    Yes my apologies if I misspoke earlier...I was coming from the mindset of if a customer wants to return a plane that has been painted...
    • rcSpanky
      • Sep 2019
      • 16
      Thanks Tom and Aros, No harm no foul.. just glad your working with me thru this issue.. my faith in MRC is restored. :)
      • Bobaroo
        If it Ain't Right on the Ground...
        • Dec 2017
        • 327
        • Newburgh, IN
        Originally posted by Tom
        Hi, I'm talking with my customer service team here at Motion RC. Sorry guys. We've had a bit of a miscommunication on our part. Painting a plane has nothing to do with electronics issues and we're happy to get you all fixed up.
        Outstanding !! Good to Hear. Thx
        • JamesonC
          MRC fanboy
          • 619
          • Laurens, SC
          This is why I love Hobbysquawk so much! Direct communication with the awesome MRC folks! They are great to deal with and just remember, we're all human!
          • Acook100
            • Oct 2019
            • 2
            Just picked one of these up, i started with an orangerx lite to just test everything and it seemed just fine. I switched over to a Lemon rx stabilizer receiver and now the rudder servos and front landing gear steering servo are moving in all different directions with no stick input. It seems like it begins to happen when I do anything with the flaps. Any help in fixing this issue is appreciated as i wont be flying it until i know this wont happen in the air.
            • fredmdbud
              • 451
              Seems like it's the LemonRX - you are turning stabilization on & off with the flap channel. Try setting up the RX so that stabilization is OFF, and see if the strange behavior continues. Since the rudder and steering servos are connected in common with the stock setup, they would move together.
              • Acook100
                • Oct 2019
                • 2
                The flaps aren't on the stabilizer on/off channel (ch5 gear). They're on Aux1 and gear is on Aux2. The power from the bec is plugged into the stabilizer on/off channel.
                  • 8834
                  That "should" work but just in case you've got something else going on, try the following:
                  Try plugging the BEC into a different port with a "Y" (eg, throttle) and leave ch5 empty so all it does is turn the stab ON/OFF. This shouldn't make any different but you just never know. Note polarity on ALL plugs.
                  Did you open up the flap menu (ie, select 1ail, 1flap, normal tail in the aircraft type menu)? Then go to your flap menu and do the flap zeroing and adjustments there and selecting the proper switch there? Usually, this would be switch D (3-position). When I'm suing the Lemon stabilized RX, I plug the gear into AUX2 (ch7) as you do and assign switch B (3-position) to operate the retracts but I don't stop in the middle position when flipping the switch.
                  What I'm trying to get at is that your "aircraft type", channel assign and port assign must be all set properly. Also ensure that all the direction switches for each control surface is set in the right direction (there is very little indication that the switch has reached the end so you must be very firm - after this, you'll need to first check the stick response direction, then with the gain pots set a bit higher to determine the gyro response direction when you move the plane. Put the gain pots back down for the first flight even though you have the ability to turn the gyro OFF.
                  • Rcfiddy1
                    Professional Crash Test Dummy
                    • Aug 2015
                    • 186
                    • Manalapan, NJ
                    Anyone record thier top speed? I got 81mph so far. Heres a quick hatcam vid with carrier landing.
                    • JamesonC
                      MRC fanboy
                      • 619
                      • Laurens, SC
                      81mph seems pretty low for this one!
                      • RichJ53
                        • Nov 2018
                        • 342
                        • Southern Oregon
                        Originally posted by Aros
                        So after my flip over it really took a substantial amount out of the top LE of the Vstabs thanks to the pavement. I am trying to think the best route to go as far as repairs. Would love to hear anyone’s thoughts. I am thinking adding foam and sculpting, sanding and painting...Any ideas?
                        Aros,
                        you can add some foam and glue using FoamTac then sand to shape, add some paint. I really don't see the need to replace unless you don't want to spend some time on the repairs. I found this old video showing the technique (about half way into the video 12:18)
                        • gooniac33
                          The Original Gooniac
                          • Jun 2016
                          • 1047
                          hat cam video haters... look away... but here are my flights from sunday...
                          • Bobaroo
                            • Dec 2017
                            • 327
                            • Newburgh, IN
                            I Love 'HatCam Video' ... when I'm Documenting Grilling a Rib-Eye let's say, or Changing out a CatBox liner !!! Hahahahaha
                              • 5424
                              145mph but I’m on 8s
                                Originally posted by RichJ53
                                Aros, you can add some foam and glue using FoamTac then sand to shape, add some paint. I really don't see the need to replace unless you don't want to spend some time on the repairs. I found this old video showing the technique (about half way into the video 12:18) https://youtu.be/G5lWOaN3Nfk
                                Thanks for the info!
                                • RichJ53
                                  • Nov 2018
                                  • 342
                                  • Southern Oregon
                                  you are welcome
                                  I really like using the Beacon Foam-Tac and the foam filler..... using some water to thin out the filler makes a smooth finish and very little sanding.
                                  Rich
                                  • Daneflyer
                                    Aviation is my life
                                    • 13
                                    • Centennial Co.
                                    I am thinking about getting the ARF version and putting in the power system from my FW 90mm F-16 which I removed as to install an 8S system in the F-16. I'm in the Denver area and the altitude takes a toll on the F-16. Was wondering if anybody at Motion tried that setup before deciding on the current setup which is 9 blade vs 12 on the F16 and 1000kV higher on the F-18 vs the F16. If so, would you recommend it?
                                      I finally started getting caught up on projects and put this one together with a Lightburner, it flys great on grass and is very stable and predictable...why would you not want a 90mm F-18 ;)
                                      • gooniac33
                                        • Jun 2016
                                        • 1047
                                        So the time has finally come to install the new graphics onto mine! It has been flying naked for now because I was waiting for to add the proper graphics on the plane. I am not a fan of the waterslides of this size and didn't want to fight with them. So I had Callie make me some and in the more updated #6 with Andre Webb as the pilot! I am hoping to get them applied today and then get busy on the glossing.... and then a new edf set up going in since my current set up (which has worked awesome by the way) is an 3 year old 12 blade unit used in my F-15 when I first started to fiddle with inrunners... Hopefull will be a new hotrod set up!
                                        • JamesonC
                                          MRC fanboy
                                          • 619
                                          • Laurens, SC
                                          What setup this time?
