    • 2693
    Test flight complete! The F18 on 8S is sweeeet! If you're flying off asphalt, stay with 6S, but for grass, 8S makes a big difference. Our runway was getting quite thick and even cut short, my 2 F18'S were starting to struggle getting off, borderline at stall speed, making each take off an adventure. Installed an 8S fan in my oldest F18 which was pushing 100 flights, with several early flights before going to AS3X Plus, less than perfect. It has the Elbee incredible cockpit and a JHH full body pilot, which added nose weight and a recent flight that when the pilot in the cockpit (not the one operating the TX sticks ) attempted a go around, got it in too high alpha, and spiraled into the ground, severely damaging the forward fuse. After a ton of epoxy, spackle and gallons of paint, it looks perfect, but had to add an additional 7 ounces of lead to keep my tail heavy balance (on top of 2 1/2 ounces already there) at 105mm.
    So would this fat cat even get airborne? Stock it's already borderline on wing loading, what would almost 3/4 of a pound of lead and an 8S battery do to it? Well, no problemo! Got off fine, and the grass was even wet, and flew great, couldn't tell it was a candidate for TV's " My 600 Pound Life".
    Put a short video of the take off below, also the F4 on 8S, which plows through heavy grass like a bull! The grass mounds and ant hills really threw off the F18's take off run, making it kind of squirrelly, especially since I have it tail heavy, but damn. I LIKE IT!
    I'm now officially an 8S Junkie, may never get a 6S 90mm again. On 8S have 2 F4's, Eurofighter, F16 V1 and the F18 Canadian and soon to follow the F18 Tiger. That one only has about 30 flights and is in pristine condition so won't need all that extra lead. Look out Maduro and the Drug canoes off Venezuela!
    The SMS 8S HiV 4900 & 5900 are perfect for these. The F4 and F16 in 8S also fly much better than on 6S.
    Sorry for the poor video quality, shot by a friend using his phone, which I believe is an older rotary phone.
    Our Lawn mowers, soon to be venison burgers:
    Click image for larger version  Name:	20190815_080305.jpg Views:	0 Size:	99.1 KB ID:	431991 Click image for larger version  Name:	20241002_152628.jpg Views:	0 Size:	305.8 KB ID:	431992
      • 8205
      Good to hear brother! Man I love your lineup of birds!
      • jetpltrich
        I fly with gyros!
        • Dec 2021
        • 155
        • Somewhere in east Texas
        I took the liberty to configure my F-18 Hornet Gray to mimic the real F-18 Hornet Flight Controls. The link is a post video configuration test of the flight controls, sorry no flight video.
        My first step was to replace all flight control servo's, minus the rudder, to HiTec Torque servo's. It has been my experience the original servo's, specifically the flap servos, are simply not up to the task and give up on the full flap setting over time. I believe this has been mentioned by others.
        I purchased a new 8-channel Spectrum Plus RX and updated it to the very latest software; I think it is version 3.3. It has been my experience that even though they are newly purchased RX’s they have older versions of software.
        Because the configuration required use of all 8 channels, I put the Assan AG61 steering gyro in the aircraft. I love steering gyros!
        My concerns with this configuration were many, specifically the roll rate and how was the airframe going to act in turns. What could I expect with full span flaps on approach. So, with that I created one more Rate/Expo on the three-way switch that controls rates.
        High Rates: 100% rate, 12% expo
        Mid Rates: 70% rate aileron/elevator, 80% rudder, 12% expo
        Low Rates: 50% rate aileron, 70% elevator, 80% rudder, 12% expo
        If I experienced too high of a roll rate on Mid Rates, which I intended to use for the test flight, I could switch to low rates.
        Gains were put on the gear switch, down increased the gains considerably, up reduce gains.
        This morning I test flew it.
        Weather:
        Winds Calm
        Clear Skies
        Temperature 65F
        Altimeter 30:10 pressure
        Density altitude 680 feet.
        Runway 3800’ x 60’
        The aircraft flew great! The rotation to flight took less than I expected. Roll rate was pretty much normal though it required a tad more back pressure on the stick to maintain the turn. I did one roll and it roll like a drill bit much like the A-4.
        Overhead break to down wind and once level selected Takeoff flaps. I noted a slight pitch down and I was expecting that, a tad of back pressure corrected that. Gear down presented no issues at all. Now for the full flap selection. Much more nose pitch down though I quickly corrected. I throttled up to approximately 40 to 50% throttle and she settled into a very nice stable approach. GPS speed was approximately 30mph. The airframe presented itself as if it was the real thing, so cool. I'm going to add more percentage of up elevator in the flap settings.
        Note: In case of a go-around full flaps are your enemy! It is not the gear that is the drag, it’s the flaps. In the 737 I flew as an airline pilot the procedure is: 1. Go-around thrust, 2. Flaps 15, 3. Positive rate of climb Gear up, 4. 1000’ agl or minimum safe altitude lower pitch and clean up per MASI Speeds. This applies here with the little planes as well. This configuration has a lot of flaps hanging out in the final landing configuration.
        I maintained the 40 to 50% power until in the flare and she settled on the runway as if she was landing on a carrier. Should it be windy with light gust I'd increase speed appropriately.
        I just wanted to share this with those that are leery of this plane. The Spectrum RX has really changed this aircraft and this configuration is really cool.
        Rich
          • 5387
          Great report. Please be careful with full span flaps, especially the amount you are using. It's fairly easy to stall the wing.
            • 2693
            jetpltrich Outstanding report Rich!! Now if we can just get Aros into the "Brotherhood of the F18 Plus RX", maybe we can get Freewing to do a V2 Super Hornet. But then my 8S Hornet would just be obsolete after only a week. Hornet number 2 set for 8S upgrade Sunday
            • jetpltrich
              I fly with gyros!
              • Dec 2021
              • 155
              Thanks Evan and Hugh. My goal with this project had two objectives. 1. To really prove the Plus receiver is cable of taming this airframe, and 2. To let others in this community know that though this airframe is wicked it can be tamed and be an absolutely awesome bird to fly. I approach flying my jets like flying the real thing. I fly with a GPS speed read out and have found like the real thing it helps tremendously. My only issue is it has a slight lag and the mental math on windy days can be a challenge. I would like to see Spectrum bring back their airspeed unit, if anyone has one laying around, I'll gladly purchase it.
              I really hope that Aros has a successful flight with his F-18.
              Rich
                • 8205
                Thank you sir, that makes two of us!
                  • 2693
                  Just finished my 2nd F18 upgrade to 8S! Whoopi (and not the Goldberg kind. ) Now calling them "Semi-Super Hornets", just hope the graphics and paint don't strip off from the intense air friction at full throttle!
                  Was only able to get 3 flights on the 1st over the last 2 weeks due to continued never ending rain, so hoping to test #2 out soon. #1 flew spectacularly, so no reason this won't either. Nice thing about the upgrade was that the 8S battery placement wasn't much different vs 6S, back less than 10mm to still balance at 103mm. Previously used SMC HiV 6S 5900 (750 gr), now using SMC HiV 8S 4900 (843 gr) or SMC HiV 8S 5900 (972gr).
                  Check out the clean battery bay thanks to Jandro's guidance, (battery placement of the front of a 4900 at green lines, 5900 about 20mm further back):
                    • Nov 2013
                    • 2667
                    • Cody, WY
                    Super work, Hugh!
                    Wishing you blue and dry skies!
                    Cheers
                    Davegee
                      • 2693
                      Why did I have a double post? I know everyone is just sitting on the edge of their seat hoping to hear words of wisdom from this modern day Mahatma Gandi, but once should be more than enough for my adoring fans!
                      Elbee can you delete one for me (maybe both if you're honest about it)? Tried, but couldn't do it, I'm more of a rotary phone guy with turntable music in the background.
                        • 8755
                        Hugh, I believe your double post is part and parcel of the ongoing issue with this site's "mechanics" (IT stuff). A few of us have experienced intermittent security issues and slow (extremely slow at times) response to "Post Reply", Edits and Saves. As such, this may compel some posters to click "post reply" a second time because nothing happens after the first click. I've experienced up to 30 seconds before a reply is posted. Someone else here has reported up to 1 minute. That's a long time to wait for something that usually takes less than a second.
                        • f4u ausie
                          • 1230
                          • Melbourne
                          Hugh U make us all chuckle.. me anyway no shadow of a dought. That awsome tiger paint will be shredding paint soon .. won't b easy to fix.. weather here crappy tmora morn (Sunday). So gota wait bit longer to get F16 first 8s flightin nervous but confident .. with little Xtra weight. Just keep speed up me
                          • ConnorBlast
                            Banned
                            • Sep 2025
                            • 2
                            hello everyone..!
                              • 4820
                              Originally posted by ConnorBlast
                              hello everyone..!
                              CB,
                              Welcome to Hobby Squawk.
                              Glad to have you onboard, Sir.
                              Best, LB
                                • 2693
                                I've definitely experienced those extremely slow post and edits time, so you're probably 100% correct, as usual! For me, this has been going on about 10 days. At first I thought it was my Cobalt based computer and was considering upgrading to Fortran, but this is the only site with those delays! The site takes twice as long to open and respond as before and when posting the "working" label takes forever, so much so that I'll hit "Post Reply", then go off and read a book and come back later! Took 10 seconds just to load more similes here!
                                  • 8755
                                  That's about the same amount of time for me as well, maybe a bit longer. (Things might go a lot faster for me if my punch card reader didn't jamb so often.)
                                    • 8755
                                    Originally posted by Elbee
                                    CB,
                                    Best, LB
                                    Elbee, this is just a post of his to set us up for SPAM! I've reported his SPAM post.
                                      • 4820
                                      Got it, banned member and deleted Topic.
                                      Thanks again, couldn't do this without y'all.
                                      Best, LB
                                        • 8205
                                        Gents,
                                        Could use some help for a buddy of mine. His words…
                                        “I need the elevator servos for a F-18 I'm working on but there are so many 9g servos on your site I don't know which ones to get. I'll need a standard and reverse servo. Can you ask folks which one of the new better 9g servos I need?”
                                        Ideas? It’s true, we have so many to choose from. Appreciate the help!
                                          • 8755
                                          Originally posted by Aros
                                          Gents,
                                          The ELE servos on this plane are actually 23g, one “normal” and one “reverse”. To be sure, take one out and see what it says. If you go to the product page at MotionRC, in the “overview” tab, scroll down to “servos”. It actually tells you the catalogue number in the form a link. Just click on the link for left ELE and right ELE and it will take you to that product’s page where you can put it in the cart. Failing that, the ELE servos are the only 23g ones for this plane that has 100mm leads. Unfortunately, they are SOLD OUT at MRC.
                                          There’s still hope. You can get them from RC Castle for the same price but you’ll have to pay for shipping from Hong Kong. They have stock.
