Plan to be on deck at 3 min useful throttle on a maiden. That way an unplanned go-around won’t leave you hanging at the edge of the power reserve if you’re heavy on the throttle for the maiden.
Flys great, and very honest. Good luck! 👍🏼
Hi duke I would recommend watching through the several videos we have published so far showing this bird flying. Flight conditions, throttle usage, battery health and other factors will influence your experience compared to ours, but as always with a large EDF we recommend a conservative 3 minute timer for your initial flights.
At the 3:00 mark in this video, the total flight time ends up being 4 minutes (3 minutes of which is throttle use above 10%), landing at 3.79V per cell, on two Admiral 6s 4000mAh PRO batteries, so your 5000s should fly longer, assuming you're not trying to hover or break a speed record on your first flight (which you shouldn't be).
But as always, it is smarter to land too early and add time in 10-15 second groups on subsequent flights, rather than to land too late...
Hi RCGuy83,The tension in here is high as your MiGs get closer and closer.
I know many of you know what you're doing but I wanted to point out a couple things I went over on my build. I estimate I spent about 45min building the jet and about 6hrs setting it up. I pulled the engines to check the fans, pulled the ESC's to solder bullets, and setup my radio system on the bench first before installing it in the plane. Make sure to set the elevator servo horn positions to the middle hole and set the manual recommended 1mm of nose UP neutral trim. Book rates seemed solid with 30% expo on elevator/aileron.
Can you please tell me if the retracts can be operated from the receiver, or they need the blue box?
Thank you,
CristianComment
Given the sequenced doors if you run the mains direct from the Rx they'll need another channel so you can add the appropriate delay.
That said, even the most strident critics of junction boxes usually leave them in charge of gear sequencing and light control.Comment
I will use a 12 ch receiver, so every control surface is on it's channel, and also dual motor control, so no issue here.Comment
You need 11ch for everything I'm doing. Having everything on separate channels makes set up much easier and so that I can have tailerons, full span ailerons and flaps, crow and rudder air brakes.
Thr
R Ail
R Ele
R Rud
L Flap
L Ail
R Flap
L Rud
L Ele
Gear
Steering
Adding the second motor and separately doing the gear doors makes it 13. I'm doing the 11ch route to have every surface on it's own. If I end up doing TVs (still zip on date or price) I'll Y the rudders and steering to get the 3ch's the TVs need. That takes away my rudder air brakes.
With 5,000mah packs I set my timer at 4min. I was landing right on the timer and my packs came off at about 3.75V per cell. I won't be setting my timer any higher. :face_with_monocle:
