  • seaviper
    ATC retired
    • Aug 2016
    • 1092
    • Philadelphia Mississippi
    My base gray high performance version had the damaged elevator servo wires. I replaced the servos from my own stash and trimmed the pockets with an xacto blade about half a mil on each side. I reported this to Motion a couple days ago. Today I read the technical service bulletin. Doh!
    One thing I noticed in the manual is that the stated length for the rudder control rods is too short by about 5 or so mm.
    I am running full span flaps, flaperons, tailerons, and rudder brakes.
    • Greyhound61
      Hobby Squawk Pilot
      • 37
      • Lucerne - Switzerland
      Pilots, finally maidened my Swiss Airforce F/A-18 Hornet. Such a beauty to fly. Definitely a keeper.
ID:	268188Click image for larger version
ID:	268189Click image for larger version
ID:	268190Click image for larger version
        • 8225
        Beauty!
          • 4852
          Greyhound61 Phenominal work. Love the Swiss F-18's. I have been using those as reference. Just a great job on your livery. Bravo Zulu, Sir.
          Hornet Enthusiasts Et al, reworking the FIR's and supports. Printed these with PETG and like the way the design looks. Also, PETG is easily finished/cleaned up and is less brittle than PLA so thought for this application it would work well. We'll see, huh? Best, LB
          • Corsair nut
            Jets...warbirds...mmm hmmm
            • 218
            • Tehachapi ca
            Dang tgats sweet elbee!! Did you ever see the mods i dis to my f18 inlets? I was able to get better performance with no cheater
            • Corsair nut
              • 218
              • Tehachapi ca
              Greyhound..that looks sweeeettt!
                • 4852
                Originally posted by Corsair nut
                Dang that's sweet elbee!! Did you ever see the mods i dis to my f18 inlets? I was able to get better performance with no cheater
                Thanks, CN, Didn't you use Carbon Fiber to recreate the FIRs? Did you reshape the interior of the inlet ducts? I noticed the LG mount extends into the inlet, but it is so slight didn't figure it would matter much. I'll rewind into this thread and check your mods. Best, LB
                • Corsair nut
                  • 218
                  • Tehachapi ca
                  Yeah..i cut away in the inside. Yellow Aircraft had the same setup on their df single and twin f18. It worked extremely well. When i get another f18 ill be doing the same.
                  • Mizer67
                    • 374
                    How's the F-18C fly compared to the F-22?
                    I've got a spare 120A ESC and the 1750kv 9 bld. motor from my F-22 lying around. Thinking of ordering the ARF Plus as this would be the same motor that comes in the base PNP version that's getting phased out.
                      • 8225
                      Both are great flyers. The F-22 has a bit more forgiving/trainer-like feel to it due to it's massive wing surface. But don't let that fool you, she is more than capable of high octane flight and performance. Wide envelope.
                      • seaviper
                        ATC retired
                        • Aug 2016
                        • 1092
                        Ready for the maiden... full span flaps, flaperons, tailerons, and rudder brakes.
                          • 5401
                          Since the flaps don’t go up what’s the difference between full span flaps and flaperons? Do you mean crow?
                          • seaviper
                            ATC retired
                            • Aug 2016
                            • 1092
                            ailerons that act like flaps too
                              • 5401
                              Ailerons that are flaps without the normal flaps? If with that is full span flaps. I have crow plus the rudder airbrakes in mine. While not much value in the air they are great for braking on landing, they shorten the roll out quite a bit. I also don’t like the full span flaps, it makes the plane a bit unstable.
                              You'll need some elevator compensation.
                              • EA-6B Geek
                                EW Misfit
                                • 485
                                • South Central Ohio
                                Nice looking jet!
                                • seaviper
                                  ATC retired
                                  • Aug 2016
                                  • 1092
                                  On the FA-18, the ailerons also work as flaperons. The flaps are still flaps. The rudders also both move inward to aid in rotation at takeoff. The elevators assist the ailerons. in other words, they are all mixed.
                                    • 5401
                                    Yes, I worked on them and other carrier based planes for years. Not to say that I do mixing that the real planes do though, I do mixing that I want to try and see how it works.
                                    Remember to make appropriate pitch mixing especially for the rudder airbrakes.
                                      • 4852
                                      SV, Great-lookin' Hornet. In the last picture, your Crew Chief seems to be dropping by to inspect your work, as well. Bravo Zulu, Sir. Best, LB
                                      • seaviper
                                        ATC retired
                                        • Aug 2016
                                        • 1092
                                        Those are my security and crew chief. I call them my staffelhunds
                                          • 2137
                                          • On planet earth....right
                                          That looks awesome .
