It wasn't fun. I'm still wondering if I'm going to fly paint off....
[/QUOTE]
As I said before, the paint adhesion on this model is one of the worst I've seen. Freewing's process seems to me to be much better, but is the foam molding process so much different between the two? Even in repainting the raw foam nose cones, priming did not work as well (even after cleaning it profusely with alcohol several times) as with other models and even after coating with spar urethane several coats, light trim masking wanted to lift everything off.
I do feel that after 4 coats on the entire jet after finishing that it gave it a somewhat better "shell", so if you find the paint "flying off", you may want to add some clear coats. I'm sure you don't want to alter the matte finish that looks so realistic, but maybe if you try the matte or satin urethane finish, it won't change the look. BTW, forgot to say how much I like your canard wing modification. Your bird REALLY stands out from the crowd. Bravo!
. If you had just a little snot on your fingers, the paint would come off. If it smelled masking tape coming, the paint would just fall off on its own.
I think it's got to do with the releasing agent they spray into the molds so that the foam parts can fall out easily. The more complex the part, the more agent is needed. Same goes for if the part is large in square area. If they don't fall out on their own, some human has to be there to coax them out. Such circumstances really should have a better prep stage before the paint goes on.
, in which case, I'll fly it as is for a couple of flights.
, but the 5500mah 70C came in at 20C, still higher than the Admiral 6000 50C, but not by much. I'm guessing the actual C can't be much more than 30C based on the internal resistance tests of this meter. Roaring Top came in at a true C rating of 29% of stated!!!
It still has plenty of thrust, just not as much as with the Admirals (and I'm not pitching Admirals, I'm sure there are plenty of other great brands out there). I've been flying all my jets on the AD 6000 for the last 4 months, always felt they have plenty of power, but after hearing everyone say RT where best, I had to try them out. Well, I now have 8 new 5500 70C and they may go into permanent storage.
