The plates appear to be between 6.25"-6.5" wide, hard to tell exactly with the wing on, and just under 4" long (front to back). I would think to achieve the strength you're looking for 6" would give you enough to work with.
12" should be good too, from aluminum spar or front of the plate.. 12" puts you into the bulge just before the rudder.
Good luck!
Good luck!
. That is a heck of a deal for that much styrene :open_mouth:.
