I've been doing this for nearly 10 years and still stuff to learn.
You are more likely to crash this plane due to not balancing it properly. Take note that the CG page of your manual may not be correct. Mine came with a "stick on" correction that gave the "correct" CG. If your manual does NOT have the "stick on", you likely do not have the correct CG. Do your homework and make sure you know what the correct recommended CG is. The other reason for a crash is due to this plane having full flying stabilizers and these can tend to be quite "twitchy". In this case, use of some (or a lot of expo) will help dampen this effect until you figure out what throws work best for you. Compound this with the fact that this plane is fairly fast, the twitchiness could be quite alarming. Of course, let's not forget about "dumb thumbs".Comment
Noted on the full stabilizer. I've read through this entire this thread believe it or not. So the one thing I did see was the addendum and correction to the CG. Do you just use your fingers for CG or is it worth it to invest in a CG machine?I've been doing this for nearly 10 years and still stuff to learn.
I want to “second” the advice about CG placement!!!
Also, the other two things that surprised me about my maidening of this plane were: (1) roll rates even with low travels were very quick. It’s due to the *huge* ailerons. I think I have my low rate aileron travels (for takeoff) set at 40% (Travel! Not expo!) (2) once in the air, it’s fast. On grass the takeoff roll is long, leading you to think the plane is marginally powered. But, after liftoff, it accelerates and top speed is probably 100-120 mph. I also kept the throttle up after takeoff thinking I needed it. Actually, after in level flight, 60% throttle is fine for the pattern and learning the plane’s responses. Full throttle turns into speed quickly, which amplifies the roll responses.
Finally, I’ll add that you must land this plane nose-high. It’s the only way it slows down. I actually start getting the nose up when I’m on base, and final needs to be nose up, with descent rates controlled by throttle.
If you lift the nose up, and the plane “goes up”, you have too much airspeed and you need to make another pass.Comment
I use my fingers on the spot on each wing to hold it up. I did buy a balance machine a while back. Used it a couple of times. Haven't used it in years. CG placement on most foamies (and even non-foamies) is somewhat flexible. People used to say that CG MUST be to the mm. I think that's gone by the wayside now. There are still a few anal retentive people out there who say that "moving the CG 1mm forward made all the difference in the world". I call a BIG BS on that. You can't even discern the line of demarcation on a battery down to 1mm. Such people shouldn't be drinking and flying at the same time.Comment
Hi guys,
I wanted to pass this along regarding my jet fan unit on the F-35. I have 48 flights on my F-35 now and it has been lots of fun to fly. As most of us know, the ducted fan is out of site and we do not think about checking it for maintenance. I check all the servos and linkages every flight, but never really thought about the ESC or Fan unit.
I pulled the access cover off of my F-35 and discovered the fan screws were loose and the ESC was loose and moving back and forth. Wow, I tightened everything up and all is well. I am adding this to my check list after 20 flights.
Hope this helps others too.
Rich
Here's a trick I learned from my electronics test fixturing days - apply a dab of enamel paint (or even nail polish) at the screw/flange joint to make it resistant to working itself loose.Comment
OK as I takeoff from grass and have seen the few issues with extending the nose leg I decided to try putting some 10mm(3/8") packing under the retract when retracted the nose wheel protrude below the wheel cover but if it works I can live with thatComment
I always take out the screws that come with the kit and use a much courser drywall type screw. they hold better and don't loosen over time.Check me out on youtube at https://www.youtube.com/user/gooniac33
I am an RC addict and innovator that loves to share my knowledge with those that need help. Ask me anything via PM if you need help! Check out my Website here https://www.gooniac33.me/Comment
That's a great idea. I put some FoamTac on the screws on my fan unit. I guess as long as your fan is balanced and you don't pick up debris into the fan blades... all is well
RichComment
Great idea... I used FoamTac on my screws which is a similar thought. Also, you need to check the plywood mounts are thoroughly glued into the foam. I found on side barely glued into place on my T45 jet.
RichComment
I just wanted to post something that happened recently to my airplane that could be a reminder. When I was flying the model the fan failed in flight, causing a loss of power leading to a belly landing. When you assemble the airplane and before you fly, make sure you check the fittings holding the fan on to limit the chance of failure. I hope this helps others from experiencing this same situation. Thanks.Comment
On mine, after about 45 minutes of airtime, the fan decided to remove itself from the motor shaft. Fortunately it did so on Power up while on the taxi way.I just wanted to post something that happened recently to my airplane that could be a reminder. When I was flying the model the fan failed in flight, causing a loss of power leading to a belly landing. When you assemble the airplane and before you fly, make sure you check the fittings holding the fan on to limit the chance of failure. I hope this helps others from experiencing this same situation. Thanks.Comment
The fan came off from the housing, along with the spinner. I suspect the retaining screw and washer loosened, causing the spinner to separate which lead to the fan coming off and disintegrating. It damaged the foam in the process of course.Comment
Jerry
