    • 5401
    Have you talked to them yet? The shipping back and forth are on you for a no reason return. You are returning due to warranty defects...
    • JamesonC
      MRC fanboy
      • 619
      • Laurens, SC
      I have. I sent in a general customer service form asking my options, but was told this wasn't a warranty issue so I'd have to fill out a RA form if I would like to return it.
        • 2137
        • On planet earth....right
        Originally posted by JamesonC
        Looking at their policy, customers are responsible for shipping it back AND the cost it took to ship it to you the first time. That what happened on yours?
        Since the aircraft I had (was several years ago) had issues like warped surfaces, etc., if I'm not mistaken, I dont believe I paid for shipping in any way for the return/exchange process. It was a while ago, but I'm going off memory. During that time, I spoke to someone on the phone and they sent me the necessary return label.
        • Bobaroo
          If it Ain't Right on the Ground...
          • Dec 2017
          • 327
          • Newburgh, IN
          I was on a Deployment when my Jet arrived. I didn't get the box opened for about 4 month after it arrived. I had 'Warpage' on the Stabs, I got the Sorry, ... that out of your Warranty Period... Warranty starts upon receipt of Box, not when you Get around to opening it !!!! Hahahahaha. I explained my particular situation and got No sympathy whatsoever .... Veteran Owned business too !! OhWell... I just deal with it. GL
            • 2137
            I feel for you with that as that is a tough thing to have happen. Thank you for your service.
            • Herman Munster
              • Oct 2019
              • 15
              I just received my all grey version last week. I was disappointed to find out that the elevator plates aren't properly glued. I had to put very little pressure on them and they practically popped out. I'm going to have to remove them completely and re glue them. The sticker was on the box warning me to check the service bulletin prior to flying this plane but come on, I paid $479 for this plane and it has a issue that they know about yet are basically telling their customers "you fix the issue"
              • john2kx
                • 112
                • North Augusta, SC
                I ordered mine last week after doing the maiden +1 on a club members new F18. It felt that good in only two flights I knew this could cause my F22 to take the bench for a bit. Stock 6S powertrain is perfectly matched for this aircraft.
                It’s a bummer about the servos and plates but at least the issue is out in the open and easy enough to fix.
                John
                • gooniac33
                  The Original Gooniac
                  • Jun 2016
                  • 1047
                  My flights from this past weekend....
                    • 2137
                    Well, I have a gray ARF+ on the way. Hopefully this plane doesn't disappoint as I've wanted one for a long time.
                      • 8225
                      I replaced my elevator servos to all MG, did my due diligence as per the TSB and couldn't be happier! Great jet!!
                      • gooniac33
                        • Jun 2016
                        • 1047
                        Just do as the service bulletin says... you will be fine!! Plane flies awesome!
                        • john2kx
                          • 112
                          • North Augusta, SC
                          John
                          Pulled the elevator system apart on my new kit and found no issues as listed in TSB.
                            • 8225
                            My replacement didn't have any problems with the elevator setup either, just replaced the servos to MG and slightly dremeled more room for the leads.
                              • 2137
                              No doubt, man . I'm picky, so I go through things with a fine tooth comb, LOL. After I'm satisfied, then I'll get to painting, and further mods.
                              • Jetman64
                                • Jun 2017
                                • 113
                                That’s exactly why I’ve not purchased any more! If your lucky, you won’t have to cut foam to re-glue the plates. Otherwise, there’s two ways to fix it correctly in my book.
                                1. Split the fuse
                                2. Cut out the bottom portion around the plate only. (This is what i did)
                                But back to your point, there’s NO REASON on earth, anyone should pay $500 and have to make repairs before use, PERIOD!!!!!!
                                • JamesonC
                                  MRC fanboy
                                  • 619
                                  • Laurens, SC
                                  As expected, MRC has taken care of me 100%. I was disappointed to have mine arrive with damage, but MRC's customer service never disappoints!
                                  • gooniac33
                                    • Jun 2016
                                    • 1047
                                    I replaced all the important servos (aileron, flaps and elevator) and eliminated the blue box. That may have been slight over kill but I wanted to make sure it worked as I wanted. I will be using the blue box to get the LEDs working as they should. I also reglued the servo plates with extra thick CA and it made a huge difference!
                                      • 2137
                                      It's well worth the effort to make changes you feel will provide added assurance to the longevity of the jet . I know many of us have wanted a large F/A-18 like this for a while now, so it's nice to keep it around for as long as possible.
                                      • rcSpanky
                                        • Sep 2019
                                        • 16
                                        Hey Guys, just thought I'd post some progress pics from my F18 Build.. Going with the Canadian 150 Scheme.. not gonna win any scale awards with this one, but its my first attempt at customizing an airplane.. psyched to fly it, but have alot more to do..
                                          • 8225
                                          I can't explain what happened in that first batch of F/A-18Cs...I along with many of you have been waiting years for a quality scale 90mm EPO version of my favorite fighter jet so it was very disappointing to discover the issues that came about, which is completely uncharacteristic of Freewing. I do not have any inside information as to how the QC or issues got past final inspections but I can tell you there's no RC distributor that works harder than Motion RC to rectify any issues and continues to strive for quality and excellence in every release. Trust me when I say we will work our rears off 24/7 to make sure those types of issues are exceedingly rare.
                                          I am now flying mine with the confidence I should have, and it's fantastic! LOVE this jet man!
