
                          Thanks for the info. I'm hopping I can wet them wet and remove them.
                          Acetone will melt the decals away without hurting the foam at all. When just changing the aircraft identification, but keeping the original paint scheme, I just dip a Q-tip into acetone and wipe off the decals. You mainly want to make sure to get rid of decals that cover panel lines or any type of impression in the foam.
                          You, and most reading, probably already know this info... but I figured I would bring it up for the newer members.
                          **I am only referring to this airplane, do not try acetone it on an EPS airplane like the SU-35. It will turn into a puddle right before your eyes. I pretest all glue, paint and random build\repair techniques on scrap pieces prior to my project airplane.
                          • msidler
                            • Jul 2020
                            • 5
                            Has anyone tried the F14 in the Real Flight simulator and flown the Freewing F14?
                            If so, how similar is the simulator vs actual?
                            I have the Freewing F14 but have never flow it nor any other EDF. I can land the F14 in the simulator without bouncing about 8 out of 10 times with a 8MPH cross wind.
                            I'm wondering how different the real thing would be.
                            TIA,Mike
                            • mshagg
                              • 541
                              • South Australia
                              Very late to the party here but been having a blast building the tomcat up over the past few weeks. Lot of 3DP work has gone into it, from structural bracing and retract supports to a custom battery tray and an underbelly with naca intakes for ESC cooling.
                              First time using pigments (tamiya weathering master kits) for weathering and love the control it provides on building up the grime. Doesnt show up too well in photos but you can even mottle and fade the entire base coat, a subtle but nice effect. Still need the airbrush to really get stuck into the underside of the plane and heavier build ups.
                              Just need to triple check the radio programming and gyro config but otherwise she's all set for a maiden. Signed up to a new club with more room specifically to fly this thing lol, so need to get signed off on solo flight by an instructor there before the tomcat can take to the skies. She's a welcome addition to the hangar in the meantime.
                                • 8819
                                Originally posted by mshagg
                                retract supports
                                gyro config
                                Those are very impressive retract supports.
                                Which control surfaces are you affecting with the gyro?
                                I too, am very late to the party. I’m still in the “consideration” phase and the “do I have enough room to store another plane” phase.
                                • mshagg
                                  • 541
                                  • South Australia
                                  The receiver (S8R) is configured as a conventional aircraft and the 'box' remains responsible for mixing the pitch and roll axis to the taileron servos.
                                  So - the tailerons are stabilised in the pitch and roll axis in all flight modes (albeit with lower gains and in swept wing configuration) and the rudders have stabilised yaw input. The wing ailerons run on their own channels as trailing-edge-up-spolierons (with wings out) - aka the RCGeek setup - and are not stabilised. They also shift down on the full flap setting. Radio programming took several hours given there are effectively two distinct flight modes; thankfully it's someting i find enjoyable, and OpenTX excels at.
                                  I took GarrisonR's wonderfully thought out 3DP brace/support for the main retract housing (represented by the red box below) and integrated a strut brace (grey box) which bolts to it through the bottom of the fuse, so the whole thing is effectively one sub-structure supporting the main gear from the strut to the retract mount at the top of the fuse. Any landing that breaks that setup is not one you deserve to walk away from lol. The front retract support was adapted from Bmcormack's idea, who used plywood to achieve the same result. Guess that's the beauty of building up a plane that has 5 years worth of community developed improvements.
                                  And yes, we said farewell to some good planes to make room for this one! Some nervous looks around the hangar with Freewing's latest announcement...
                                    • 8819
                                    WOW! :clap:
                                    • PaulZ
                                      Crashing less
                                      • 279
                                      • DFW Area
                                      All, I am also late to the F-14 party, just got mine and it is still in the box. I looked at RCInformer's gear upgrades and although I am sure they are perfect it is a very expensive way to go. I'll reinforce my mains and the nose gear by putting a G2 sheet above and running long screws through the foam.
                                      • thisguy65
                                        • 509
                                        It’s less than cost of a new fuse, not considering moving everything over. There’s a new mod that will be included in the kit here soon along with the battery tray, hardware, wing plates.
                                        There’s going to be a promotion ran soon.
                                        Planes
                                        • PaulZ
                                          Crashing less
                                          • 279
                                          • DFW Area
                                          Do you mean this will be a MotionRC upgrade kit?
