Got a second real flight in today this little gem flys awesome! Trimmed her in and used the stabilizer. Gonna move the batt back on the next time out.
Well the maiden didn't happen tried but I couldn't get it to lift off, our grass strip is very smooth and grass is cut very short , I was using a 5200 6s 10c that I use in my F3a pattern plane but ran out of runway which by the way is 100 mtrs long, I had a old 5000 . 40c pack which is a bit swollen but I couldn't get the canopy to close, model seems to have plenty of power with both battery's , I have the cg set at the front of those plastic bits on the wing.
So I have ordered a new 5000 40>60c so will have to wait another week before I can try again
- Likes 2
I have found the larger 5000 6S packs do not allow the canopy to close because of the foam bracing inside. I had 2 Venom 5000 6S 30*C and the fit great with lots of power. Probably the 4000 packs are ideal size but I do not want to buy more batteries :) Sorry I do not fly off grass, but the 5000 pack needs to go back towards the tail to get the CG right (for me)Originally posted by rsunleaded View PostWell the maiden didn't happen tried but I couldn't get it to lift off, our grass strip is very smooth and grass is cut very short , I was using a 5200 6s 10c that I use in my F3a pattern plane but ran out of runway which by the way is 100 mtrs long, I had a old 5000 . 40c pack which is a bit swollen but I couldn't get the canopy to close, model seems to have plenty of power with both battery's , I have the cg set at the front of those plastic bits on the wing.
Here is the link to the Venom battery so you can see the measurements.
Rich
I'm sorry, I checked my battery list for each plane and I was mistaken. I used a turnigy Heavy Duty 4000mah, 6s when I tried to get off the grass and couldn't do it. Mind you, the HD 4000 weighs the same as other 4500mah batteries. I can only fly this plane from GeoTex runway. I may try a 4000 Admiral next time I go to the grass field and see what happens.Originally posted by xviper View PostWith a 5000mah battery, mine couldn't lift off the grass either.
Did you try that with the stock cheater hole?Originally posted by rsunleaded View PostWell the maiden didn't happen tried but I couldn't get it to lift off, our grass strip is very smooth and grass is cut very short , I was using a 5200 6s 10c that I use in my F3a pattern plane but ran out of runway which by the way is 100 mtrs long, I had a old 5000 . 40c pack which is a bit swollen but I couldn't get the canopy to close, model seems to have plenty of power with both battery's , I have the cg set at the front of those plastic bits on the wing.
An FPV guy showed up at the field I fly at, and made this short movie for me. So cool. Loving my F35.
Originally posted by DaFlyingSnek View PostSo what is the actual CG? I see people talking about different CGs and I'm honestly quite confused.
F-35 V3's proper Center of Gravity (CG) For the proper CG point refer to the photo at this link.
