  • RichJ53
    • Nov 2018
    • 342
    • Southern Oregon
    I was afraid of that. I'll go a head and replace them. Thoughts on these? https://hitecrcd.com/products/servos...-servo/product
    Hi-Tech servos are definitely an upgrade and this linked servo looks to be much better specs including the bearing output. I do not appose installing better servos, but the Freewing servos seem to work fine for me. I have had some FW servos fail or become twitchy and I just replaced them.
    I have to resist going down this path :) because your $450 foam airplane becomes a money pit. (ESC, BEC, inrunner motor etc)
    Rich
    • Aussie1
      Mainly turbine jets!
      • Feb 2019
      • 78
      • Adelaide South Australia
      • Dustman
        • 81
        Thanks LB, I got the file. I'm going to use this pic I found to do up the panel.
          • 4821
          DM, That's the template I used for the 3DP design. Perfect, Sir. Post pictures, please. Best, LB
          • JamesonC
            MRC fanboy
            • 619
            • Laurens, SC
            Originally posted by Patriotic_Banana
            I have an AS3X receiver in mine, going for the maiden tomorrow morning. I'll post the values I used for gains if they work well.
            Replaced the stock elevator servos with Freewing's metal gear 17g's. It is a night and day difference, super happy I decided to postpone the maiden for those servos.
            Can't wait!
            About to order the F18 and want to put the full metal elevator servos from the F22 in mine as well. Are these the two I need? One standard and one reverse?
            Thanks!
              • 8205
              Correctamundo.
                Those have slightly longer leads than you need. Get the ones with the 100mm/4" leads:
                • JamesonC
                  MRC fanboy
                  • 619
                  • Laurens, SC
                  Thanks for the help!
                  • Jetman64
                    • Jun 2017
                    • 113
                    I finally got one of my Hornets setup the way I want, and that allowed me to do the artwork. Here she is for all to see...
                      • 4821
                      JM64, Bravo Zulu. Looks great. Best, LB
                      • Wolfgang Wagner
                        Have a bandit day!!!
                        • Apr 2019
                        • 58
                        • Bavaria, Germany
                        Hey guys, did anyone experience a significant nose down effect with gear extension and counteract this with some elev uptrim, or is it only a minor effect? Thx
                        • Carlbrainiac
                          • May 2019
                          • 242
                          Haven't experienced this. Wheres your c of g? Maybe go a little further back? I'm at 90mm
                          • Wolfgang Wagner
                            • Apr 2019
                            • 58
                            • Bavaria, Germany
                            I'm in the middle of my assembly, so no experience of that so far. Just wanted to know if there is a mixing relevant like with the flaps. Thx
                            • Carlbrainiac
                              • May 2019
                              • 242
                              I personally do not use any mixing. I like to manage all control inputs myself but some people have applied mixing. If you get it right could then just adjust the power and she would almost land herself. But wheres the fun in that. Get the mixing wrong though, too much of one or the other and could make for a very hairy landing.
                                • 5387
                                No, it does not need a throttle mix. For flaps I have up 7mid/12full%. If you decide to do full span flaps I have up 14/20%.
                                • Quax
                                  • Jun 2019
                                  • 77
                                  • Bergisch Gladbach, Germany
                                  I wasn't the one asking but thanks for posting the values. I am going to maiden mine on the weekend and was looking for advice as well.
                                    • 5387
                                    Good luck with the maiden!
                                    • ticketec
                                      • Sep 2019
                                      • 55
                                      Hey guys,
                                      Just got my Grey F/A-18 and while i decide what scheme I'm finally going to do I thought I'd design some pimp my ride bits for it. I've added links to the files
                                      The Hornets I am going to model have the IFF bird slicer antennas on them and I thought the fence on the LREX could use some jazzing up to hide the ugly panel on the model that area. Still have a bit of setup work to do before the maiden as I will only fly it stock to get sorted and then a pretty hot setup is going to go in her :cool:
                                      Thanks
                                      dave
                                      A bit of scale bling for your freewing F/a-18, this is a base plate for the fences located on the LREX, just slide over the top of the fence and glue into place.
                                        • 4821
                                        Originally posted by ticketec
                                        Hey guys,
                                        Just got my Grey F/A-18 and while i decide what scheme I'm finally going to do I thought I'd design some pimp my ride bits for it. I've added links to the files.dave
                                        Dave, Thanks for thinking of us all. The 3DP parts look great. I will be adding these 'bits' to my Hornet as well. Tango Yankee. Best, LB
                                        • ticketec
                                          • Sep 2019
                                          • 55
                                          Just paying forward to all those who have designed cool 3DP for my other models in the past! Including you and your instrument panel which I have already printed up for it :D
                                          Quick Q, did you have to grind away a fair bit of the wheel hub to get the covers to fit nicely? It looked like I needed to grind at least 5mm
                                          Thanks
                                          dave
