I believe Alpha covered this during one of the Mig Sessions. I believe they pair up the stabs at the factory to a set toleranceComment
Maybe for lateral balance but I’m pretty sure not balanced to the elevator pivot point. I could be wrong, I’ll get mine tomorrow and will verify.Comment
Thanks for the post James. I mount most of my main receivers under the battery trays. On this one the area isn't big enough to put the MCBe there too or I would have. The antennae are long enough to go through two holes in the foam under the tray mounts and up the inside of the fuselage on either side. I also have a dual diversity satellite in the very nose with a very long satellite cable. Up there one coax antennae goes across the nose and the other along the side of the forward fuselage.
Right now I'm using a 10ch receiver and have each surface on a separate channel, only the flaps, gear doors and throttles are Y'd. That gives me tailerons (which MiG-19's need to give me the roll rate I like), crow, and rudder air brakes plus steering on a separate channel. I have a 12ch receiver if I decide to add TVs. To do all that the MCBe is bypassed for everything except the retracts, gear doors and lights.
Doing this the middle battery area is clear of all wires (except the forward retract wire, steering servo wire, landing light wire and satellite wire) and the MCBe. That way it's very uncluttered and clean for battery use.
As far as Orange, they are my go to brand and I have them in the vast majority of the 98 models I have ready to fly. Knock on wood they have been bullet proof for me through the years. They are harder to get now and I grab them (mostly the 9, 10 and 12ch) when they come up for sale.
My FW Mig-29 is built and I just need to check CG with a couple different packs and check range before maiden on Sunday (tomorrow is bad-ish weather here).
Hey Evan, are you sure you want to mount the RX under a huge pack of Lithium? Hard to tell from the picture, but I assume the aerials are long enough to go perpendicular to each other in directions that extend out and away from the battery, but if you just mounted the receiver where the blue was, it would be much more free and clear and less likely to get interfered with. A majority of the time your flying a jet, the top is going to be facing you more often, just feels risky to bury it under lithium (which 100% blocks signal) when so much space exists in the entire compartment.
I won't say anything about the ORX other than I didn't realize they were still around
I'm disappointed that my 26 August order did not make the cut for the batch that shipped in September, but I'll live. It gives me more stick time to get ready with other models. I took seven years off of flying RC and came back this Summer. I was eyeing the A-10, but when I saw the size and quality of the Mig, I knew I needed to have it. Really hoping that container ship gets favorable currents so I can get it in the air before the weather turns cold here in the DC area. Thanks for sharing all the lessons learned everyone. Good stuff here.Comment
It was pretty obvious.
Another point comes to mind about this whole balancing thing. Even though such a control surface is weight balanced, isn't there a concern about airflow balance? That is to say, if you have a larger surface area on one side of the pivot point compared to the other side, the whole thing can still be affected by how the air flows over it. IE, weather vaning. So, the question is .............. which would present a more forceful affect? Weight imbalance or weather vaning. If it's weather vaning, wouldn't that make weight balancing less critical and perhaps even insignificant?Comment
One thing i noticed is the Elevator Servo arms as delivered are static centered with the arm arc slightly aft. If someone sets their end point over 100% to gain elevator throw, or at 100%, the arm will almost be or be pointing straight aft. Which may lead to inability to gain leverage and servo freeze.
Not saying people do it, but you never know. Might want to reposition the Arm a tooth or two forward arc, then reset throw and end points.
Nope. If one moment arm is larger then the other ther servo will work harder no matter the force feom the air flow.It was pretty obvious.
I found a useful picture of the fullsize Mi9-29 that this plane is modeled after. I was confused where to put a couple of decals, there is a Crest and an "0921" that is on the forward lower part of the tail fin and this picture shows where they are located.
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
https://youtu.be/U27tP40nabg This is exactly what happened to mine and exactly how mine went down... seems like lots of people are having the same issueComment
